Test/review of Golisi IMR18350 1100mAh S11 (Black) 2019
Official specifications:
  • Nominal capacity: 1100mAh
  • Maximum discharge current: 11A
  • Nominal voltage: 3.7V
  • Discharge cut-off voltage: 2.75V
  • Charging cut-off voltage: 4.20 +/-0.05V
  • Internal resistance: <40mOhm
  • Cycle life: >800 cycles.
This is a high current 18350 Liion cell from Golisi.
The two cells do not match perfectly. They can deliver 10A, but at 15A they are overloaded.
Conclusion
This is from the new generation of 18350 cells that has good capacity and can deliver a lot of current.
Notes and links
The batteries was supplied by Golisi for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Thanks HKJ!
Still not as good as in 2017…
Thanks HKJ!
