18650 compatible with 2 CR123A
3 posts / 0 new
Zannithehiker
Last seen: 2 weeks 1 day ago
Cheap emergency torch using CR123A
Hi Please recommend a Cheap emergency torch using CR123A
(the reason i prefer cr123a is because of the low self discharge rate)
Requirements/Preference
  • Most important is Runtime – Over 4.5 Hours
  • Durable - eg. IPX-8
  • Battery: CR123A (don’t mind an 18650 which is compatible with 2 CR123A)
  • Budget: $40 aud
  • Flood
  • The Higher CRI the better
  • Minimum 100 Lumens
  • Prefer physical switch or twisty
Edited by: Zannithehiker on 11/03/2019 - 20:23
Bearbreeder
Last seen: 43 min 5 sec ago
Sofirn sp31 v2
Just use a protected bat as theres no lvp
moderator007
moderator007's picture
Last seen: 1 hour 24 min ago
For just a throw in your glove box light or in a drawer for emergencys that runs off cr123a’s or a 18650 and is cheap. I would probably suggest buying a few 501b’s or the 502b. Usually under $10. The design has been around for years. They use what is called a P60 drop in which you should find alot of different options.
Using 2 cr123a’s use to be a common thing but its starting to become hard to find in a flashlight. If you can mod a flashlight then it opens up a lot more options.
This appears to be KD’s P60 style 501b http://kaidomain.com/Led-Flashlights/KDLITKER-E6
In your price range for a quality light all I can think of is maybe a Nitecore EC20 or maybe something offered by Surefire
