This forum has a small problem of what frequent mobile users like me are well aware of. Let me a brief description: threads/posts and its contents are drawn inside boxes whose width is less than screen width pixels. When inserting images, by default the forum does nothing to give images proper size format. This means careless and/or unaware users can (and often) break the forum page layout when inserting big images (which nowadays are common).
For this reason, to properly insert an image without breaking the page layout always use the relative width option.
The relative width option is worthwhile being used if you like:
Simple Post Editor users: insert the percentage value image width in the (OPTIONAL) Relative Width (%): section in the Insert Image box.
Advanced Post Editor users: insert the percentage value figure along with the % character behind it in the horizontal Dimensions attribute input box, and clear the vertical box.
Suffice to say larger than 100 points figures will “break the box”, therefore avoid such numbers. ;-)
Thanks.
P.S.: this thread has been created to be appended to my signature.
LoL behave yourself, that is food for some hoax. Or to kick out people from a thread…
Let's make a ;-) test. Test done, 594% was enough. At 595% and up I was forced to scroll the screen sideways to see all content in a 1920 pixel wide screen device (smartphone/tablet in landscape).
Looks like it has some sort of limit. Will take a screenshot or two, and come back.
I see raccoon, just had to fiddle with it for it to look good in your quote. I briefly observed this while pming with sb56637, happens on the Avanced Post Editor. Will report to him looks like an easy fix: empty the vertical dimension box/variable for it to always get properly resized on par with the horizontal, keeping aspect ratio. Improving :-)) the forum.
That’s correct raccoon* and *Barkuti, I never recommend specifying a height dimension. Just the relative width percentage is enough. (And in cases where the user forgets to specify the width, the forum style should now limit the width automatically to 100% maximum.)
Where you can still cheat is with tables, you can take comfort in throwing off the page alignment for everybody by manually specifying a super-wide table. :innocent:
You never dared to try some nasty figure, raccoon city? :-D I once did a 600+% here, the thread turned out really nasty looking I swear. It could have served as a shenanigan by a troll, forcing moderator intervention.
All that remains now is to unify the forum post editor. I am used to syntax reconstructing quotes made with the Simple Post Editor, it's a hardship which goes both ways (Advanced to Simple too). People wouldn't flee, at most they'd complain for a few days while re-learning and getting used to the new editor, wonderful time for a lot of jokes.
