Flashlight concept #1 - Multi-emitter light
41 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 hours 22 min ago
Update 07/08/2020:
Thank you so much for your valued feedback so far! Meanwhile, I tried some new design approach that is easier, hopefully less complex to design as well as simpler to operate UI-wise, beginning as of post #23.
Specs:
Target output max.
4.200lm white (mixed)
400lm red
Max. output could possibly be higher but efficiency should be more important?
Host design
21700 shape
magnetic rotation ring
mechanical tail switch
integrated USB-C port
stainless steel bezel
Non-AR coated glass
Head section to be designed as a new part (> 38mm)
Center section design adopted from Sofirn SD05 + IF25A
Tail section design adopted from Sofirn SP70
AR coating may "bend" the light's wavelength and cause additional tint shift
Optic
LEDiL TAMPA NIS83-MX-7-W
(wide beam, 35°, 38mm diameter)
This optic will probably be a good trade off regarding maximum beam distance and the avoidance of tint shift. A more frosted design might be even better tint-wise but it will become very floody.
Emitters
3x Samsung LH351D 4.000K 90CRI
3x Samsung LH351D 5.000K 90CRI
1x Luminus SST-20 DR (660nm)
The center LED could also be something else instead of red light. I chose red because SST-20 DR is rather easy to source and with up to 3A current more powerful than Cree's XP-E2 red/deep red. The downside of less perceived brightness with 660nm might be eradicated by more current resulting in a much more pleasing red color than standard red (625nm).
A thrower LED like Osram CSLNM1.TG/CSLPM1.TG would probably not work well underneath a wide angle beam optic. It would require to have an optic with different angles for each LED - I have not found something like that. A UV LED would not work either as this wavelength would not pass through plastic material.
Driver Fully regulated buck/boost driver That's wishful thinking, of course. But it will make this concept much more interesting. Driving 6 LEDs efficiently will (hopefully) result in a more useful and longer operation on higher modes than having short bursts of Turbo using FET/DD. However, such a driver will definitely increase the (development/material) costs of this light.
Power 1x 21700 flat top Inner tube diameter should be large enough to use off-standard 21700 cells like Molicel M50-A (more a "22700" cell)
User Interface
Magnetic rotation ring
Tail switch
Ring:
controls brightness only (stepless ramping from moonlight to high/turbo)
Switch:
controls ON/OFF (fully press) or mode selection between white and red light (tap to select)
switch design is yet to be defined - most people will probably prefer a reverse clicky over a forward clicky
** ORIGINAL OPENING POST **
Hello everyone,
I did some thinking on new flashlight concepts and mostly about those things we seem to miss in some good but not perfect flashlights, e.g. good thermal management, good heat transfer, efficient drivers, convenient user interface and interesting LED configurations. With Fireflies' E07 and ROT66 V2, Mateminco's MT07 and Sofirn's IF25 in mind I wrote down a rough concept. I would appreciate any feedback on this, especially if this is something reasonable and feasible in your opinion.
Edited by: Lux-Perpetua on 07/09/2020 - 02:50
Yokiamy
Yokiamy's picture
Last seen: 21 min 27 sec ago
I like the tint mix version!
Would it be possible to change the preferred tint by giving the preferred LED’s more or less current ?
djozz
djozz's picture
Last seen: 8 hours 26 min ago
In this size that copper head makes it really massive, not a light that I would carry with me. The tint-mixing version is nice, I think it is a pity that Sofirn went for their own tint-mixing version instead of Anduril.
Lux-Perpetua
Yokiamy wrote:
I like the tint mix version! Would it be possible to change the preferred tint by giving the preferred LED's more or less current ?
Yes, that's the plan. Adjusting the current for WW and NW LEDs will change the mixed tint.
That's a good point. Maybe they™ could use a press-fitted copper pill (like Nightwatch IRA) instead of a solid copper head and/or solder the MCPCB to the pill which should result in better thermal transfer. I wish LEDIL offered a partially wide beam frosted and partially clear narrow spot optic. This would give us a whole bunch of new ideas like 3 emitters for throw, 3 emitters for flood and a wide beam frosted auxiliary light in the middle (it does not necessarily need to be deep red Wink ).
