RD tech RD6006 60V/6A NEW power supply released
Hello, my friends
Sorry for your long waiting
Today we released our new power supply series- RD series
And for now, RD6006 and RD6006-W can be ordered. RD6006-W has extra WIFI board compared to RD6006 . RD6006-W can use WIFI board to connect RD6006 to APP/software, also use USB micro cable to connect PC software . RD6006 can only communicate with PC software by connecting USB micro cable, no phone APP.
It has been changed a lot compared to DPS/DP/DPH series
ORDER LINK
RD6006/RD6006-W Product link: https://www.aliexpress.com/item/4000282551930.html
And we design two cases(S06A and S06D) for it, here is the link:https://www.aliexpress.com/item/4000284522671.html
You can check the whole instruction here, it has more functions than what I said in this article:
https://drive.google.com/open?id=17V-JWHvqMF-NuWSznEiJ4RKrnn_Pkt5v
You can also see the operation video and case installation video published on our YouTube channel:
www.youtube.com/embed/fn6ROhGrLtI www.youtube.com/embed/unoZMH3fp8Q
PRICE
Price: as old rules, when the new products are published, we will set the lowest price
RD6006: 47.68 USD (normal price 55 USD), RD6006-W: 51.18 USD (normal price 60 USD)
S06A: 28.43 (normal price 33 USD), S06D: 18.81 (normal price 23 USD), Time is limit, please seize this chance.
CORE FUNCTIONS:
  • keypad + encoder potentiometer combination adjustment
  • 2.4 inch HD color screen
  • Battery charging special interface
  • Data quick storage & recall
  • New PC software
  • Wi-Fi connection, Phone APP control
  • Firmware upgrade
  • Boot logo upload
  • Two main page styles display
In this article, we introduce its main functions and operation, and you can check the product instruction on product detailed page for more functions.
At first, take a look at the appearance.
You can see it has bigger(2.4 inch) screen and keypad, and a green terminal is added to charge the battery
At main page, you can see output voltage, current and power displayed in big font, and it can show more information than DPS series screen. The main page defaults to classic display style and you can also choose curve style
It is quite easy to set output voltage/current/ OVP/OCP, just need to press the U-SET or I-SET button to set output voltage/current, press SHIFT+ U-SET or I-SET button to set the OVP and OCP value, you can use the keypad to enter the value directly. Press ENTER to confirm or encoder potentiometer to cancel.
If you need to charge a battery, please use the green terminal to connect the positive pole of battery,you can check the battery information on the screen.
Now it is easy to store/ call out a data group, you can press MEM+NUMBER+ENTER to store the data to corresponding data group, or press SHIFT+NUMBER+ENTER to call out a data group.
You can set the connection way , USB and WIFI is available now, if you want to use APP control, you need to set it to WIFI mode and reboot.
You can use PC software (Win7 or above) to control the RD6006, we design new UI, and it is much useful than before.
You can also use your Android phone(Android 5.0 or above) to control, but it needs WIFI module
GIFT FOR SPREAD
Hope this information can help you, if you help me spread the message(need to show that we publish RD6006, product link, discount information, with some picture of RD6006), there will be a gift when you make order, not send separately, just take a picture to show me.
1, spread on 1 or 2 different forum or social media, voltage meter as gift, worth about 1-3 USD
2, spread on 3 or 4 or 5 different forums or social medias, voltage converter as gift, worth about 3-6 USD(you can get this easily if you have twitter/Facebook/Instagram account)
3, spread on more than 6 different forums or social medias, AT34 as gift, worth about 9 USD
All gifts are random with corresponding value. Remember to take a picture show the result, I will give you the gift
Interesting. So the green terminal is specifically designed for battery charging purposes, but what makes it functionally different from the red terminal? Is the red terminal optionally set aside for voltage monitoring with 4-terminal battery holders in such case?
Nice device, congratulations. :THUMBS-UP:
P.S.: it would help if at least the first picture were to be resized, see my signature.
for green port ,we add many protection, for red, there is not protection for charging battery
it is different
Does the Wh counter also work if you use the normal positive (red) terminal? It could be handy to test power usage over time of the device under test. Or is there any reason not to use the protected green output in other than battery use?
Does the Wh counter also work if you use the normal positive (red) terminal? — yes, it can, but I still suggest you use the green, because it is special interface for charging the battery …
I often charge batteries with a standard CC/CV supply and 0 problems (I am the protection).
It would be helpful to provide a detailed explanation of what the green terminal does and does not.
of course , it can do that , it just remove some unnecessary function , and add some protection for charaging battery
so if you want to charge battery, please use green port
you consider to buy one ?
In this video, we show some data you want to see
we show battery charging operation and reverse connection first.
then we check the output voltage/current accuracy and output ripple. 100mV VPP
Finally we test the working temperature under full output(60V/6A)
room temperature 36.5℃, panel 62℃, AC-DC power supply 46℃.
RD6006:https://www.aliexpress.com/item/4000282551930.html
my email: 1749808860@qq.com welcome to contact
Now we test the ripple and charging , if there is any one want to see , please let me know , i will show that
customer DIY based on RD6006
Just recently, I want to make a workbench and need to buy some equipment, I like this big colorful screen. As I work overtime on National Day, I just want to give myself some compensation.
The delivery speed is also fast. It arrived in a few days. It has been there since I opened the box. I have no idea about how to do the shell.
There are two cases on the official website, but the small one I have no suitable battery and the big one, 31cm is too long for my desk
So I decided to make the case myself
I have a power source :GERM4815T 53.5v15a, good but it seems too large
and a friend give me advices, here is his plan, after I got it , I think it is not what I want!!
300w 48v, and use converter to 70V, suitable for RD6006 input, and I design the case
go to sleep, leave the 3D printer working
get up, still working
assembly
Painting the outer casing
after assembly, have a test, it can work
add a light strip
emmmm, seems out of fashion
make a new upper board and final apperance
looks cool maybe I should carve some patterns
I just ordered an RD-6006 + S06A + the recommended power supply.
I was planning to reuse a massive Astec 48V@4A + 18V@11A with a DPS 5020. I would have had to switch between the 48V and 18V inputs. The surplus case I was going to use is big, ugly and heavy. RD-6006 and matching case will a better fit for my work bench.
This used to charge the batteries in a patient monitoring trolley.
who have any question for our products ?
RD6006 accuracy test from customer
customer feedback about the accuracy of RD6006
customer feedback to show manu page and unique boot logo
www.youtube.com/embed/a_RqywcOPOE
RD6006 feedback:
use RD6006 to make a power supply, looks nice and performs well, waiting for higher current version
Does the RD6006 have low or high side current measurement shunt?
Does it cut negative or positive in off state?
if the green terminal has more protection, then when do you have to use red terminal ?
Hi friend
thank you very much for your message
let me answer your question one by one
1, we use low side current measurement shunt
2, positive
