Olight M2R Pro 30% off today only
31 posts / 0 new
LumenMax
LumenMax's picture
Last seen: 10 hours 7 min ago
30% off Olight M2R Pro. Today only! Sold by SkyBen Amazon . Expect perfect packaging and excellent customer service from SkyBen Amazon. Also available at https://www.olightstore.com/flashlights/m2r-pro-warrior.html. Camo version is exclusive to https://www.olightstore.com/flashlights/m2r-pro-warrior.html
Discounted price as shown: Price:$76.97
Use your Amazon credit card or any other credit card that offers 5% cashback
Sign up for ebates.com for another 3% (Sports & fitness category) off and $10 sign up bonus https://www.rakuten.com/r/LUMENM5?eeid=28187 . With ebates.com, you can save on other stores, such as up to 2% back on eBay.com, up to 5% on hotels.com
https://www.amazon.com/OLIGHT-Magnetic-Rechargeable-Switches-Flashlight/dp/B07YP6P91F/ref=sr_1_49?dchild=1&m=A291SI22FJYAZO
DESCRIPTION:
The M2R Warrior Pro is the newest version of OLIGHT two-button straight tactical flashlight. It features a single 5000mAh 21700 chargeable lithium battery and TIR lens for uniform light. The maximum output and distance are increased by 20% and 44% separately, reaching 1800 lumens and 300 meters. The surface texture is improved to the second-generation multifunctional tail with strengthened connective magnetism. Newly designed magnetic USB charging wire can hold 2A current, increasing charge rate 100%. With its lanyard hole, detached two-way Stainless Steel Pocket Clip, flashlight bag, the M2R Pro is the next evolution of the tactical flashlight.
OUTPUT:
  • Model 1: 1800~750~250 lumens / 4.5+145+45 minutes
  • Model 2: 750~250 lumens / 160+40 minutes
  • Model 3: 250 lumens / 10 hours
  • Model 4: 60 lumens / 40 hours
  • Model 5: 15 lumens / 130 hours
  • Model 6: 1 lumens / 50 days
SPECIFICATION:
  • Manufacturer: Olight
  • Model: M2R Pro Warrior
  • LED Source: High Performance Neutral White LED
  • Body Material: AL6061-T6 Aluminum Alloy
  • Powered by: Customized 5000mAh 21700 Rechargeable Lithium Battery
  • Max. Output: 1800 lumens
  • Max. Throw: 300m / 984ft
  • Length: 5.37in/136.50mm
  • Head Diameter: 1.16in/29.50mm
  • Body Diameter: 1.03in/26.20mm
  • Weight: 6.31oz/179g(including battery and pocket clip)
  • Waterproof: IPX8
M2R PRO
M2R PRO
Three - Level Power Indicatior
Visual display indicator located on the center of the switch to clearly display the battery level in real time
  • Indicator glowing green (Battery remaining>75 % )
  • Indicator glowing orange (Battery remaining 30-75%)
  • Indicator glowing red (Battery remaining<30%).
M2R PRO
Crenelated Bezel
  • The new designed crenelated bezel is more excellent compared with our previous M2R.
  • Lens / Reflector Type: Reflector and TIR Optic Lens
M2r pro
M2R PRO
M2r pro
M2r pro
New Designed Tail Switch
  • Easily concealed with a quiet tail switch
  • Easy to operate with a raised tail switch
Fast Charging
Equipped with Olight MCC3
(Third Generation Magnetic Charging Cable)
Dimensions & Weight
Package Contents
  • M2R Pro Flashlight x 1
  • Customized 5000 mAh 21700 Rechargeable
  • Lithium Battery X 1 (Included)
  • MCC3 Magnetic USB Charging CableX 1
  • Stainless Steel Pocket Clip X 1
  • Lanyard X 1
  • Holster X 1
  • User Manual x 1
M2r pro
Edited by: LumenMax on 10/31/2019 - 12:24
bmengineer
bmengineer's picture
Last seen: 51 min 54 sec ago
30% off only today, but proprietary cells only forever.
No thanks.
Find all my reviews of flashlights and more gear at www.bmengineer.com
LumenMax
LumenMax's picture
bmengineer wrote:
30% off only today, but proprietary cells only forever. No thanks.
Proprietary battery if you want to use the built-in magnetic charging system.
bmengineer
No. This light will not turn on with any cell other than the proprietary one Olight sells for almost $30.
LumenMax
LumenMax's picture
Sean @ Olight stated that you can use other batteries with this light. You cannot charge them with the magnetic charging system, that's all.
bmengineer
The answers to questions on their product page and word from a reliable source with the light in hand disagree.
LumenMax
LumenMax's picture
Sean tried a button top non-Olight battery and it works for him. 18.2Wh, 3.6V battery.
bmengineer
zak.wilson
Last seen: 6 hours 3 min ago
Ceilingbounce – flashlight testing and runtime graphs for Android
LumenMax
LumenMax's picture
bmengineer wrote:
https://vimeo.com/user104670785[/quote]
Is this the Acebeam battery used in the video? https://www.batteryjunction.com/acebeam-21700-li-ion-battery.html
maukka
maukka's picture
Last seen: 26 sec ago
Oh man, what a sad thing you did there Olight.
LumenMax
LumenMax's picture
Sean will look into this further.
zak.wilson
The part number matches the one seen in the video.
pconig
Last seen: 1 week 1 day ago
That is absolute BS! We were told in the FB group that it would work with a non-proprietary battery, as does the Seeker Pro. Not only did I already order the light, I also ordered a non Olight 21700.
If this is the case, I’m done with Olight.
Travln
Travln's picture
Last seen: 5 days 22 hours ago
Thank you for posting that! I sure am glad that I scrolled down to read what others have posted.