Th558
Th558's picture
Last seen: 2 hours 19 min ago
For me an EDC light would have to have a head width of 35mm max. It can be a tiny bit more but depends on the head design. I think 7 LH531Ds might be too floody. Four would be better IMO.
Here’s some things I would like to see
Decent throw 25+ kcd for high cri version. More would be nice but the LH351Ds are domed so I don’t think it’s possible.
Tailstanding ability
Strike bezel so it’s harder to leave on by accident
Three selectable colour aux LEDs if there’s space (red, purple, orange)
Unheard
Last seen: 4 min 11 sec ago
Yes, two of them WW, one CW. That would compensate for the lesser efficiency of WW LEDs.
Lux, when to expect this true threedimensional (brightness, tint, beam) flashlight exactly? Crazy
Almost forgot: Add this CCD element to autoadjust WB Cool .
Lux-Perpetua
I just added the "USB-C port in thread section" feature. How could I've forgotten that? Big Smile
Agro
Agro's picture
Last seen: 4 days 5 hours ago
1.
Solid copper head is good for sustained performance but bad for turbo. It conducts heat away so well that it keeps the LED – and (what matters more) the LED surroundings much cooler than other materials would. Since they are much cooler they fail to store much heat.
For this reason solid copper lights tend to overheat faster than aluminum ones despite the fact that they weigh 3 times as much.
And thermal transfer improvement is marginal anyway.
2.
I really like 7-up optics because they make good use of the frontal area. Almost like 1-up…but unlike 1-up they are way flatter.
3.
I never use red lights, so for me the extra red LED would be a waste. Especially on a thrower. But if you like it – why not.
4.
Tint mixing – I’m a big fan of it
5.
Having a variant with 3535 LEDs and another with a mix of 3030 and 3535 would require 2 different MCPCBs. I’m not sure if that’s a big deal though.
6.
I think White Flat 1 mm² would make a better thrower choice. For ~45 mm head 12 mm² (let alone 14 mm²) is quite a lot. Very short turbo and actually quite floody beam. 7x KW CULNM1.TG (aka Boost HL) would truly rock.
7.
As usually with dual switch lights – I believe it’s worthwhile to give user a choice whether they want the tail clicky or just a flat cap.
8.
A Powerbank capability is a boon for any rechargable light with reasonable battery size
9.
A boost driver capable of driving 12 mm² White Flats? Not easy. Not compact. Not cheap. But doable.
Lexel
Lexel's picture
Last seen: 1 month 4 days ago
Agro wrote:
1.
4.
5.
6.
1. you are talking quite nonsense, just because Copper conducts 3 times better than Aluminum it will be completely even tending to be even cooler, why?
Just check a Cree XPL here at 3A
let’s assume LED runs 120°C on aluminum and 100°C on copper
- the amount of power with a regulated driver gets a bit higher as the LED voltage increases 0.04V*3A=0.12W more
- but also the photon conversion is more efficient almost 50 lumens more at 350lm=1W 49lm÷350lm/W= 0.14W
On an unregulated DD driver your observations are also not true, why?
With a lower temperature the LED voltage is higher so the light draws less current
copper lights may feel hotter as they heat up more evenly through the whole body
4. I think tint mixing is not so much-needed on a light
Also why is 351D 2700K so much less efficient?
5. I am sure such a MCPCB with both emitters can be made
I can see if that would also allow an aux board probably the positions of the main LED wires soldered is critical here to get a symetrical pattern
6. agreed
Agro
Agro's picture
Lexel wrote:
Agro wrote:
1.
4.
5.
6.
So…roughly 0.14-0.12 = 0.02W or 0.2% more, right?
Yes, more than 0.2% with FET.
Now the amount of heat stored is the integral of (temperature hike) * (volumetric specific heat) over volume.
Assuming constant surface temperature of 60C (that’s the moment when the light needs to step down) and ambient temperature of 25C.
