mrsdnf's machine made 7th Annual BLF/OL contest entry. Updated and finished from post 6.
48 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 5 hours 18 min ago
Just to be open these lights were posted on another forum, no not that one Smile , with intentions to post up here when the time came. This is more a story on how the lights in this build came to be.
Time is short these days, not sure why but must have something to do with rapidly turning grey.
As some of you know my other passion is motorbikes of which I have spent most of my recent spare time sitting on the saddle travelling to different parts of Australia hence the time spent building torches has rapidly diminished.
The bike itself is a SWM Superduel and has just turned over 15,000 Km since February this year.
It has one of the worst headlights on any bike I’ve had the pleasure of riding so an update was needed for better light output.
Firstly the standard H4 Halogen globe was updated to a brand name item promising far greater output. Yeah right.
The headlight switches were rewired to turn PCB mount micro relays on and off from power taken directly from the battery.
If there was any gain it was minute but this relay mod allowed me to mount up some driving lights.
Picture of the relays. There’s three here. High and low beam along with the driving light relay.
Jaycar, a local hobby electrical store, had some old stock MTG2 led lights on special for $30.00 dollars each. These run at about 2.5 amps. For the price and light output these were a bargain.
Mounts were made up and the lights installed. All was good in the light world.
As usual the itch for even more light needed scratching and watching lostheplot build his driving lights I decided l had to get rid of this itch once and for all (maybe) by building my own driving lights.
A list of parts was made and the purchasing begun resulting in this stash of parts landing on my work bench.
The reflectors are Illuminations Machines XML 4. This reflector was tested with the XHP70.2 led to make sure it was suitable which it was. The opening is 70mm in diameter. This is a four degree reflector and is also made as a ten degree reflector. An option if I want more flood than throw.
A couple of polycarbonate lenses custom made for me by lostheplot will keep the reflectors clean.
The drivers are from Russia compliments of Fleabay and should drive the 6 volt XHP70.2 at a moderate 4 amps each.
The XHP70.2 LEDS are 5000K and mounted to direct thermal path copper 20mm MCPCB’s.
The relays are tiny PCB mount, from memory each can handle about 30amps.
And finally a sketch of the internal dimension of the reflector end of the housing.
Moths escaped from my wallet as the credit card was swiped to purchase 300mm of 90mm diameter solid aluminium bar.
Two pieces 65mm in length were cut and one end faced off.
The internals were machined to suit the reflector
and the external was machined to the bezel thread diameter and the bezel thread machined.
A threaded mandrel was needed to hold the head while the opposite end was machined.
Some of you may remember the headaches I had building another torch with lots of scrap made.
It was the piece on this torch with the copper holes and slots.
The above piece was machined into this
for this. Now the bum end of the head can be machined.
The bezel was the next step. A piece of the 90 mm aluminium was cut long enough to make two bezels and machined out to the smallest diameter on the bezel.
The inside was stepped and threaded to suit the head and lens. An o’ring groove was machined into the step to seal the lens from water entering.
The completed bezel was then parted off and the second bezel machined up. The finished item is shown here threaded to the head.
The heads were then placed into the mill to machine the wire through holes and screw holes to hold the MCPCB down.
Bugger. All these holes are 2.5mm out so will be have to be re drilled. At least the head will be slightly lighter.
As all the wiring on the driver are all on the one side a separate housing will bolt to the back of the head to house it. this is the start of the housing. Its from memory 50mm in diameter.
The housing was placed in the mill for the mounting bolt holes and gland thread drilled and tapped. To the right of the centre you may just see where I have marked the centre of the driver pocket which will be machined in the lathe.
The housing was then flipped so the holes could be countersunk.
The housing was then placed in the four jaw chuck and the previously mentioned driver pocket mark aligned centrally.
The nearly finished driver housings.
Back to the mill to machine cooling fins as the chips on the back of the driver will be heatsinked to the housing.
The heads were then profiled on the outside.
A mandrel was made up to sit in back of the head to hold the head steady while flats were machined to allow the mount bracket to sit flush with the head and the bottom was also machined to allow the light to sit lower on the bike.
You will notice the extra lightening holes in the head in this picture. Facepalm
The heads are back in the mill held by the dividing head ready to have the fins machined. The grooves are 6mm in width while the fins are 4mm in width.
And we have one head finished.
The bling shots.
The driver housings. The driver mount screw holes are 2mm.
Bezels.
And finally the heads.
TBC. LOL
Edited by: MRsDNF on 11/23/2019 - 16:37
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 hour 8 min ago
Off to a flying start. Your builds are always fantastic Love
G0OSE
G0OSE's picture
Last seen: 9 hours 48 min ago
Staggering. This looks amazing so far! I just love machined stuff, I guess any guy or girl who like lights does though , tactile metal stuff is awesome.
