NiMH charger for my father
16 posts / 0 new
Winston81
Last seen: 3 hours 4 min ago
Any suggestions for a good, simple and safe NiMH charger for my dad?
At least 4 bays, reverse polarity protection, non rechargeable or bad cell detection, stop when the battery is full…
Thanks in advance
Oscar
ggf31416
Last seen: 8 hours 20 min ago
You can buy 4 Eneloops and get the bundled charger almost for free. It’s somewhat slow but it uses a better algorithm than many of the multi-chemestry chargers.
I’m not sure if detecting non rechargeable cells is possible at all.
Unheard
Last seen: 10 hours 1 min ago
Dlyfull D1, fast & reliable.
Probably needs translation: https://www.taschenlampen-forum.de/threads/dlyfull-d1-smart-charger.71583/
Cosmodragoon
Last seen: 1 week 3 days ago
I’ll second the recommendation for the regular Eneloop charger. I’m not sure if there is a newer one but mine is model BQ-CC55. It has four slots and can charge 1-4 batteries from different charge levels simultaneously. It uses colored lights to indicate charging level. It can handle AA or AAA just fine. I’ve never tried putting one in upside down so I can’t comment on that. What I do know is that mine has worked reliably for over a year with well over thirty batteries in circulation, both regular white Eneloops and the black Eneloop Pros.
Big_Sam
Big_Sam's picture
Last seen: 10 hours 32 min ago
I like the Ikea charger as tested by HKJ https://lygte-info.dk/review/Review%20Charger%20Ikea%20Ladda%20YH-990BF%20UK.html
It has physical reverse insertion protection and charges quickly. The Ikea Ladda 2450 is a good cell as well.
https://www.ikea.com/gb/en/p/ladda-battery-charger-60241308/
Winston81
Thank you very much.
My dad had a charger and ¿nimh? batteries years ago, but… an old (now vintage) and bad charger, and bad batteries… now, when I talk with him about rechargeable batteries, he says: shit!!.
Now he doesn’t know where the charger is, and use alkaleaks.
So I have been looking for simple and better chargers and batteries (eneloop!) for him.
Even “LESS” simple. Panasonic eneloop chargers, Xtar VC4 (too slow?), Nitecore I4 or D4, Dlyfull T1 (new and no reviews), Powerex C9000 (non reverse polarity protection?)…
One option is the panasonic eneloop BQ-CC17.Is it better than the BQ-CC55? I think the BQ-CC55 is, “quick”?
About the Dlyfull D1, I have read the HKJ review…
“The charger works well for AA/AAA NiMH at 2000mAh or lower, but due to a time limit cannot full charge empty high capacity NiMH cells (if the cell is only partially discharged it will work fine). There is some trickle charge at around 40mA.”
Unheard, thanks, I will translate it.
About the ikea chargers, I will take a look at this.
Oscar
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 52 min ago
Yeah.
Old NiMH chargers used to absolutely destroy my NiMH cells, and I didn’t know that when I was younger, and neither did my father.
Anyway, a quality NiMH charger is very important when charging NiMH cells for the obvious reason stated above.
xxo
Last seen: 5 days 5 hours ago
I would go with the BQ-CC17. I had a quick charger (similar to the CC-55) kill off some old no-name NIMH’s cells that I had. I use the CC-17 more than any other charger and I have never had a problem – it’s slow but it treats cells very well. I only use the quick charger when I really need it, which is rare.
Winston81
Thanks!!!
Oscar
Cosmodragoon
I’ve used the BQ-CC55 for over a year now. It charges quickly. I haven’t noticed any real changes in performance, but I do have a ton of Eneloops in circulation. Will this charger really hurt name-brand Eneloop or Eneloop Pro batteries? Will the BQ-CC17 really be that much better for the long term function of these batteries?
Cereal_killer
Cereal_killer's picture
Last seen: 37 min 45 sec ago
I use an iq-328 for my NiMH needs, hasn’t let me down yet and it’s going on like 5-6 years now.
It works much better than any of my multi-chemistry chargers, hits termination spot on 100% of the time, selectable charge rate, analizer and refresh function…
I’m always buying the newest / best li ion charger, never once felt the need to “upgrade” the iq-328
Winston81
Thank you very much for the advice. Thumbs Up Thumbs Up Thumbs Up
Oscar
Lightbringer
Lightbringer's picture
Last seen: 52 min 6 sec ago
Hey, howbow one of those Tenavolt setups? 4 cells, each cell has a Li cell inside with protection/charging circuit.
Vipon and Slickdeals had coupons for them, SD very recently.
http://budgetlightforum.com/comment/1571000#comment-1571000
Prime’s unnecessary, as I ordered a set no problem.
Winston81
Tenavolts? I have read about them.
Thanks
Oscar
flydiver
Last seen: 6 hours 43 min ago
Tenavolts (on special @ $11-12) are actually pretty decent. Simple charger, that is easy to use (unless you KNOW what you are doing use only their charger). Cells seem well made and work well. I’ve ended up with 12 of ‘em, and I have dozens of NiMh.
Lightbringer
Same here. Facepalm
