Wuben L60 zoomie will be on sale for $25.83 or cheaper on 11/11
8 posts / 0 new
SKV89
Last seen: 1 hour 34 min ago
Does anyone have any experience with this light? It looks very interesting. The reflector is white instead of black. It will be on sale 11/11 for $25.83 and there are additional coupons.
https://www.aliexpress.com/item/4000039584218.html?spm=a2g0o.productlist...
zak.wilson
Last seen: 5 hours 39 min ago
Looks like its capabilities are similar to any generic zoomie, except that it has USB charging. I think the Wowtac A3S is a bit more appealing, were I to get a cheap zoomie.
Ceilingbounce – flashlight testing and runtime graphs for Android
SKV89
Why do you say that? The L60 is cheaper, brighter, throws farther, and has built-in usb recharge.
Theodore41
Last seen: 6 hours 5 min ago
Because I have one of their other lights,I can say that the quality of these lights is very good.
zak.wilson
The A3S is slimmer, I trust its waterproofing a bit more (though Wuben’s advertised waterproof USB port is above-average), and it has Thrunite’s e-switch UI with shortcuts while the Wuben has a blink-to-change-modes mechanical switch with SOS in the main mode rotation (and it’s not clear if the memory is on-time or off-time). The A3S is available on US Amazon shipped from the US, which is much more convenient than Aliexpress for people in the US; it’s often on Amazon for other regions as well.
SKV89
Where did you see the SOS is built into the main mode? I couldn’t find any info on that. If that is true, Wuben just killed a light with good potential like Manker did to all of their lights.
EDIT: just got an answer from Wuben. SOS is hidden. Double click for SOS.
zak.wilson
I thought I saw a UI diagram that seemed suggest that on the product page, but it’s not there, and I may be thinking of a Wuben tube light with the same tailcap charging port.
If I’m understanding correctly, this is a mechanical reverse-clicky switch. Tap once to go to the next mode. Tap twice within a certain period of time for SOS. That’s still likely to be really annoying.
SKV89
Just recieved mine from Amazon. Bought it on 11/11 with a discount code that can be found on BLF. Took some measurements:
Zoomed in
Output: 713 lumens
CCT: 10470K
DUV: -0.0176
Ra (CRI): 73.9
Zoomed out
Output: 321 lumens
CCT: 14561K
DUV: -0.0211
Ra (CRI): 73.3
It is very CW but not super blue surprisingly given the high CCT. I will probably replace the emitter with a White Flat or SST-20 2700K. The host is very good quality and I like the simple UI and usb charge. Perfect for leaving in the car.
