BLF Lantern Purchase/Followup Information - Group Buy list is Closed!!!!
319 posts / 0 new
spinynorman
Last seen: 6 months 4 days ago
JakeDjanitor wrote:
fluke wrote:
I asked elsewhere, what is the trim pot for.?
Anyone know? Where is this trim pot?
Check the other LT1 thread, the two have sort of crossed.
sbslider
sbslider's picture
Last seen: 2 days 17 hours ago
It is visible on the battery side of the driver. This post and a few before discuss it in a bit more detail.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
JakeDjanitor
Thanks guys
sbslider
sbslider's picture
JakeDjanitor wrote:
Thanks guys
Thumbs Up
xevious
xevious's picture
Last seen: 13 hours 41 min ago
I was waiting to get a PM with my GB code. I never got one. This whole GB process was very confusing & it seems many people were able to “jump the line.” And now the 3,000 units allocated for the GB is closed? I saw that the auction listing for the version with batteries still had some inventory so I submitted an offer for it, but not hopeful… Angry
Sherbona
Last seen: 4 hours 58 min ago
See here
RobertB
RobertB's picture
Last seen: 7 hours 29 min ago
Success getting the bale lined up with the button. djozz had it right. Take the screws off the driver and un-twist the wires. Pull the bolt off the top and lift. With plenty of room, you see the two tabs DBSAR was talking about. It’s soft plastic. I just grabbed the tabs with pliers, snapped them off, then cut the left over tab with a sharp knife.
As DBSAR mentioned, the o-ring was a bit tricky to get back on. I rolled the o-ring down onto the shade, then slowly rolled it back up to seat on the top of the shade. Lined up the top cap and replaced the bolt.
Putting the driver back in, take a sharpie marker, and mark where the charging port is, so you can line it up. Twist the wires back up, line up the charge port, and put the screws back in.
Driver off, un-twist the wires
Pull up on top cap, and snip off the plastic tabs on the center post
Mark the charging port with a marker, twist the wires back, and install screws
Done
sbslider
sbslider's picture
The first step by step LT1 mod!! Of course, DBSAR gets some of the credit here. Thanks for the pictures, i can see doing this soon.
RobertB
RobertB's picture
DBSAR and djozz both get the credit ! Just remember, if and when you change the batteries, to grab the head around where the button is to unscrew the battery tube. If you grab it by the top cap, you risk twisting it since the stopper tabs are no longer there.
sbslider
sbslider's picture
I guess the diffuser is epoxied or some how else attached to the base for protect against water intrusion? Else it seems like one could just rotate the diffuser/top to line up the bail with the switch, and not have to cut the tabs. Not really sure the tabs are needed, but perhaps are part of the normal production assembly process.
RobertB
RobertB's picture
I should have looked at how the diffuser was attached, but didn’t. I believe it is screwed into the base and an o-ring between the bottom of the diffuser and the body. I can definitely see why they put those tabs in there, to keep from rotating the top cap where the MCPCB is attached, thus, preventing further twisting of the wires.
atobe
Last seen: 16 hours 51 min ago
The base of the diffuser has 3 screws that holds it to the base. I was thinking of trying to turn it that instead. I just cut the tabs and was able to turn it so it matches with the button. Added some loctite to the bolt but it probbly won’t back out on it’s own anyways.
ᕦ(ò_óˇ)ᕤ I can always be wrong, probably 75% of the time.
sbslider
sbslider's picture
I completed the mod, took about 20 minutes? Would have been quicker but I added a twist, not really sure if/how much of a difference this makes. I put aluminum foil over the center diffuser post. Figure whatever light might have gotten absorbed there is now reflected. Hard to say if its any brighter or not, but it can’t hurt. The foil extends from the base to about 1/4” of the top, just cause that’s how my cut ended up. It would be interesting to compare this LT1 with another now.
Think that’s my first flashlight mod. Smile
Camo5
Camo5's picture
Last seen: 3 weeks 4 days ago
Ha, I asked about this exact mod being part of a potential future production run or if it will be a one-off thing. Though looking at how the lantern functions, it’s probably only a few lumens different.
