Ultimate LED Bulbs - Ultra High CRI - The Honorable Quest
402 posts / 0 new
contactcr
Last seen: 3 hours 19 min ago
I had been trying to find a “smart” bulb that was also CRI 90+ only a month ago with not much luck
djozz
djozz's picture
Last seen: 8 hours 22 min ago
djozz wrote:
fneuf wrote:
In one, simple but effective, word : YES
In two, honest and heartwarming, words : YES, PLEASE
laughing
Which of Yuji’s reference have you got on hand?
It must be YJ-BC-RP-6-40, it is a couple of years old already but it looks like that one.
Just measured the Yuji bulb: CCT=4040, duv=-0.0014, CRI=96.2, R9=91.6
So it does live up to its specifications.
One of my Philips GU10 3000K ExpertColor bulbs: CCT=2982, duv=+0.0004, CRI=97.4, R9=87.8
One of my Philips GU10 2700K ExpertColor bulbs: CCT=2779, duv=+0.0009, CRI=97.7, R9=88.5
fneuf
fneuf's picture
Thanks for the work djozz. All your candidates have very great Duv values, special mention to the negative value of the Yuji.
Do you have R12 and Rf measurements also?
Rise and Shine my precious...
djozz
djozz's picture
fneuf wrote:
Thanks for the work djozz. All your candidates have very great Duv values.
I never used TM30 on my meter before, but I just added it to the parameters, had to measure again and had to look up what Rf and Rg were Innocent :
Yuji 4000K: CCT=4035, duv=-0.0008, CRI=96.1, R9=90.9, R12=73, Rf=91.3, Rg=100.7
Philips ExpertColor 3000K: CCT=3009, duv=+0.0013, CRI=97.3, R9=89, R12=83, Rf=93.9, Rg=100.4
Philips ExpertColor 2700K: CCT=2796, duv=+0.0011, CRI=97.8, R9=89.6, R12=84, Rf=92.7, Rg=98.8
SKV89
Last seen: 30 min 24 sec ago
Waveformlighting 2400K filament light bulb
CCT: 2342K
DUV: -0.0032
CRI (Ra): 96.0
R9: 81.9
Rf: 93
Rg: 102
Blue Peak: 0.23
I absolutely love the negative DUV so it doesn’t look overly yellow. It is great as a nighttime light to minimize melatonin suppression. It is one of the lowest blue emitting lights I’ve measured, which is about right for the color temp but it still contains about 3x as much blue light as the E21A 2000K 9080.
fneuf
fneuf's picture
contactcr wrote:
I had been trying to find a "smart" bulb that was also CRI 90+ only a month ago with not much luck
That might be a tad harder at the moment.
Last time I checked, top of the class was LIFX with close to 90 values (~86).
I never used TM30 on my meter before, but I just added it to the parameters, had to measure again and had to look up what Rf and Rg were Innocent : Yuji 4000K: CCT=4035, duv=-0.0008, CRI=96.1, R9=90.9, R12=73, Rf=91.3, Rg=100.7 Philips ExpertColor 3000K: CCT=3009, duv=+0.0013, CRI=97.3, R9=89, R12=83, Rf=93.9, Rg=100.4 Philips ExpertColor 2700K: CCT=2796, duv=+0.0011, CRI=97.8, R9=89.6, R12=84, Rf=92.7, Rg=98.8
I have updated  the first post table with your results, thanks again.
That's a shame really that there's no E26/E27 equivalent to those GU10 spots in Philips' current product range. They are not perfect, but very decent (R9 and R12 are still too low).
SKV89 wrote:
"Waveformlighting 2400K filament light bulb":https://store.waveformlighting.com/collections/a19-bulbs/products/lux24-... CCT: 2342K DUV: -0.0032 CRI (Ra): 96.0 R9: 81.9 Rf: 93 Rg: 102 Blue Peak: 0.23 I absolutely love the negative DUV so it doesn't look overly yellow. It is great as a nighttime light to minimize melatonin suppression. It is one of the lowest blue emitting lights I've measured, which is about right for the color temp but it still contains about 3x as much blue light as the E21A 2000K 9080.
