BLF Lantern Purchase/Followup Information - Group Buy list is Closed!!!!
319 posts / 0 new
djozz
djozz's picture
Last seen: 1 hour 38 min ago
hoodninja wrote:
Hi,
I havnt received a pm with a code.
I’m number 2048 on the interest list, am I still meant to be waiting on a code or has something gone wrong?
Regards,
Daniel
Nothing has gone wrong. Only 500 lanterns have been produced sofar, and less than 500 codes have been send out sofar. When new lanterns have been produced, more codes will be sent out, until all people on the list have bought their lanterns.
hoodninja
Last seen: 11 months 4 days ago
Thanks for the info mate Smile
b1i1l1l1y1
Last seen: 1 month 2 days ago
Let me get this straight. So if we didn’t come to this thread and sign up again (despite already being on the interest list) we’ve missed the group buy? If so, that’s very disappointing for people who don’t follow all these threads closely and were waiting for a PM as promised.
Mr.Scott
Last seen: 1 month 1 week ago
Nope. The other thread was for sign-up (and design, and status updates). This thread, as I understand it, is for questions / issues after you receive your light.
b1i1l1l1y1
Ahh, thanks for the update. Haven’t been following the threads in a while and was worried the group by was already done and gone. (that’s what I get doing late night browsing)
DBSAR
DBSAR's picture
Last seen: 3 days 15 hours ago
Don’t worry, if your name is on that list in the first OP thread of the main BLF LT1 lantern topic, then a code will be sent to you, just need patience and will take time as Sofirn is doing them in batches of 500 units at a time. They are working on to finish up the first 500 batch now, then they will be starting with the next batch ( and next 500 on the list.)
RobertB
RobertB's picture
Last seen: 3 hours 12 min ago
Ordered mine on Amazon on Oct. 10th. Arrived today in good shape. 22days.
A couple questions. Are these soldered on the correct spaces?
Also, can the top cap be swiveled so the bail is horizontal to the button? (Turned counter clockwise in this pict)
goshdogit
goshdogit's picture
Last seen: 4 min 30 sec ago
I don’t have an LT1 yet, but it seems you could loosen the top bolt, rotate the cap, and re-tighten the bolt.
I figure the only issue would be twisting of the LED wires, but I’d hope there’s enough slack for a bit of rotation.
Let us know if it works!
atobe
Last seen: 15 hours 31 min ago
Robert has OCD like me, but I wasn’t able to turn the cap. There seems to be a grove it goes into and it won’t sit any other way. Maybe I’m afraid I’m going to break something. If someone else has tried it please report back.
ᕦ(ò_óˇ)ᕤ I can always be wrong, probably 75% of the time.
RobertB
RobertB's picture
I don’t have OCD, but I would like the button to face out when I hang it on my camp kitchen hook.
fluke
Last seen: 1 day 8 hours ago
I asked elsewhere, what is the trim pot for.?
MtnDon
MtnDon's picture
Last seen: 2 hours 17 min ago
Turn the camp kitchen hook???
RobertB
RobertB's picture
Can’t do that. It’s on a bar. You can see this red Fenix lantern hanging from it. On another note, I do wish this lantern had a red light mode. The red light is great for not attracting bugs. I like leaving the red on all night in case someone has to get up.
jigsaw
jigsaw's picture
Very good idea. Maybe a red shade can be developed later.
RobertB
RobertB's picture
A red shade would work, as long as no white light was leaking out. I made the mistake of leaving a Fenix lantern turned on lowest white mode sitting on the camp kitchen all night. The counter tops were caked with dead bugs in the morning.
SIGShooter
SIGShooter's picture
Last seen: 2 hours 25 min ago
Yes the pads are correctly solder; 6/7 are supposed to come unbridged and you can bridge them if you want more output (at the cost of run-time and heat of course). It’s nice to see that 6/7 have no solder on them since some of the early ones were incorrectly bridged by Sofirn. The charge pad is also correctly bridge to give you the higher charge rate.
