I’m new to flashlights. I was wondering if someone could tell me what the differences between the Convoy S11 and S21A. Which one is better?
Many thanks!
Many thanks!
The Convoy S11 is a 26650 based host, 20mm MCPCB and 22mm Driver sizes
the Convoy S21A is 21700 based, 20mm MCPCB and 20mm Driver
That is about all the differences I can see, and on a personal note, I have built an S21A based EDC that works great for my personal use
I was wondering what batteries you use in your S21A? I was wondering if the LG M50 5000mAh fit?
I use both Samsung 40T and 50E, they be perfect fit in the S21A.
So long as you don’t use protected cells, or rewraps, you should be good.
Looked up your battery, bit low on the CDR at 7.3A for my tastes, still decent for the price and no protection circuitry to make it bigger than standard.
Definitely good to go!
I wasn’t aware of the Samsung 50E. I much prefer it to the LG and I’ll get some of those. Do you know if the S2+ holster will fit the S21A?
Many thanks.
I honestly cannot say for sure that it will fit, but could be possible since the S21A is only a few millimeters bigger in diameter.
Not a problem! Glad to help!
