RD tech RD6006 60V/6A NEW power supply released
82 posts / 0 new
Andrew_Debbie
Last seen: 12 hours 48 min ago
Burn in and quick calibration check. So far working very well.
First, make sure my inexpensive DMM is ok:
Next, a quick check of the RD6006.
I’ll do some more checks tomorrow.
RD tech
RD tech's picture
Last seen: 1 day 4 hours ago
if you want to reshape the case, you need a hammer to hit the curved place gently, the case material is soft. and waiting for your test, you can contact me if you have any questions when using it, and I cannot see the picture because I cannot access the picture link Facepalm
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
RD tech
RD tech's picture
RD6006 feedback:
[It came with neat RD6006 and case but I successfully made a  nest coolgood functions]
https://www.aliexpress.com/item/4000282551930.html
RD tech
RD tech's picture
very good work, you can continue to test, if there is any problem, please let me know
Andrew_Debbie
Load check and burn-in. All good so far. I like the user interface. It is easy to use. I set 3.3, 4.1 and 5V into memory 3,4 and 5.
I am going to let it run at low power for several hours. The fans don’t run at low power settings so the supply is silent.
Andrew_Debbie
RD tech wrote:
Quote:
I am ordering another case Smile
, and you can try to reshape the first case, so that you can get two
Do you have plans for more new products to fit the 160×74mm cut out?
I could use a better bench DMM. Mine is 3,999 count. I’d like 60,000 or better at a reasonable price.
RD tech
RD tech's picture
sorry, for this size, we have no plan now
RD tech
RD tech's picture
customer feedback
[In general, the product RD6006 turned out very cool, the control is done intuitively understandable, in 5/7 minutes you can completely understand it, collected qualitatively, does not overheat even when working on Max currents with low voltage(
compared to the previous power supply)]
RD tech
RD tech's picture
Load check and burn-in. All good so far. I like the user interface. It is easy to use. I set 3.3, 4.1 and 5V into memory 3,4 and 5. I am going to let it run at low power for several hours. The fans don’t run at low power settings so the supply is silent.
haha , you can continue to test
RD tech
RD tech's picture
customer review:
RD6006 power supply
[Fast delivery and great packaging. The housing is made to a good standard, all parts needed are included. The photos also show the packaging of the RD6006 itself which is obviously not included with this housing.]
Derosoft
Last seen: 3 months 2 days ago
This is a very interesting design. I am mostly interested in Constant Current mode and would like to know how fast does the circuit switches from Constant Voltage to Constant Current. In other words, what surge current must I expect on the output if I connect a sensitive circuit to it. Are there large capacitors directly connected to the output?
Thank you
Derosoft
RD tech
RD tech's picture
Thank you
Our output capacitor is two 330uF in parallel, our switching frequency is about 70kHz, so your sensitive circuit should absorb at least ΔU*C energy.
RD tech
RD tech's picture
customer review
RD6006 USB WiFi DC - DC Voltage current Step-down Power Supply
[excellent product!!! very well packaged(well packaged for rude delivery, we both don't want to see a broken device, it is a waste of time and money)]
RS6000
This is a very interesting item.
I’m mainly interested in the graphical monitoring of voltage and current like other more famous DMMs.
Very interesting software for PC …
Can you expect a version with 3.5 “or 4.2” LCD display ?
(I hope he will arrive soon)
and any improvement in voltage and current monitoring?
It works very well both in the laboratory and in the assembly line.
now I am testing one in my laboratory and 4 in assembly line …
Next day I post some other information about my experience with RD6006-W
RS6K
icpart
Last seen: 17 hours 43 min ago
Any news and specification about higher current version? I have biffy 1KVA transformer and like it made some PSU with that new RD6006. Can you tell me if that the higher current version will have the measure resolution like 1mA in RD6006?
Yokiamy
Yokiamy's picture
Last seen: 51 min 57 sec ago
Very professional looking power supply! If i have enough funds, i might order one.
Kroki
Looks nice and I plan to buy one, probably with different PS and box, but I don’t see anywhere on pictures the female green connector for input voltage: is it included with RD6006? or box? Do I need to buy it separately and if yes could you please provide its reference?
Also, as I plan to use a spare laptop PS which delivers about 21VDC, my understanding is that RD6006 will then be able to deliver only up to 20 V: is that correct?
Andrew_Debbie
The input connector and a temperature sensor come with the RD6006. There is also a fan on the back of the RD6006.
A CR1220 battery is required to back up the time and date. The battery is not included with the RD6006 or the case. The supply works without a battery but doesn’t remember the date or time.
The S06A case includes a 50mm case fan and power board for the fan.
Drop is specified as >10% and > 1V. The instructions say to set the input to 62V for 60V maximum output.
I guess you will get >19V and <20V.
Kroki
Thanks for this detailed answer Smile
RD tech
RD tech's picture
RS6K
Thank you so much for your message and your support
I am so happy that you like it
for big screen, there is not plan now , we are planing to make higher power for RD series
in fact, 2.4 inch , it is ok, for now
you can share your experience for RD6006W, If there is any problem, we can talk it here
RD tech
RD tech's picture
next version is 60v/12a,. But it will be after 6 month…
RD tech
RD tech's picture
very good, friend
I am so glad you like it , waiting for your order, and hope you can tell your more friends
RD tech
RD tech's picture
1, you said input connect ? yes, we have in the box
2, input voltage must be higher 1.1 times than output .. input 21V , the output max will be about 19V
RD tech
RD tech's picture
thank you so much for your answer , you used our products, it works well ?
RD tech
RD tech's picture
RD6006 customer feedback
[Very well packaged. Very good product. Recommend seller.]
RD tech
RD tech's picture
RD6006 customer feedback:
[Excellent. Received quickly. Impeccable packaging. Exceptional. Perceived quality excellent. Works perfectly. The quality of this product and really good compared to the price. I am very satisfied.]
RD tech
RD tech's picture
RD6006 feedback:
Everything is very fast and high quality.
RD tech
RD tech's picture
RD6006 feedback:
Very high quality appliance! Excellent packaging. I recommend. Thanks!
RD tech
RD tech's picture
RD6006 feedback:
Good product. I assembled it before PSU is arrived.
RD tech
RD tech's picture
RD6006 feedback
Fine! Packed - beyond praise! Everything works. The accuracy of the installations at altitude. I recommend products from this manufacturer. Not the first purchase already. One minor minus - there is no watch battery. but it is not essential