Thanks for your input SKV89, I have added your results to the first post table. The 0,23 blue peak does mean the overall curve has a nice shape and no, peak per-se, in the blue area?
lightdecay
Last seen: 24 min 49 sec ago
CCT: 2342K
DUV: -0.0032
CRI (Ra): 96.0
R9: 81.9
Rf: 93
Rg: 102
Blue Peak: 0.23
Thanks for the test! I wanted to get a below-2700K LED bulb with negative duv, this one looks great.
fneuf
fneuf's picture
Guys, if I want to create a "BLF Bulb Quality factor™" to "scientifically" order my first post table, what would you advise as metrics/formula? Which Rx, or other parameters to factor in?
Draft proposal => Qf = [(Ra *1)+(R9*3)+(R12*3)+(Rf*3)] / 10
djozz
djozz's picture
Quote:
 [Philips ExpertColor] They are not perfect, but very decent (R9 and R12 are still too low).
There is a point at which perfection can only be measured and not be seen at all by eye, are you sure you did not pass that point already? Wink
patmurris
patmurris's picture
Last seen: 9 hours 6 min ago
fneuf wrote:
Now B22 mostly remain in usage in UK, India and Australia. France is “converting” (don’t know of norms fixing that decision, seem to me it’s a market general decision) to B22 since some years (decades), but you will still find some bayonet in old houses/rooms. The majority of Europe uses B22.
I guess you mean France is converting from B22 to E27, and the majority of Europe uses E27?
fneuf
fneuf's picture
djozz wrote:
There is a point at which perfection can only be measured and not be seen at all by eye, are you sure you did not pass that point already? ;)
That's a valid point, but from a number POV we have better offers from alternate manufacturers regarding R9 and R12 than the ExpertColors. Now, could I, could you, could the readers here, feel the differences, and what color rendering would they prefer? That's a good question.
To be sure about that, we'd need a setup with every "bulb contestant", and be able to blindly switch between the lights, and slowly build a prefered order. Kind of an ABX test adapted to lights infact.
But, isn't the title of this thread "Ultra High CRI"? laughing And well, the subtitle of this thread could also be "Never accept compromises, to the infiniiiite and beyond..." innocent
Slip of the tongue, thanks to point it to me! I'm correcting that.
Joshk
Joshk's picture
Last seen: 2 hours 41 min ago
fneuf wrote:
Guys, if I want to create a “BLF Bulb Quality factor™“ to “scientifically” order my first post table, what would you advise as metrics/formula? Which Rx, or other parameters to factor in?
I was actually thinking about this a few weeks ago. I think you are including the right things. But the best results would best be a simple scale from 1 to 10, but not try to fit the scale to the whole market today. For example, a 5 would actually be an above average light today, a 10 would be a future perfect light, and a 1 and 2 would be many of the lights on the market today. The idea of fitting the scale like that would so it doesn’t become obsolete by not accounting for improved technology in the next few years.
SKV89
yes the blue zone is very small, with blue peak is mild at 23% only.
djozz
djozz's picture
Talking about the blue peak, Luminus has brought a new 3030 led on the market that has the cyan gap filled up (or even made into a cyan peak) so that high CCT’s can be made with a lower blue peak. It is called Luminus “Salud”.
https://www.luminus.com/datasheets/Press_Release_Luminus_Salud_102819.pdf
https://luminus.com/products/salud
maukka
maukka's picture
Last seen: 1 day 12 hours ago
Not high CRI but here’s the Ikea Trådfri 1000 lm E27 smart bulb:
https://imgur.com/a/Xsx7d
Lexel
Lexel's picture
Last seen: 8 hours 55 min ago
matik42
Last seen: 4 days 11 hours ago
phantom23
phantom23's picture
Last seen: 2 days 9 hours ago
Livarno Lux bulbs from Lidl are advertised as high CRi (>95, sometimes 97 or even 100), they’re pretty cheap at 1,5-5€ each (depends on the country and model) and they come in various shapes, sockets (G10, E14, E27), from 250 to 806 lumens. Sources:
Germany
https://www.lidl.de/de/livarno-lux-2-bzw-3-led-leuchtmittel/p308488
Poland
https://www.lidl-sklep.pl/LIVARNOLUX-Zarowka-reflektorowa-LED-6-sztuk/p100267581
Spain
https://www.lidlonline.es/es/bombilla-led/p667
fneuf
fneuf's picture
Ikea >> sub-90CRI seems not enough for our "Ulta High CRI" topic. But it's great that a "big name of house equipments" is putting CRI on its product. A good way to eduquate consumer in the long run. Do they offer better lines?
