New build for xmas 2019.. Finished Merry Xmas
28 posts / 0 new
lostheplot
lostheplot's picture
Last seen: 7 months 1 week ago
Inspired by the latest competition new builds , I decided to knock something up for xmas.. I have a 3v xhp50.2 and a lexel fet bistro driver laying around also a odd reflector that is 58mm dia and 55mm long.(no idea of the beam pattern)and will use a 26650 for the power source. With the lack of a decent boring bar(12mm) I decided to rough out the head on the mill. Tool is a cheap ebay 16mm hss 4 flute cutter at 1500rpm had to use this big to get the depth 57.5mm chip evacuation is a problem when boring holes
https://vimeo.com/370462232
short video3 mins ,the machine spirals in 15mm at a time then expands the hole to diameter
Finally with a 10mm step down to expand to final drawing size,
This opp took around 30minutes total,
Next off to the lathe.
sorry all images down
thanks photobucket
Edited by: lostheplot on 12/08/2019 - 05:51
pinkpanda3310
pinkpanda3310's picture
Last seen: 16 hours 8 min ago
Cool. Looking forward to seeing your build Cool
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 58 min ago
Do you normally “climb” mill vs conventional milling when circle interpolating the bore?
Wouldn’t it be faster to “plunge” mill then circle interpolate the bore?
KB1428 “Live Life WOT
lostheplot
Best way is to drill a hole and open that up.climb milling tends to leave a better finish.dont think I can plunge with that cutter.
Still learning this cnc stuff.
thanks photobucket
lostheplot
Small update thinking at work that I could use the metal that was removed to shape the head as the material for the bezel,
Machined a groove and ran a pilot hole for driver
into the lathe and parted off, material for the bezel instead of waste! Beer
thanks photobucket
MRsDNF
MRsDNF's picture
Last seen: 7 hours 23 min ago
Thanks for the vid LTP. Hows the parting off going? No broken tools?
lostheplot
A small update , realizing I should have knurled the bezel before parting I’ve changed the design a little
Decided to cut flutes around the diameter (used the head to support it in the vice
bezel finished!
thanks photobucket
lostheplot
No all good, it works well for fins as well
thanks photobucket
MRsDNF
MRsDNF's picture
Cant be much wall thickness there.
lostheplot
still 2mm under the root of the thread, ample considering the 1.25mm pitch.
next to shape the rear of the head
thanks photobucket
pinkpanda3310
Nice job saving on waste and recovery from no knurling Thumbs Up
lostheplot
Ok another small update,
Head complete, may have gone overboard with the fins,
Now on to the tailcap and tube
thanks photobucket
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 6 hours 46 min ago
Looks cool, Good work.
As iconic as the Aussie recycling bin lol
MRsDNF
MRsDNF's picture
Lots of fins need lots of current.
G0OSE
G0OSE's picture
Last seen: 16 hours 50 min ago
Pretty pretty!
lostheplot
This build is in no way connected to any competition, the remark in the first post is just a bit of dig!
sorry if this has caused any problems
regards Ltp
thanks photobucket
MtnDon
MtnDon's picture
Last seen: 5 min 4 sec ago
All the finning makes it appear to be a small engine cylinder. Smile
Interesting to follow this.
MtnDon
MtnDon's picture
I have a Christmas, non-competion, project I will be starting soon. The last parts I had to purchase came in Saturday’s post. I will start a topic when I start cutting and drilling wood.
lostheplot
A small update ,time to start on the tailcap
https://vimeo.com/377945294
small video thread turning how slow can you go?
next to castle the tailcap similar to the head and make battery tube hopefully in the next couple of days
thanks photobucket
MRsDNF
MRsDNF's picture
Nice video ltp. Good to see you remember how to use the lathe after spending all your time on the NC mill. Love the packer under the tool. Multi purpose fish tail gauge. Thumbs Up
pinkpanda3310
That spindle speed it super slow Tired
lostheplot
Its great for threading, I took the single phase motor of and put a 3 phase with vfd;
I can go from 5 rpm to 2500,,much smoother as well .the Chinese vfd talks a little though
thanks photobucket
lostheplot
Hi another small update.
ok the batteries arrived ,I decided to engrave the battery tube rather than knurl it.
and finally put all the parts in the tumbler for the afternoon
I hope they turn out ok
https://vimeo.com/378045389
A little vid of the engraving
thanks photobucket
lostheplot
well several hours in and looked like nothing was happening ,so I gave the parts a buff up
came up ok. assembled all the components
pictured with a few other builds.
so 15 amps is ok I guess.
will try for a beam shot of the shed later..
thanks photobucket
MRsDNF
MRsDNF's picture
Nice video. Do you allow for the diameter in the programming?
pinkpanda3310
So you’re not planning on changing the led… ever Big Smile
Ooh, okay then Blushing 15 amps will have to do won’t it LOL
Looks good Thumbs Up
lostheplot
mrs dnf
this guy explains the process
https://www.youtube.com/watch?v=XjjAqf94yZI
pp the idea of a longer tube for 6v and a 6vled did come to mind
but i’am just trying to use stuff that I had.
thanks photobucket
lostheplot
Ok one more pic of the light
the reflector is fairly deep probably as deep as it is wide.
a few nearly dark shots
first up the moon.
and of course the shed and down beside the house
I’am fairly happy with how this has turned out
thanks for watching.
thanks photobucket
