Looking for some help on battery selections for the following flashlights.
BLF A6 XPL 3D
Convoy C8+ XPL Hi – V2 1A
Convoy S2+ L2 7135×8 XML2 U2-1A
Convoy S2+ SST40 (5000k)
I am not sure if these batteries will work well with the above lights, as I have them from a short vaping stint I had awhile back - I currently have the following:
2 x Panasonic 3400mAh 18650 NCR18650B Flat top
2 x Red LG LGDBHE21865 2500mAH 30A 3.7v
2 x Xtar 18650 2100mAh
If those will work, which would be best for each light? If these are no bueno… what would you guys recommend for the flashlights?
Panny-Bs are fine for low-stress lights (up to 3A or so), and most of the S2+es should be fine with them.
Not sure how much the C8 draws, but it should be fine with a panny-B, too.
A6? Might be more than that, so you can’t go wrong with 30Qs.
Aha, saw above that you actually have the cells you listed. Still, the panny-Bs would be fine in the S2+es, and any of the others would be fine in the A6.
30q in the A6 for sure. Being overly cautious, I use some protected cells that came with other lights in the S2+ since it does not have the protection the A6 has. Others are more responsible than I am and go unprotected keeping an eye on the battery.