I was about to purchase for that price. I EDC an Olight. I have two, but if this is what they are doing I may never purchase another.
On Amazon, In the description it just says Powered by: Customized 5OOOmAh 21700 Rechargeable Lithium Battery
LumenMax
LumenMax's picture
pconig wrote:
That is absolute BS! We were told in the FB group that it would work with a non-proprietary battery, as does the Seeker Pro. Not only did I already order the light, I also ordered a non Olight 21700. If this is the case, I'm done with Olight.
I have the Seeker 2 and Seeker 2 Pro. The Klarus 21GT-50 battery works in both.
SKV89
Last seen: 3 hours 42 min ago
That’s not true. I just tested my copper M2R and it turns on with my VTC6 button top and Molicel P26A flat top.
pconig
LumenMax wrote:
pconig wrote:
That is absolute BS! We were told in the FB group that it would work with a non-proprietary battery, as does the Seeker Pro. Not only did I already order the light, I also ordered a non Olight 21700. If this is the case, I’m done with Olight.
Yes, my S2 Pro also does work with all of my 21700 cells, not just the provided Olight cell.
pconig
We’re talking about the M2R Pro here, its a totally different light…
kanton
Last seen: 48 min 23 sec ago
I gave my thoughts on why this light will probably not work with a regular 21700 contrary to the Seeker 2 Pro here: http://budgetlightforum.com/comment/1578783#comment-1578783
Short version: The battery goes in the other way around than in the Seeker 2 Pro. They seem to use the Plus and the proprietary Minus to drive the light for the M2R Pro. They used the regular Minus to drive the light in the Seeker 2 Pro.
Regarding the regular M2R: This light is constructed COMPLETELY differently, and has an inner tube (like the FW3A or Klarus lights) so it can use a standard 18650.
Lightbringer
Lightbringer's picture
Last seen: 6 hours 56 min ago
Yoiks!
If I bought the light from Amazon, tried (several) standard 21700s, and it wouldn’t work, I’d have to return the light as defective. How could I or anyone else know it would only work with a proprietary cell?
Alitd
Last seen: 4 hours 48 min ago
I’ve bought several olights. They finally get the neutral>cool white and then get greedy on a $30 battery?
kanton
It’s probably only part of the story, but yes. My guess is that it’s also easier to manufacture that way and they save 1-2mm in diameter.
@Olight: I have a regular M2R. I bought it because I liked the UI and that you for once did not opt for a proprietary battery design. The regular M2R is very well executed. It did not fail me once.
But I don’t see the “Pro” in a “tactical” flashlight that can’t even be used with some other 21700s. Nothing “Pro” or “tactical” about this. Won’t buy.
wraithpc
wraithpc's picture
Last seen: 3 hours 50 min ago
Just seems silly, I purchased just a little while ago, going to be cancelling order first thing in the morning. Don’t care about the charging, but if the light does not work with anything but the proprietary battery that is a deal killer, bad move imho!
toddcshoe
toddcshoe's picture
Last seen: 5 hours 37 min ago
Wow, that’s pretty bad. I guess I would understand it if the cell needed wasn’t $30. They wanted to do something that required a proprietary cell? Okay. Still idiotic but, sell the cells for $5 a piece when ordering the light. A guy could stock up on 4 or so. Even though that is still a crappy thing to do. That is next level genius right there.
Still trying to see the logic in posting it on BLF. They should have known the term “proprietary battery” wouldn’t sell many lights here. I am a gun guy as well. CZ is one of my favorite makers. If CZ told me they came out with a new 9mm pistol but it will only shoot their ammo at 6 times the money of say, Winchester ammo, I’d start buing Hi-Point instead. Okay maybe not Hi-Point. Wink
Edit: Question. Will Olights proprietary cell only be able to be charged by the magnetic charging dohicky?
"Everywhere I go, there I am"
pconig
The cell looks to be the same as provided with the Seeker 2 Pro, in which case I can verify that with a small neodymium magnet placed on the (+) end it can indeed be charged outside of the light.. You obviously still must use caution because it can quite easily be shorted.
wraithpc
wraithpc's picture
If it is like the 18650 it will charge in any charger that will accept its physical size. Even if they were less then $30 I’d think twice, I have two of the 18650 cells from them, both have only seen a cycle or two, and one will not run turbo on my m2r, the other runs it for a few seconds, I assume voltage sag as the light is fine with different bats.
I will say I’m very pleased with customer service, emailed them for confirmation of proprietary only, asked they cancel my order if correct. Answered my email in maybe 30 minutes, confirmed correct, asked if I still wanted to cancel, I confirmed immediately. About an hour later I had the refund.
I’m sad though, would have liked the light for my rifle.
kanton
On a different note:
5 or 6 people in the Olight Facebook group report the light not turning on – after charging, the status LED in the switch turns green but nothing happens if you try to turn the light on.
According to the video M4DM4X posted, every single light is tested before shipping out (see http://budgetlightforum.com/node/69795) – if that really is the case it would mean that the lights basically die after they at least had worked in the QA.
From what I have heard, Olight has excellent support, so this probably won’t be a big issue. Just something to be aware about if it happens to you.
Edit: More people report of duds on Facebook. Count increased to 5 or 6.
zak.wilson
I’d suggest that they check with another battery before returning it, but….
kanton
People did and the light seems dead. It’s a few more now, I would guess around 8-10 in that group. One report where the light worked for a little while but then died after the person started to use the tail switch more often. That person also crosstested it with the battery from the Seeker 2 Pro without luck. Not sure what’s going on.
bmengineer
It’s Sean still trying to figure out what batteries his flashlight takes?