Temperature difference between surface and near the led is inversely proportional to thermal conductivity.
With 100C for copper we would have ~160C for 6061 alu, regardless of head size shape etc. Yeah, that 100C is likely too large. I think 80C copper and 130C alu would be more like it, though I am not sure about it really.
This gives temperature hike over ambient of ~55C for copper and ~105C for alu. Adjusted for difference in volumetric specific heat (copper is better), with these parameters alu would store ~33% more heat near the LED. Now, near the surface it would be the opposite, both have the same temperature, alu stores about 31% less. But then the temperature at the hottest point of the surface is much smaller; heat storage near the LED is more important. At the cooler points of the surface the difference will be larger in favour of copper. But then – the amount of heat stored there is minimal.
In practice – through the whole head. And not much elsewhere. Facepalm
EDIT:
Wrong, 0.02W is not ~0.2% but more like 0.3% because energy consumed != energy dissipated as heat.
Lexel
Lexel's picture
1.
You do the math wrong, we already have a thick copper MCPCB which reduced the temperature difference between a copper or aluminum head
Ask any here in forums why we don’t want to use aluminum MCPCBs even if they are DTP, the heat conduction is absolutely critical to keep the LED temperature low
Nobody wants to store the heat near the LED, the cooler it runs the better its photon conversion is, so people asked manufactures for thicker shelves on the BLF lights to move the heat faster away and give more heat buffer
I have done several thermal imaging videos of aluminum heads, the heat from the hottest to the coldest spot is minimal as the conduction of heat is already very good on flashlights with a thick shelf and thick walls
2.
Your 0.2% on DD drivers is also wrong math
look on a Samsung 30Q battery for example and look how much 40mV voltage difference between a hot and cold LED result in current change
I did here the graphs between 5 and 7A and on average I would say about 40mV difference
so your 0.2% I don’t know how you calculate that number results in my calculation for 40% current change without any resistance added
so lets take bypassed springs and switch with 50mOhms and driver and LED leads also 50mOhms
40% change on 16mOhm of the 30Q cells, now lets do the math with all resistances I get 5.5% less current on DD light just by 20°C lower LED temperature
3.
I mean a 100% copper light with copper tube, most people touch a hot rod light only on the tube, the better it conducts heat the more the human heat sink plays a role
Lux-Perpetua
Lexel wrote:
Agro wrote:
1. Solid copper head is good for sustained performance but bad for turbo. It conducts heat away so well that it keeps the LED - and (what matters more) the LED surroundings much cooler than other materials would. Since they are much cooler they fail to store much heat. For this reason solid copper lights tend to overheat faster than aluminum ones despite the fact that they weigh 3 times as much. And thermal transfer improvement is marginal anyway. 4. Tint mixing - I'm a big fan of it 5. Having a variant with 3535 LEDs and another with a mix of 3030 and 3535 would require 2 different MCPCBs. I'm not sure if that's a big deal though. 6. I think White Flat 1 mm² would make a better thrower choice. For ~45 mm head 12 mm² (let alone 14 mm²) is quite a lot. Very short turbo and actually quite floody beam. 7x KW CULNM1.TG (aka Boost HL) would truly rock.
1. you are talking quite nonsense, just because Copper conducts 3 times better than Aluminum it will be completely even tending to be even cooler, why? Just check a Cree XPL "here":http://pct.cree.com/dt/index.html at 3A let's assume LED runs 120°C on aluminum and 100°C on copper - the amount of power with a regulated driver gets a bit higher as the LED voltage increases 0.04V*3A=0.12W more - but also the photon conversion is more efficient almost 50 lumens more at 350lm=1W 49lm÷350lm/W= 0.14W !{width:50%}http://www.metronixlaser.de/bilder/flashlight/XPL_3A.png! On an unregulated DD driver your observations are also not true, why? With a lower temperature the LED voltage is higher so the light draws less current copper lights may feel hotter as they heat up more evenly through the whole body 4. I think tint mixing is not so much-needed on a light Also why is 351D 2700K so much less efficient? 5. I am sure such a MCPCB with both emitters can be made I can see if that would also allow an aux board probably the positions of the main LED wires soldered is critical here to get a symetrical pattern 6. agreed
So, a press-fitted copper pill and/or soldered MCPCB could probably be more efficient in terms of weight, thermal conductivity and dissipation as well as being more cost-effective?
