ThruNite T10T V2 (Titanium) Dual Chemistry EDC /// Full Review
13 posts / 0 new
robo819
robo819's picture
Last seen: 3 weeks 3 days ago
The T10T V2 can be found on Amazon and the main ThruNite site. The Light shows to come in both Neutral and Cool White.(links are NON affiliated)
https://www.amazon.com/dp/B07XNMQ6TS?ref=myi_title_dp
http://www.thrunite.com/thrunite-t10t-v2-customized-edition-with-cutlery...
The T10T V2 arrived in a padded bubble envelope with the Thrunite box inside that. The outer Thrunite box houses the metal storage case for the light and contents that come with the T10 V2.The contents include the Light itself , 2 extra O-rings , clip , user manual and the Thank you card.
This is a dual chemistry light , meaning it can work from AA (alkaline) , NiMH , or 14500 cells. It is also made from Titanium , so (in my personal opinion) looks very stylish.
The light is pretty compact and has a magnetic tail , so it can be used hands free when stuck to something metallic. The magnet holds pretty firmly on something like the rougher Refrigerator surface and especially on a flat surface , as demonstrated with the scissors and the metal Thrunite box the light came in , even through the outer cardboard box , it still holds pretty firmly.
The T10T V2 pictured with the Sofirn SF14 and a 18650 cell.
The Clip can be attached at either end of the tube for head UP or head DOWN carry of the light. When the clip is attached at the head end of the light the T10T V2 can also be used as a headlamp. There is also an eyelet in the tailcap if you wish to attach a lanyard. The clip on this light is also made more sturdy than the original model of this light and will stay put on jeans , slacks or a ball cap with NO problem.
“Ribbing” instead of knurling is used on this one. It provides sufficient grip and I like the looks of the ribbing on this light. The threads are well cut on the tube and inside the head also. The spring inside the tube (one piece tube) looks to be well attached in the bottom.
The branding (etching) is also well done on the light. The emitter has been changed from the original T10 V2 , which had the XP-G3 and the T10T V2 now utilizes a XP-L emitter with OP reflector (pretty much perfectly centered on my sample). In the end it proves to be a much smoother beam than the original model and without the olive or greenish corona around the hotspot as the original model had.
The UI is pretty simple on the T10T V2 and is as follows……
A long press from OFF to get the Firefly mode (about 1 full second) from there a press of about 1/2 second to advance to Low mode and the same to advance to High mode from there. A quick double click gets you to the Turbo mode and from there you can get the strobe with another double click. From any mode double click to go straight to Turbo mode. To turn the light off from any mode a quick click is all that is needed. The T10T V2 will memorize the Low and High modes only and will remember which ever of those you turn the light off in.
Note When using a Lithium cell in this small light (as with most small lights) it DOES get very hot in the Turbo Mode. The light is also producing close to 4 times the output from the lithium cell that the NiMH produces. When using the NiMH cell the light gets warm , but not hot.
ThruNite does not list any run time testing for the Lithium (14500) cells , but I did my own testing with an Efest 14500 650mAh , as noted in the charts below. I did not do any official run time testing with the NiMh cell , but after using the light a good bit with the NiMH (Everyready 2450mAh) I averaged around 120 minutes. The average was across Low , High and short burst of Turbo Mode.
Another Note For those who have not already seen in some of my other post…..My light box (Tube) has been calibrated with the Maukka calibrated light set and my readings from my setup are about 3% UNDER the Maukka calibrated lights.
All of the live footage (noted below before the video) and beamshots that I am posting were done using the 14500 cell.
GIF 10 yards—Low/High and Turbo
GIF 50 yards—Low/High and Turbo
GIF 70 yards High and Turbo
Overall I really am liking this little light. The only suggestion I may have would be to possibly put an electronic lockout in the driver so you don’t get the parasitic drain from the E-switch. There is no way to manually lock out the solid titanium light as it is.
For those who may not want to see the whole video , but would like to see the live outdoor comparison footage using the T10T V2 , the Thorfire TG06 S and the Sofirn SF14 (all AA size dual chemistry lights) that footage starts at 11:25 of the video timeline.
Video followed by listed specs…………
https://www.youtube.com/watch?v=baN9Q7yMZuc
Features and Specifications
•Equipped with the advanced CREE XP-L LED upgraded from previous CREE XP-G2 LED
•Uses one 2450mAh AA battery or one 750mAh 14500 battery(not included).
•Max output: 160 lumens with 2450mAh AA Ni-MH battery OR 550 lumens with 750mAh 14500 Lithium-ion battery.
•Working voltage: 0.9V-4.2V.
•Output & Runtime (Tested with 1*2450mAh AA Ni-MH Battery):
•Firefly (0.5 lumens /14 days)
•Low (9 lumens /40 hours)
•Medium (54 lumens /8 hours)
•High (160 lumens /140 mins)
•Strobe (160 lumens /200 mins)
•Peak beam intensity: 1160cd.
•Max beam distance: 68 meters.
•Waterproof: IPX-8 (2M).
•Impact resistance: 1.5 meters.
•Size: 87mm (Length) x 19mm (Diameter).
•Weight: 40g (without battery).
•Reflector: OP
•Accessories: Spare O-ring x 1, Pocket Clip x 1.
•Compact design fits comfortably in your pocket, backpack, or anywhere else you keep your light.
•Magnetic tailcap free your hands. Be perfect for any hands free mechanic work.
•Reverse polarity protection design to protect from improper battery installation.
•Aircraft-grade aluminum body with premium type III hard-anodized anti-abrasive finish.
•Toughened ultra-clear glass lens with anti-reflective coating.
•Removable pocket clip for easy to use.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 10/30/2019 - 15:32
Gunga
Gunga's picture
Last seen: 4 hours 55 min ago
Looks great. I do want to get one of these. And mod it with more pleasant led.
robo819
robo819's picture
I expected this one to be a big hit, I know it isn’t the super gazillion lumen output like everyone is into now , but still a really nice little EDC.
Gunga
Gunga's picture
If no coupons show up, I’ll probably grab one at black Friday.
robo819
robo819's picture
They advertise it with Neutral or Cool white on both Amazon and the Main Thunite sites.
Gunga
Gunga's picture
I’ve had neutral before. Twas nasty green. I prefer to pick my led.
robo819
robo819's picture
I know what you are saying for sure. I dont like the “Flip Chip” (XP-G3 / XHP 50.2 – 70.2 etc.) emitters at all due to all the greenish cast from those. Usually do the slice and dice and get rid of the extra phosphor on those.
This one does not have the XP-G3 like the original T10 V2 did though (uses XP-L in Titanium model). No olive or egg yolk color like the original had.
LightObsession
Thanks for the review.
Looks like a nice, compact light.
robo819
robo819's picture
Glad to do it. Yes very nice little EDC.
toddcshoe
toddcshoe's picture
Last seen: 1 hour 23 min ago
Wait a second, wait a darn second. Does this thing really show up with “Cutlery Lover” etched on it and the r in lover is a pistol? Somebody please tell me this is a joke.
"Everywhere I go, there I am"
robo819
robo819's picture
Actually that is correct , but I had not even noticed the R in there being a pistol.
Hugh Johnson
Hugh Johnson's picture
Last seen: 14 hours 16 min ago
Nice review, as always.
robo819
robo819's picture
Thanks
