550kcd+ Emisar D1Sv2 coming this month!
53 posts / 0 new
SKV89
Last seen: 29 min 50 sec ago
contactcr wrote:
Needs a fixed aspheric lens option! How cool would that be
Fixed aspheric with RLT/wavien collar. 1.5MCD. That would be sweet! I wonder if someone is going to do that mod.
goshdogit
goshdogit's picture
Last seen: 1 hour 18 min ago
ToyKeeper wrote:
I added tail-clicky support two years ago. Most UI functions are on a side e-switch, and the tail provides momentary activation at the last-ramped level. It works fine, from what I’ve heard, and does exactly what people usually want the tail switch to do in a thrower.
Indeed it does! I flashed Andúril onto my modded EagleEye X6R as soon as you added dual-switch support.
It’s still my favorite pocketable thrower because of the dual switches and how Andúril works with them. Thumbs Up
I would love a tail switch on my D1S but haven’t found a tailcap with matching threads.
TK, please let Hank know how well Andúril works with two switches. Wink
justanotherguy
Last seen: 3 hours 7 min ago
hasddie293 wrote:
Is there anyone can translate 550kcd equal to distance in meters or km…?
Awesome news. I always look osram led beam in youtube. Beam look very2 intense…
I am sitting on a modded GT mini by Vin.
600 lumen or something, 300 kcd.. the throw is most impressive for a light this size.
I guess I am getting this new light, or maybe see if Vin can up it to 600-650 kcd…
truly wonderful times
mrheosuper
SBT90G2 is an expensive led, so it’s understandable he won’t make it an option
and more over, using that LED only make it brighter, not thrower, which is not the target of emisar d1s
Forgot my pen
Yokiamy
Yokiamy's picture
Last seen: 8 hours 44 min ago
I don’t see why the SBT90G2 is hyped that much, just because it’s a new LED ?
Everything is a matter of finding the right combination of host, driver and emitter, just like Hank does with this updated D1sV2 which should be really good according all specifications.
deleted-200707
begs a 21700 body
Yokiamy
Yokiamy's picture
chinooker wrote:
begs a 21700 body
Buy this one and transplant the internals into a Convoy L21A host, which has a 10 mm larger reflector and a 21700 tube.
Edit, my bad Facepalm
I thought i was posting in the nightwatch NI40 thread
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 27 min ago
Well if you all are going to cream and dream…LEP with Fixed aspheric with RLT/wavien collar (wonder if Vinh can do this?) for under a $1,000.00 dollars…
KB1428 “Live Life WOT
This is beginni...
Last seen: 1 month 4 weeks ago
Any idea on what the pricing will be?
Flashlights is neat.
funkychateau
funkychateau's picture
Last seen: 1 year 1 week ago
ToyKeeper wrote:
mrheosuper wrote:
0.5 or 1 lux is more pratical, 0.25 lux is barely visible in most cases
This is true, but the standard specs use 0.25 lux. So people stick with that, to make numbers comparable across the entire industry.
Tubercle wrote:
Gonna be a pencil beam.
Yes, it will probably be the pencil-est of pencil beams. At 550 kcd and maybe 800 to 1000 lumens, that’s 550 to 687 cd/lm. So the beam will probably be even tighter than the BLF GT. It has slightly more cd/lm and the reflector is smaller, so we can expect this one to perform extremely well at a distance but won’t really be useful up close.
Basically, it’s optimized specifically to be as “pencil beam” as possible.
Sounds like it might be a good option for a rifle-mounted shooting light, assuming it has stiff springs at both ends of the battery to prevent recoil disconnect. I’m definitely interested.
SKV89
Something that complicated with LEP and RLT collar will require a manufacturer like Microfire or Acebeam to do. I do wish someone will make one in the future. Probably can get 3+ MCD in a light of this size.
contactcr
Last seen: 5 hours 43 min ago
It’s probably too late to consider aspheric for this but maybe some small changes could allow a fixed aspheric version. Here’s hoping because there is very few new lights in this market and the “mid to large” reflector market is beginning to get saturated with cheaper lights.
Th558
Th558's picture
Last seen: 12 min 23 sec ago
Well it out throws an XHP35 HI whilst putting out over double the lumens. It might seem expensive but in a 70mm light it should perform about as good as a TN40 v2 whilst being much smaller and cheaper. The only alternative I can see to the SBT90G2 is 4 2mm White flats.
Agro
Agro's picture
Last seen: 1 min 22 sec ago
djozz wrote:
mbp wrote:
Do they make those Osram LEDs in anything but 6500k? I don’t know that I’ve ever seen any neutral or warm tints but I’m not very experienced with the emitter.
There are a few tint bins but the range is limited, I think 5400K is the lowest. Kaidomain managed to source a batch of the lower CCT tint-bins for the PM1 White Flat version (2mm2). link
Unfortunately according to Vinh they are actually not 5400 but about 6500. Sad
justanotherguy
tick tock
what would a W1 version likely cost?
brenden23
Last seen: 9 months 3 weeks ago
Can’t wait!
Any idea on colors? Surely he has to make cyan an option right?
deleted-200707
Nope…He needs to finish what he started with the smooth green. I NEED a smooth green to finish my set! Angry
justanotherguy
I asked about this light…
“We are still working on it, it will still take some time before releasing.”
A bit vague… But I want it soon!
Th558
Th558's picture
justanotherguy wrote:
tick tock
My guess would be $60-$65 but he hasn’t mentioned any prices yet. Could be more or could be less.
CarpentryHero
CarpentryHero's picture
Last seen: 13 hours 11 min ago
Bump, any news ?
I’m glad I’m not the only flashlight collector out there, I was beginning to think I was strange.
My name is Kendall and I’m a Flashaholic from western Canada
justanotherguy
nope
hoping for november now
justanotherguy