Using a full copper body would definitely increase both weight and cost dramatically. I was hoping to match the best of three worlds (Titanium for a sturdy bezel, Copper for best thermal transfer, Aluminum for best and fastest heat spreading/dissipation alongside the battery tube with the benefit of less weight).
The idea about tint mixing originates from Sofirn's IF25 and the LT1 lantern. Basically, I would like to enable every customer to choose his/her favorite tint between warmwhite and neutralwhite. We could also go up to 5.700K 90CRI - no big deal. There might be certain situations when people like using neutralwhite (outdoor in summer) but also want to change to warmwhite (outdoor in winter with highly reflective snow/iced surfaces or when inside) with the same flashlight. If tint-mix is not an option we could still mix LH351D 2.700K 90CRI with 5.700K 90CRI to get rid of any greenish tintshift and drive the mixed tint below the BBL resulting in a rosy tint pattern somewhere around 4.000K. Just thinking...
Why is 2.700K so much less efficient? Because most (all?) warmwhite emitters seem to have less efficiency than coldwhite emitters. I do not have accurate numbers for LH351D 2.700K 90CRI but I quickly translated the reduced output by the expected loss in efficiency. We may get a bit more output here but I wanted to keep the numbers conservatively calculated.
If multi-footprint MCPCBs are feasible, how about replacing the inner XP-E2 deep red by an Osram White Flat KW CSLNM1.TG 1mm²? This would give us a flashlight with both flood (6x LH351D) and throw (1x Osram White Flat 1mm²).
Lexel
Lexel's picture
Lux-Perpetua wrote:
So, a press-fitted copper pill and/or soldered MCPCB could probably be more efficient in terms of weight, thermal conduct and dissipation as well as being more cost-effective?
The idea about tint mixing originates from Sofirn’s IF25 and the LT1 lantern. Basically, I would like to enable every customer to choose his/her favorite tint between warmwhite and neutralwhite. We could also go up to 5.700K 90CRI – no big deal. There might be certain situations when people like using neutralwhite (outdoor in summer) but also want to change to warmwhite (outdoor in winter with highly reflective snow/iced surfaces or when inside) with the same flashlight. If tint-mix is not an option we could still mix LH351D 2.700K 90CRI with 5.700K 90CRI to get rid of any greenish tintshift and drive the mixed tint below the BBL resulting in a rosy tint pattern somewhere around 4.000K. Just thinking…
Looking on Digikey as a source for LH351Ds
I get 2700K CRI90 310 and 330LM binnings
for 5000K CRI90 390-410 binnings
so 4000lm for 5K
and 3200lm for 2.7K
Lexel
Lexel's picture
so 4000lm for 5K
and 3200lm for 2.7K
also why not simply compensate the lumens in the firmware to have on any color 3200lm just do the 5000K only on 80% max current?
Lux-Perpetua
Just to get it right: Do you mean a balanced output, i.e. the flashlight will always have let's say 3200 lumens output regardless of the tint's CCT?
Lexel
Lexel's picture
Lux-Perpetua wrote:
Just to get it right: Do you mean a balanced output, i.e. the flashlight will always have let’s say 3200 lumens output regardless of the tint color?
yes
you could then also make in the firmware an option to blast out Turbo with all LEDs and max current at about 4000K
Lux-Perpetua
Okay, I got you. Smile Good idea. Sofirn did not balance the output on the IF25 (yet). Effectively, not only in perception but also in actual numbers it is brighter on coldwhite than on warmwhite. They also did not implement the fancy feature of using all 4 LEDs on Turbo (yet). However, your ideas definitely belong to the wish list of the UI a perfect flashlight should have.