My LT also has the bail in the same position relative to the button so I assume that’s the way they designed it (and that’s too bad Sad ).
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
DBSAR
DBSAR's picture
Ok if you want to align up the bail-handle to a 90 degree or parallel to the switch , you will need to remove the top center bolt, then carfuly lift up the head a little, ( there will be some resistance due to the three wire leads soldered to the head LED plate. It can lift up roughly 1/4 to 1/2 an inch.) in the center you can see two centering square pins on the center of the acrylic shade post. (these pins fit & lock into two corresponding slots in the LED MCPCB) They are there to prevent accidental turning of the head to much that it twists the lead wires off the MCPCB. You can either carefully clip or file those two pins, then you can re-align the head and tighten the center bolt. (do not over tighten that bolt! as you may crack or damage the lens/shade, just snug it down to keep everything in place firmly. Be careful of the upper shade O-ring and that it stays in place.
RobertB
RobertB's picture
Great Den, thanks. I will check that out (carefully)…
edit…
I just tried that and couldn’t get the top cap to lift off high enough. At least, I wasn’t comfortable pulling on it too much. Going to leave well enough alone, and find a half twist carabiner.
goshdogit
goshdogit's picture
DBSAR wrote:
…if you want to align up the bail-handle…
Thanks for the info, Den! Thumbs Up
I don’t have an LT1 yet, but I can sorta visualize what you’re describing.
If anyone performs this alignment, please post some photos of the process.
DBSAR
DBSAR's picture
Maybe i can do a quick how to video for those wanting to clip the pins & align the bail handle, and the easy way to get the o-ring back in place. (as that is tricky too. Party
RobertB
RobertB's picture
That would be cool if you could do a quick vid
amishbill
amishbill's picture
DBSAR wrote:
Ok if you want to align up the bail-handle to a 90 degree or parallel to the switch , …..
Or, a small carabiner, clip-ring or split-ring would have the same effect – the only cost would be the lantern hanging an inch or two lower and the price of a cheap carabiner.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
RobertB
RobertB's picture
amishbill wrote:
DBSAR wrote:
… Ok if you want to align up the bail-handle to a 90 degree or parallel to the switch , …..
It’s off 45º. So adding a clip ring would just put it off 45º the other direction, as you can see in my picture.
DBSAR
DBSAR's picture
I will after next week do a video. Thumbs Up
amishbill
amishbill's picture
Ahhh… that makes if a little more interesting.
Have you seen the strange shapes you can bend an S hook into with a pair or two of pliers? For about $0.40 (zinc coated) to $1.50 (stainless) each you can make as many 45 degree twisted custom S hooks as you like.
I’m not going to argue that having the hook aligned like that is a touch weird… but there are answers that don’t involve breaking off the anti-twist protective tabs. Heck – I’m wondering if there’s enough slack in the bail to twist the tip without messing up the rest of its geometry.
RobertB
RobertB's picture
Bending s-hooks would work well. It’s really not that big of a deal, and certainly won’t effect my usage of the lantern. But if it can be adjusted easily, then I’ll do it.
d_t_a
Last seen: 4 hours 33 min ago
Yours look good. On mine (and I notice on some of the batch 1), the “6” & “7” have solders on them but were unsoldered (but still leaving solder residue)..
!{width:50%}https://i.imgur.com/5vxUvcG.jpg!
Have the same question, is this by design?
MtnDon
MtnDon's picture
You need a swivel device. I’ve seen some just can’t recall the exact name. Set it at the position you want then wrap the swivel with some clear silicone tape to fix the position. ???
djozz
djozz's picture
There is enough slag in the wires going to the MCPCB, but the wires are twisted in the driver cavity so you can not pull them upwards from above. You can unscrew the driver, untwist the wire bundel and then tighten the driver again. Then the top can be be lifted much higher and everything is in reach.
JakeDjanitor
Anyone know? Where is this trim pot?
