I built the UF-20 zoomie host a few weeks ago and was pretty happy with it, but wanted MORE power. I found an xhp50.2 3v and dropped it in...
The plastic retainer has a 5x5mm square cutout- perfect for the xhp50 size die. It's the K2 2A bin 6000k which is supposedly pretty high. In case anyone's interested, I got it from Aliexpress LHT Flashlight Store. It wasn't cheap but came on a thick 16mm Kaidomain DTP board.
The driver is the same FET Convoy driver, but I added thicker wires and a thicker bypass wire. I bypassed the spring in the tail cap as well. That made a really big difference with the sst40!
On the fresh Sony VTC6 the output is astounding.
Zoomed in the hotspot is bigger than the sst40. You cannot see the 4 individual dies of the xhp50.2.
Moving outside...
Just a solid shaft of light. Doesn't throw quite as far as the sst40, but it's much brighter.
Pointed it up...
On flood mode it's crazy bright.
I thought I'd have issues with the 4 dies being visible, and they are with the cross pattern, but just barely. You can't even see it in the photos.
I like the beam much better than the sst40. Yes, the sst40 throws more, the battery runs down faster on turbo, and the sst40 has a brighter hotspot, but less flood and isn't as bright. I say the brightness is doubled easily. There is a noticeable corona. The xhp50 isn't breaking a sweat and doesn't get as hot as the sst40 either. I know I can push it much harder. Maybe a driver swap is in order?
Thanks for looking.