Can’t wait to see it/them finished!
CRX
CRX's picture
Last seen: 2 min 56 sec ago
Great to see a master masoch… machinist enter again Big Smile Thumbs Up
MRsDNF
MRsDNF's picture
Thanks for the kind comments.
The only master in this household is she who flays the whip. Silly
MRsDNF
MRsDNF's picture
And now for the final assembly.
The two chips on the back of the driver need to be heat sinked. This is achieved by machining the driver pockets to leave a thousands of an inch clearance when the drivers are in place. This clearance is taken up with AS 5.
The drivers were installed into the housing and the wiring soldered into position.
Before assembly the lights were tested. For once there was no magic smoke. Phew.
And tested again when assembled. All joins had o’rings in place to keep the water out. The two 5mm cap screws holding the driver housing in place had small o’rings under the heads that sat in a small recess in the housing.
The best type of pawn complete with dirty fingerprints. The 6mm thread holes for the mounting brackets are Helicoils (steel thread inserts) for strength. The wiring in the gland was permanently sealed with JB weld.
And finally a couple of pictures with the driving lights in their natural environment complete with bugs.
MRsDNF
MRsDNF's picture
Night shots. Did we get close to what we set out to achieve?
Camera settings for the night shot was aperture 2.8, shutter speed .5 second and ISO set to 400. What the pictures show is pretty close to what you see.
These driving lights were compared to the driving lights below.
Firstly a cheap set of lights from China. I have no idea what these cost as lostheplot gave them to me.
The Jaycar lights with MTG2 leds.
Firstly the standard bikes low beam. It really is this bad.
My bike came fitted with small day time running lights (DTRL) which can be seen in the last picture in the above post. These work really well in assisting low beam at night which makes low acceptable.
Standard high beam. Its criminally bad.
High Beam DTRL.
High Beam DTRL Chinese DL.
High Beam DTRL Jaycar DL. These are not a bad driving light.
High Beam DTRL XHP70 DL.
I’m more than happy with the performance. Riding at night is now a lot safer than using just the standard headlight.
Heat is not an issue so I wonder if the Russian could make a 6 amp version of this driver. LOL
djozz
djozz's picture
Last seen: 1 hour 50 sec ago
Thanks for the enjoyable write-up Smile
Super-cool lamps for your bike! I bet you will get many questions and compliments when you are on the road! Do the beams have the profile that you expected? Edit: ignore the last question, you just posted the nice beamshots.
MtnDon
MtnDon's picture
Last seen: 4 hours 6 min ago
Nice bike lights! It is always so nice to see where one is going. How did we ever manage back in the 60’s? Thinking of all the lousy lights on the old British bikes. Of course I also think my eyes saw better back then.
MRsDNF
MRsDNF's picture
I agree Don. In the early eighties I replaced the standard insert in my RD headlight with a Cibie insert. The headlight went from mediocre to wow. If Cibie could build decent headlights back then there is no excuse for building crappy headlights today.
No one knows any difference djozz. No questions or otherwise though I have not had them on that long.
MtnDon
MtnDon's picture
The first thing that impressed me about the first Honda 50’s was their headlight. Made the Ariel look anemic.
Watermanchris
Last seen: 8 hours 18 min ago
Great build! Congrats!
Not only are they amazing performers but the machining is gorgeous!
CRX
CRX's picture
Nicely made custom lights and practical too, great to see how they will be used, the comparison and knowing they will improve your ride Thumbs Up
DB Custom
DB Custom's picture
Last seen: 7 hours 39 min ago
Outstanding to see what you are capable of these days Steve! Brilliant!
moderator007
moderator007's picture
Last seen: 3 hours 52 min ago
Orsm custom bike lights Steve Thumbs Up . Very nice upgrade, you have a eye for functioning detail.
Alot of time when into building this, I applaud your effort and skills, well done Wink .
The driver looks like it has 2 current limiting resistors marked R240 and R160, assuming low and high beam.
Lowering each to about half should about double the current on each, estimated guess.
pommie
Last seen: 5 hours 40 min ago
What can I say that has not been said Beer
Cheers David
Nothing to see here folks, move along...
MRsDNF
MRsDNF's picture
These are the drivers here moderator007. No modes on this driver, just different outputs.
I forgot this driver put out 4.8 amps. Had it in my simple mind it was 4 amps.
https://www.ebay.com/itm/LED-driver-LDRADJ29-4-8A-4-8A-DC-6-5V-28V-Multi...
moderator007
That’s a interesting buck driver. Output current settable by jumper pads. Those 2 resistors are for setting the other 2 output currents apparently. Even has infinite variable output using a 250k pot. Very nice driver with good effeciency. Nice find Steve.
I don’t see anything that limits the max output, assuming the buck controller is maxed out. I’m no expert though.
I may order a couple just to check out. Thanks for the link.
