Hey team, I’m looking for a light for airsoft.
I already have a C8 that I tried upgrading to a XHP50.2 but realized after reading some more posts on here that it’s not going to give me the best throw.
Also I mostly destoryed it in the process.
So im looking for an out of the box, or with minor mods, flashlight that is:
- C8 (or close to) form factor that is as throwy as possible
- fits a pressure switch
- firmware can be put in off / 100% mode - or some other mode that will work with airsoft/pressure switch
From what i’ve read a XPL-HI tends to give the best throw, so i’ve found a few on aliexpress and bangood
This one is probably the best so far: 18.97€ 19% OFF|Schwarz Convoy C8 + mit XPL HALLO LED, kupfer DTP bord und ar beschichtete innen, neue firmware|Taschenlampen| - AliExpress
XPL HI, AR coated lens and I think I could manage with that firmware aslong as I don’t manually strobe it too much after getting to mode 12
Are there any similar ones but with better suiting firmware?