A revised draft concept...
id30209
id30209's picture
Last seen: 2 hours 30 min ago
Ehm...IN!!!!
WTB Titanium 4sevens 2xAA tube
amishbill
amishbill's picture
Last seen: 3 weeks 3 days ago
Hmmm… Tint ramp is not a huge thing for me, but then again, I’ve not used a light with tint ramp.
I like the idea of a separate red in the center. Sometimes you need a more gentle and nighttime friendly light. Then again, dropping what I assume is an Osram thrower in the middle defintely adds flexibility. The unicorn flood/throw combination light.
Size — I’m torn on this one. As a pocket light, even the 21700 might be a bit big for my tastes, let alone a 7 LED head. As a holster / shelf light, I like the feel of a 26650 tube, which might be a better size match for a 7 LED head. (reference – I have most recently used an FW3 and EDC18 as my pocket lights, and they are IMHO, on the edge of being to big for pocket EDC)
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
manithree
Last seen: 16 hours 43 min ago
I was wondering about this the other day, and since I saw this, I figured I would ask. Is there any potential advantage to using the red LED in the tint mix? Most phosphor-based white LEDs tend to lack red, right?
ETA: Or is that already the plan?
Lux-Perpetua
I don't know if using the red emitter in combination with the surrounding white emitters would result in a nice beam pattern. I would rather expect it to look weird. So, the red / deep red emitter is more likely to work separately as auxiliary illumination in lowlight scenarios (e.g. camping, preserving one's night vision, no attraction of insects, nightstand light, ...). Using the Osram White Flat 1mm² instead could be interesting to put out more throw as a centered hotspot in combination to the floody LH351D beam.
Nismo
Nismo's picture
Last seen: 6 days 18 hours ago
This looks like a great concept, I like it. I’d be more of a 4-LED 18650 kind of guy for EDC, but this seems like a good camping trip flashlight that can also serve as a lantern. 5700K while hiking for visibility, mixed tint while cooking food and 2700K when relaxing and reading a book. Just throw on a silicone diffuser and you’ve got yourself a lantern. Maybe a folding hook in the rear to be able to hang it in the tent or from a tree, with a magnet in the cap to keep the hook folded and still being able to stick it to metal surfaces.
I’ve been waiting for my IF25 from Aliexpress since 11/11, but I’m not sure when it will arrive, or how good it will be with the 70CRI 6500K SST-20s. Also waiting for my BLF LT1, but a flashlight like this could replace them both for my use.
Current lights:
Emisar D4V2 SST-20 4000K, D4V2 Ti SST-20 2700K amber switch LEDs, D4V2 Ti SST-20 4000K cold white switch LEDs, D4SV2 SST-20 3000K | Fireflies PL47G2 XPL HI V3 3A, PL47G2 SST-20 4000K Lumintop FW1A SST-20 4000K Nitecore LR12 XP-L HD V6, TUP XP-L HD V6 | Sofirn C01S SST-20 4000K, SP10S LH351D 5000K, IF25/LT1-M SST-20 2700K + 6500K w/3D printed diffuser, BLF SP36 LH351D 5000K, BLF LT1 | ZebraLight SC53Fc XP-L2 4000K Convoy C8+ SST-40 6500K
Lux-Perpetua
So, I revised my original idea and tried to set up something new, something easy to operate...
(please excuse this rather simple design draft....just for illustration...)
Specs:
Output: approx. 4.200lm white light with a mixed tint of 4.500K 90CRI and approx. 400lm deep red light (660nm), emitters to be driven efficiently - not pushed to their limits
Host: Proprietary, mid section maybe based upon Sofirn SD05 or IF25A, front section (head) new design with wider head diameter (40-42mm), tailcap + switch Sofirn SP70
Optic: LEDiL TAMPA NIS83-MX-7-W (wide beam, 35°, 38mm diameter)
Bezel: Stainless steel bezel
Emitter: 3x LH351D 4.000K 90CRI, 3x LH351D 5.000K 90CRI, 1x SST20-DR (660nm)
Driver: fully regulated boost driver (wishful thinking)
Power: 1x 21700 flat top
UI: magnetic rotation ring controls stepless brightness only (moonlight to turbo), tail switch controls modes (tap for mode selection between white and red light, fully press for ON/OFF)
MascaratumB
MascaratumB's picture
Last seen: 4 min 35 sec ago
I like this new idea Wink Thumbs Up
Seems a very well thought flashlight!
