Malfunctioning MF01S
20 posts / 0 new
ricksp65
Last seen: 4 days 11 hours ago
My astrolux mf01S seems to lock up in a slow blinking mode and the only way to stop it is to disConnect contact with the battery and it will operate normally for a few tries but then gets stuck once again any thoughts? Thanks
Edited by: ricksp65 on 11/02/2019 - 17:37
Lexel
Lexel's picture
Last seen: 16 hours 19 min ago
It’s a know Anduril issue related to switch bounce, especially 2S lights seem to be affected a lot more
I had it also on 1S lights
a small MLC capacitor of like 0.1uF directly soldered on the switch can fix it
ricksp65
I did contact banggood but they don’t seem to be very receptive when it comes to returns or replacements I’ve only had the light a couple weeks I haven’t heard anything back from them yet. But I guess repairing it myself could be an option if There’s no other way I do like the light though it would’ve been one of my favorites if this didn’t happen .
Lexel
Lexel's picture
Unscrew switch and solder cap 0603 for example, not sure where exactly to solder but easy to probe the switch
ricksp65
Kind of hard to imagine not replacing a product with a known defect. I guess I should’ve purchased it from Amazon they seem to be better about returns and replacements.
Lexel
Lexel's picture
Switch bounce problem is kind of odd most lights don’t show it
ricksp65
I only found one video on YouTube besides mine showing the problem.
ricksp65
Lexel
Lexel's picture
I hope Toykeeper will release a fixed firmware revision
NarsilM works flawless if you may want to flash different firmware
ricksp65
I have no idea how to flash software I just collect flashlights that I like I’m not really too much into the workings of them. I guess this one will be relocated to the drawer in the garage it didn’t make the grade to go on the shelf with all the really awesome flashlights.
d_t_a
Last seen: 4 hours 41 min ago
Lexel wrote:
It’s a know Anduril issue related to switch bounce, especially 2S lights seem to be affected a lot more I had it also on 1S lights a small MLC capacitor of like 0.1uF directly soldered on the switch can fix it
I have already many Anduril flashlights, but so far haven’t encountered this issue.
I would like to know how often do these kinds of “issues” or “bugs” happen? What is the cause?
Do they potentially affect all Anduril firmware flashlights (at least until a new firmware to workaround the said “bug” is released)?
Lexel
Lexel's picture
the issue is known by Toykeeper and its confirmed switch debounce code who can get stuck in a loop
any flashlight with this issue under Anduril could be tested with NarsilM working without that problem
ricksp65
So how do I get it fixed?? Or replaced? I’ve only had it less than two weeks? And what is a toykeeper?
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 31 min ago
Toykeeper is the person that makes the code of the firmware that runs your light.
ricksp65
Found an article that deals with this I think I figured out what’s going on here . https://www.allaboutcircuits.com/technical-articles/switch-bounce-how-to...
ricksp65
Well I think he needs to put that one back in the oven to bake for a while. LoL
ricksp65
The GF likes the pretty lights I wish I could take that board out with the colored LEDs and put it in one of my better lights but I don’t have the skills.
ricksp65
Has anyone else had any luck with returns and replacements from Banggood? I noticed they do a lot of advertising on this forum.
klrman
klrman's picture
Last seen: 17 hours 55 min ago
I think BG has a US warehouse, so for you it may be very easy to return it.  Normally, if you can get the same deal for a light on Amazon, it's always way easier to return.
Lexel
Lexel's picture
MF01S Aux board will not even fit MF01, not to mention any other light
I have for some lights aux board as in my signature
