Test/review of Keeppower INR21700 3000mAh NM2130 (Black) 2019
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 28 min ago
DSC_6878
Official specifications:
  • Capacity min.: 2900mAh
  • Capacity typ.: 3000mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20+/-0.05V
  • Standard discharge cut-off voltage: 2.50V
  • Standard charge current: 1500mA
  • Charge termination current: 150mA
  • Max. continuous discharge current: 35A
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-info
This is a high current 21700 battery with fairly low capacity for its size.
DSC_6877
DSC_6879 DSC_6880
DSC_6881
DSC_6882
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Capacity
This discharge curves matches very fine and capacity is basically the same at any current.
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Temp-20.0
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Temp-30.0
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-CapacityTimeHours
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Energy
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-PowerLoadTime
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-TripCurrent
Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Charge
Keeppower%20INR21700%203000mAh%20NM2130%20%28Black%29%202019-Pulse-1A-10-10-2.5V-IR
Conclusion
This is good battery when needing high current.
Notes and links
The battery was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 5 hours 52 min ago
Thanks HKJ!
d_t_a
Last seen: 23 hours 1 min ago
Any idea if this might be a rewrapped Samsung 30T or some other 3000mAh 21700 battery?
I can’t seem to find this battery yet in the battery comparator to try to match discharge curves of other known 3000mAh 21700 batteries..