DBSAR
DBSAR's picture
Last seen: 3 hours 36 min ago
Awesome work! Thumbs Up
G0OSE
G0OSE's picture
Is that Pinkpanda’s Roadhouse? Silly
That build is fantastic MRsDNF (and so is the bike! super jealous!) well planned, well made, look gorgeous and you certainly can’t argue with the end result – they do exactly what you wanted them to do!
CNCman
CNCman's picture
Last seen: 8 hours 1 min ago
MRsDNF wrote:
These are the drivers here moderator007. No Beer modes on this driver, just different outputs.
Very Nice Work Machining, Design, and Implementation of your Bikes upgraded lights. Thumbs Up
It is fun to have an idea and make adjustments on the fly as needed. Big Smile
Thank You for sharing that driver and led info, I have a zoomie that may use that one mode 4.8A driver. Beer Beer
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
Joshk
Joshk's picture
Last seen: 4 hours 32 min ago
Cool Smile
CNCman
CNCman's picture
MRsDNF, Just looking over all your posted pics. Such a nice job, I really like that Mastech HY3030e power supply.
Is it a switching or linear and will a switching Power supply do for checking driver setup on bench testing ? Thumbs Up
pinkpanda3310
Lol, they come in all shapes, sizes, flavours and colours dont’ they.
Looks like a mighty improvement for night riding. Safe riding Moose.
MRsDNF
MRsDNF's picture
CNCman wrote:
MRsDNF, Mastech HY3030e power supply. Is it a switching or linear and will a switching Power supply do for checking driver setup on bench testing ? Thumbs Up
Not that either means anything to me it is a Switching PS. One of the best things I’ve bought and had it for along time now.
Tally-ho
Tally-ho's picture
Last seen: 1 day 3 hours ago
Really nice design and rock solid custom built lights. Thumbs Up
MRsDNF
MRsDNF's picture
Thanks Tally-ho. See ya. Blushing
Hoop
Hoop's picture
Last seen: 4 hours 5 min ago
Wow MRsDNF. It looks like a whole lot of careful effort went into these puppies. And it also looks like you can really light up the road. Thumbs Up
I must’ve been absent when you built that light with the copper inserts and slots. I had not seen that one before. It is beautiful.
MRsDNF
MRsDNF's picture
Thanks Hoop. I look at some of the lights I built and wonder how they ever happened. Must be getting old. Well getting older. Facepalm
lostheplot
lostheplot's picture
Mrsdnf well done , again, and again
I must say they came out unreal.
+ 1 on the Russian making more powerful drivers.
sorry all images down
thanks photobucket
FlashPilot
FlashPilot's picture
Last seen: 14 hours 13 min ago
Hi MRsDNF! What amazing skills and attention to details you have! Thank you for sharing your build and posting beam shots. How are your flamethrowers holding up so far? The output is simply amazing and Im very jealous!
Ive long been thinking about a high powered compact lighting system for my touring bike (which has a 70 amp alternator to power all the gizmos Ive added). What is your opinion about the Jaycar lights you once used? Im looking for a great light housing that can disperse 100 watts of heat through an XHP70.2. Do you think the Jaycar would be a good choice for the XHP70.2 conversion? Do the housings have thermal capabilities up to the task of exchanging 100 watts of heat energy (thick floor plate attached to the cooling fins, sufficient mass/surface area, sold robust housing, etc.) What about the beam pattern with the 70.2? Do you like the reflectors? If you’re not sure… no biggie. Wink
Ive contemplated going with CPU heat sinks with mounted 12 volt fans and elliptical TIR optics to put all the light on the road and guarantee heat transfer from the emitters. But Id have to use epoxy to cobble it all together and make it waterproof. Only the front of the optics would be visible, so it would remain compact and wouldn’t be that noticeable while still looking decent.
Let me know if you’re still interested in a more powerful robust driver solution. I bought some custom linear automotive drivers from a guy on CPF who builds them (I assume he still does). They were about $30-35 USD each as I recall. They are hardened to deal with transient voltage spikes alternators throw off, have voltage protection cut-off set at 15VDC, ramping independent remote thermal protection for both the driver and heat sink, output 13.5A (so theoretically 190.5W at 14.1VDC). Also capable of accepting remote potentiometer leads to adjust output. But because it is a linear driver, its most efficient while ran at max output. Anything less is converted to heat and must be sinked through the FET. Id probably mount the driver in a small cheap aluminum box with the large FET glued to the side to keep it cooled. That, or possibly use a spot on the aluminum bike frame for the FET heat exchanger. This driver with a pair of XHP70.2 emitters on 12V MCPCBS in parallel should be sufficiently bright… but now I need to find the best way to make it happen.
Sheesh! Can I just “barrow” your lights and call it good? Silly
Thank you for reading!
