Finding remarkably little information on compatibility for diffusers. I'm trying to acquire diffusers for my D4S and SP36.
I've found old threads mentioning the Convoy #36 diffuser being a great fit for the D4S. Unfortunately this diffuser doesn't seem to be available anymore.
Fenix AOD S, M, L series diffusers are readily available but there is very little info out there on compatibility with non-fenix lights. Sofirn is selling several diffusers but there is very little info on compatibility with other products.
Is there a list anywhere of compatible lights for these common diffusers?
Cut off the bottom 1/4”–5/16” of the diffuser. Since the sides of the diffuser are slightly tapered, this will expose a smaller inside diameter. I haven’t actually tried it yet, but I plan to.
I checked today how this diffuser (for mt07/mf01 mini) works on D4S. It fits almost perfectly, but is loose. If you flip the flashlight it falls down. It works only if put on and stand vertically.
And what do you think about it? OTR silicone diffuser (37.5mm).
In the picture it is showed on X5, whose head diameter is 40mm. The head of the D4S is 39mm.
This one should fit perfectly. I think I’ll order one.
