As the title says Im looking for a 26650 flashlight with the following specs:
- 1.000 lumen or more
- either a visual step down of output as the battery voltage is running low OR a voltage reading function OR both
- thermal regulation would be a +
- throw with a good amount of spill
- side switch would be a +
- runtimes on moderate output levels should be good
- user interface should be relatively easy (as its for my father) - but I think Anduril would be okay as well as you dont have to use all of its functions
- the size of the flashlight should be a EDC size (doesnt have to be too small, as it could be worn in a holster)
I really like 26650 lights that are small and fit the hand well. This is a very good mix of flood and throw, indicates battery well through the leds under the optic and manages heat well.
Astrolux MF 01 Mini would be a light to look at, although it is a little larger then the D4SV2… but has USB C charging - no need for a special Li-ion charger, it works like a phone. Very neat light. I cannot speak of reliability as it’s very new though.
The D4SV2 is certainly one of the best compact 26650 lights too.