Philips >> GU10 CRI97 offering is great, for sure. Why don't they also make E27 bulbs out of it is a mystery. Maybe a double targetting bias, where GU10 is used to target shops/pro displays, whereas E27 is viewed as consumer only format, and consumer as deemed not interested in great CRI?
Airam >> Do you have tests or more detailled specs somewhere about this bulb?
LIDL >> claimed specs are interesting, but I can't help but being dubious about a CRI100 offering (who would/could be their manufacturer?). That is making me "scientifically doubt" about pretty much their other claims too, as a consequence. Other bias in my reasonments is that with those "white branded" products, the inside of the product could change with each production run. Any tests (and more precise references) somewhere ?
The "trick" with pretty much manufacturer claiming good/great CRI will fall under the CIE vs TM-30 measurements caveats. The common old CRI index is proven to be unfit to adequately qualify LEDs flux (too much pastel colors, not taking into account full spectrum, etc). That's why TM-30 is aiming to perfect that situation and that's why I've added from the start R9 (deep red), R12 (deep blue) and Rf (full spectrum) values.
A manufacturer can claim a great CRI value (so based only on R1-R8 values), but producing for instance "badish" results on R9 and R12. And as such giving a "meehish" render in our homes.
I've started to rebuild my table, with the BLF Bulb Quality factor™ proposal, you cand find it there.
Have to think a bit more about the proposal of Joshk for its scale.
djozz
djozz's picture
IKEA Ledare, type LED1708R5.
A dimmable GU10 bulb that uses very warm leds at the lowest brightness setting and gets cooler tint at higher setting by gradually mixing in a cooler set of leds and switching off the warm set at the highest setting.
Lowest settings, just the warm leds:
CCT=2060, duv=+0.0012, CRI=93.6, R9=58, R12=98, Rf=93.2, Rg=96.8
An intermediate setting, some cooler light mixed in:
CCT=2450, duv=+0.0005, CRI=93.8, R9=60, R12=92, Rf=92.6, Rg=99.4
Highest settings, just the cooler set of leds, warm leds are off:
CCT=2640, duv=+0.0008, CRI=91.7, R9=54, R12=88, Rf=90.3, Rg=100.0
djozz
djozz's picture
IKEA Ledare, type LED1521R6
A 2700K 90+CRI GU10 bulb, non-dimmable
CCT=2850, duv=+0.0014, CRI=91.9, R9=59, R12=83, Rf=91.0, Rg=99.9
Lexel
Lexel's picture
too bad all IKEA above BBL
djozz
djozz's picture
The newest insights are that (“western”?) people prefer the tint well under the BBL, which these bulbs are not, but they are only slightly above it, and I do not see an ugly tint.
fneuf
fneuf's picture
Really quick post. First, thanks for all your new test additions guys.
Then, here is the updated table, with a first run at ordering it:
Bob_McBob
Last seen: 11 hours 4 min ago
Since there are so many measurements being posted, I just want to remind everyone you should allow LED bulbs to warm up for a while before testing because Duv tends to drop significantly.
staticx57
Last seen: 3 hours 46 min ago
I so want to try some of these
johnpc
Are there any good tube style replacements? I got a box of Hyperikon T8 bulbs that claim >= 90 CRI. They’re better than the fading florescents they replaced, but the PWM is noticeable sometimes.
maukka
maukka's picture
djozz wrote:
IKEA Ledare, type LED1708R5. A dimmable GU10 bulb that uses very warm leds at the lowest brightness setting and gets cooler tint at higher setting by gradually mixing in a cooler set of leds and switching off the warm set at the highest setting.
Those look neat! I suppose flicker is obvious when used with a typical voltage chopping dimmer?
lightdecay
How long does one need to wait? Does this also apply to flashlights?
maukka
maukka's picture
High output bulbs with mediocre cooling tend to heat up to 70-100°C within an hour. Since home lighting is used for prolonged periods, I would usually wait at least 15-30 minutes before taking the measurements. Similar shift in tint goes for flashlights too, but they’re mostly used in shorter bursts and as such with less heat generated at the emitter.
