[M4D deal] Nightwatch NI40 with Luminus SBT90 Gen2 interest list OPEN
452 posts / 0 new
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 15 hours 51 min ago
Hi Martin, could you still send me a code for 2nd batch?
Do you have any info about approximate lumen specs or current draw of all mods?
Could you confirm the light always starts on moonlight mod (no memory)?
Tom E
Tom E's picture
Last seen: 4 hours 22 min ago
Thanx! Got the code and submitted the order for batch #2.
M4D M4X
M4D M4X's picture
Last seen: 4 hours 23 min ago
Afair it has mode memory
since I am not at home I cannot measure every mode etc...
codes are sent to all requests asap
still not easy here in China Wink
will be better Monday when I am back
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
blueb8llz
Last seen: 9 hours 29 min ago
since I am not at home I cannot measure every mode etc…
Good to know. I just purchased three units. If you can confirm turbo is in the mode sequence or at least if turbo can be memorized, I’ll purchase another 3 or more more.
JordanZHP
Last seen: 27 min 41 sec ago
How’s does the SBT90 Gen2 compare to Osram leds, such as white 1mm, 2mm etc?
Tom E
Tom E's picture
SBT90.2 has wayyy more lumens, wayyy more amps. Not sure head-to-head on throw in similar lights, but I would imagine the 1mm/2mm's are more of a pencil beam simply because of the higher lumens of the SBT90.2.
M4D M4X
M4D M4X's picture
I try to find out
Edit: Neal said yes
Dyrnwyn
Last seen: 4 hours 59 min ago
Placed my order, thanks Martin and Neal.
Th558
Th558's picture
Last seen: 6 hours 21 min ago
M4D M4X wrote:
I try to find out
Edit: Neal said yes
Yes to what? Turbo can be memorized??
M4D M4X
M4D M4X's picture
correct
blueb8llz
Wonderful. This light is gonna be a hit.
SKV89
Last seen: 1 hour 25 min ago
For the price with a SBT90.2 it surely will Thumbs Up
Tom E
Tom E's picture
Wonder what the flux bin is. Here is the chart from the SBT90.2 datasheet below. I'm trying to order 3 pieces of just the LED mounted on a 20mm MCPCB but all they had was flux bins RB and SA, so I'm ordering the SA bins, but there 5 higher bins listed:
Th558
Th558's picture
The last bin is crazy! Wonder which one is being used in this light. Btw where did u even find this datasheet…Mars? Pluto?
Tom E
Tom E's picture
Th558 wrote:
The last bin is crazy! Wonder which one is being used in this light. Btw where did u even find this datasheet...Mars? Pluto?
smile I asked Wendy and she emailed it to me -- will post a link to it on my google drive share...
try this for the SBT90.2 datasheet. let me know if it works or not for you.
Agree - would be great to know the bin they are using in this light.
SKV89
I wonder if there’s any chance for a group buy to get the top bins. Perhaps we can chip in with some light manufacturers or sellers like KD, L4P, MTN, Emisar.
Tom E
Tom E's picture
I'm think'n the higher bins might not exist yet. CREE would do the same thing - all bins/tints listed would no be available, but for CREE now, they are mostly at the high end of the bin range anyways, sometimes higher than the datasheets define. It's all a matter of what they can produce, and what the distributors/resellers carry. Maybe the high bins exist but are twice the price - who knows...
Agro
Agro's picture
Last seen: 6 hours 14 min ago
Tom E wrote:
Wonder what the flux bin is. Here is the chart from the SBT90.2 datasheet below. I’m trying to order 3 pieces of just the LED mounted on a 20mm MCPCB but all they had was flux bins RB and SA, so I’m ordering the SA bins, but there 5 higher bins listed:
Thanks a lot for that datasheet!
Some notes:
  • this LED has seriously low Vf. About 3.35V at 20A.
  • ~100 lm/W at 9A (the binning current), but cold binned.
  • About 5300 lm at 22.5A compared to CFT-90 4800 lm (sourced from CFT-90 datasheet, not from test). And it has lower Vf, so it’s clearly more efficient.
This may not scale to extreme currents like CFT-90 but nevertheless thanks to not-so-terrible efficiency it may be the new king of big throwers. Grad
jonxxn
jonxxn's picture
Last seen: 6 hours 50 min ago
Interested for 2nd batch
ver_ivanz007
also interested for 2nd batch
  • My current lights: Astrolux MF01 - Astrolux S43 - Astrolux FT03 - Convoy L6 - Nitecore MH20 - Nitecore TIP - Nitecore TUP - Convoy M3 - Convoy C8+ - Astrolux C8 - Astrolux MF01 Mini - Full Copper - Acebeam K30GT SBT90.2 - Massdrop tool AAA Copper and Brass - Nitecore Tip2
M4D M4X
M4D M4X's picture
please send me a PM - easier for me to answer asap
atsteele
Anyone have any info in the rear clicky specs? Dimensions etc? Looking to put in a reverse clicky
Th558
Th558's picture
Someone correct me if I’m wrong but I think it already has a reserve clicky.
atsteele
Sorry. Want a forward CLICKY.
Tom E
Tom E's picture
Listing says:  Swtich:  20mm,10A reverse switch
typos and all... smile
Ohhh - fwd switch.
Th558
Th558's picture
10A switch with a 20A LED. Something isn’t right here. Maybe they used a different switch for this one.
djozz
djozz's picture
The little Onten 1288 switch is rated at 1A (30V) and is used in flashlights up to 15A sometimes. Specs are not as simple as they sound.
atsteele
So what should I buy for this host ?
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 58 min ago
I use these KAN-9 10amp FWD click switches 20-30amps with 18awg bypass…no problem…
. https://www.aliexpress.com/item/KAN-9-Latching-switch-2fee-3A-6A-10A-Fla...
KB1428 “Live Life WOT
blueb8llz
Would have been cool if they gave us option to choose forward clicky. Would be cool if it was a standard thing to offer both from all companies.