One question, though: the tailswitch would be a e-switch or a foward clicky switch?
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3/ 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
id30209
id30209's picture
I like it.
trakcon
trakcon's picture
Last seen: 1 hour 15 min ago
I like this, too. Nice design.
Th558
Th558's picture
How about 9 LEDs? or have both a 7 and 9 LED variant.
Edit: 9 months ago I said 4 LEDs Shocked
tammap
Last seen: 5 days 19 hours ago
I like the thrower version.
Am I a minority here or what, but why would someone want a flashlight that is anything <5,000K. I know that a lower number K LED light will yield a higher CRI, but this is a flashlight after all and not photography lighting. If someone wants higher CRI then he/she might as well go back to using incandescent light bulbs. Newbie here, so please educate me.
I have my fire suit on, so go ahead: fire away.
Poguche
Last seen: 21 hours 57 min ago
Hi tammap!
It all comes to a matter of personal preference. For example, I use my warm white FW3A a lot at night when my eyes are alredy used to dim and warm light, and in that conditions warm white seems just white, and my neutral lights seem cool. It is just easier on my eyes, more comfortable.
Then again, I have a 2700K led lamp on my desk to study, just because I like it, and late at night cool lights don’t seem right to me. In addition, I think it is better if you have to sleep inmediately after stopping studying. In this conditions, the transition from warm lamp to warm flashlight is “seamless”.
Of course, If you like cooler neutral / cool whites then you don’t have to be educated, it is fine. I would try an inexpensive warm flashlight if I were you and had the chance, just to try it if you haven’t, but if you know it isn’t your cup of tea then again it is just fine, personal preference.
Lux-Perpetua
MascaratumB wrote:
I like this new idea Wink Thumbs Up Seems a very well thought flashlight! One question, though: the tailswitch would be a e-switch or a foward clicky switch?
An e-switch would probably make this much more complicated to design (double-tube), so I would suggest using a mechanical (reverse/forward) clicky switch.
Th558 wrote:
How about 9 LEDs? or have both a 7 and 9 LED variant. Edit: 9 months ago I said 4 LEDs :O
Not sure if there's a 9 emitter optic with less than 40mm. IMHO, going beyond 40mm will make this light too big and ugly using only one battery. Moreover, there's little benefit to expect with 2 more LEDs, making this light only "more floody" than it is already. Smile
tammap wrote:
I like the thrower version. Am I a minority here or what, but why would someone want a flashlight that is anything <5,000K. I know that a lower number K LED light will yield a higher CRI, but this is a flashlight after all and not photography lighting. If someone wants higher CRI then he/she might as well go back to using incandescent light bulbs. Newbie here, so please educate me. I have my fire suit on, so go ahead: fire away.
I would also like the center LED to be something for long distance illumination. But I did not find any optic that has multiple beam angles, so something like Osram's White Flat will not work well here. In such a case, a classic multi-emitter reflector might be the better choice but then again the head diameter will become huge. UV LEDs will not work either as their wavelengths will be filtered out by most plastic lenses.
Concerning the tint: Many people here seem to favor a tint between 4.000K and 5.000K. The downside of HighCRI emitters is their worse efficiency but this could be solved by driving an array of six LEDs at reasonable currents, yielding in a beam that is both bright and pleasing for optimum color rendition.
Update:
I revised the OP with the latest draft and some spreadsheet about the specs. An integrated USB-C port might be a nice add-on, too?
hodor
hodor's picture
Last seen: 25 min 47 sec ago
Maybe add some knurling to the body? Preferably not the pineapple style though Sick
