What are you trying to light up? Xhp50, xhp70? Single li-ion? Aliexpress has some good ones for xhp’s. Kaidomain has some good ones. Mtn electronics Boost drivers has the best ones but they are double the cost of the Chinese ones and always backordered. Taskled Taskled will have the best ones for high current, but they’re also expensive. Boost drivers usually run at the LEDs rated current, but the pull from the battery can be as high as 10A as the voltage drops.
Hmm interesting, none of my text showed in original message. Xhp70.2, single 26650. I’ll look into the options you provided, thanks for the feedback!
Good, pretty and cheap: Manta Ray ∅22mm XHP70x boost driver @ DanceLite
Suffice to say I would bypass the springs or swap them with high current ones.
You bet!