RollerBoySE
RollerBoySE's picture
Just a small warning: the protective tabs on the bottom of the 18650 cells shipped from Sofirn can leave glue after them. Noticed that when I popped them into a charger and one of the cells didn’t charge correctly until I cleaned the bottom connection properly.
sbslider
sbslider's picture
Even with an angled reflector I describe in this post, the lumen output change was barely noticeable at the lower levels. Not noticeable enough to make me think posting pictures was worthwhile.
RollerBoySE
Ran a capacity test on the 18650:s from Sofirn that came with the LT1 on my Opus and they deliver: 2951, 2952, 2985 and 2985 mAh.
oto
oto's picture
Last seen: 3 days 4 hours ago
3121, 3113, 3067, 3054 here.
dmsoule
Last seen: 2 hours 39 min ago
Received mine yesterday, very pleased to learn that standard Sanyo GA cells work fine, no button tops needed.
Beautiful work, DBSAR! Also, ToyKeeper, Lexel, Del, Sofirn, and many others!
Geronimo
Last seen: 3 weeks 2 days ago
Just a heads up, mine was ordered on 10/12 , shipped via speedpak. So far speedpak with USPS sucks.went from DC to NJ , then to Indiana and next Kentucky. I am in Ohio . The updates for tracking happen seemingly the next day after it moves. It’s finally in Ohio. Should have it today or tomorrow. Again thanks for the team that made this.
Emisar d1s 3a. ZL sc700d,sc64w hi,H600c,Streamlight tlr1-hl, Astrolux mfo1s 4k/purple. Olight I3t Eos black. Ylp 2m cri.
DavidEF
DavidEF's picture
Last seen: 8 hours 33 min ago
I just had a chance to try out my first LT1. It will be a gift, so I didn’t really do a complete run-down. But it seems to work fine, and the candle flicker mode looks realistic. I didn’t find any manufacturing defects. It’s a very nice light. I left positive feedback for Sofirn in eBay, as they requested. Big Smile
- The YKK Philosophy
MtnDon
MtnDon's picture
Last seen: 25 min 20 sec ago
My LT1 has a problem.
After charging I found the USB port flap had come off. I am not rough with my lights. I have 3 Wubens that I have used more than the LT1 and never had a problem. I have a Nitecore several years old that has never had a problem. Not to mention a couple of phones with port flaps that have been used for 5 years or more and have the original flaps. Anyhow I thought I would mention it. I’ve sent a PM to Sofirn and to Barry. Here’s a photo.
DBSAR
DBSAR's picture
ouch, did it just pop out or did the tab break?
amishbill
amishbill's picture
I’ve had the same problems with the SP36. At least the LT1 driver comes out easily so pulling a new tab through the hole isn’t a big deal.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
SIGShooter
SIGShooter's picture
Last seen: 5 hours 22 min ago
I thought the USB port flap coming out was a definite possibility when I got my LT. Hopefully Sofirn will make them available for sale when they inevitability get lost.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
amishbill
amishbill's picture
I need to order a half dozen or so SP36 versions. I might as well add a few of these to the list too.
MtnDon
MtnDon's picture
The round stem that goes through the hole of the head body snapped. It appears to have broken off where I expect there is/was a larger ball or whatever, that is on the inside of the head to retain the opened flap. I simply pulled the little tab to open the flap and folded up to insert the USB plug and it came off in my fingers. Totally unexpected because, as mentioned, I have had good luck/experiences with port cover flaps on other lights and devices.
I hope they can at least send me a few, not just one and that it is not too difficult to insert.
sbslider
sbslider's picture
I took a look inside my LT1, the rubber piece has a long . . .
nah, this needs a picture.
It looks like a replacement would feed through the body and one could grab the piece before the retention piece has to squeeze through the body. Likely a little isopropyl alcohol would help with the job also.
MtnDon
MtnDon's picture
It looks like it broke right where the widened portion is. With length like that it should be easy enough to pull through. Thanks for the photo
I was about to forward this light to a relative in CA, but they are definitely not going to be able to install a new one themselves. So I’ll delay the sending I guess.
sbslider
sbslider's picture
My pleasure. Smile
