BLF LT1 Lantern, Whining, Ranting about USB C port issues go here.
80 posts / 0 new
MtnDon
MtnDon's picture
Last seen: 1 hour 21 min ago
We all know about the issue. For now it is what it is.
BLF Member Map Add your name and location.
Stittville Ed
Stittville Ed's picture
Last seen: 6 hours 11 min ago
For anyone with a problem about the charging options if you do not like the way it is now just do not order the Lantern.
People going on and on about things like this will make others stop following this Forum.
aginthelaw
aginthelaw's picture
Last seen: 3 hours 31 min ago
They’ll be corrected when the orange one hits the market. That’s when I’m jumping on it
never fear shadows…it means a light shines nearby
jon7
Last seen: 3 weeks 5 days ago
Would anyone be able to post a summary of the problem and workaround? I searched the main 300+ page thread and saw some references to the issues, but nothing specific. That would definitely help those of us who haven’t been following this. Thanks!
SIGShooter
SIGShooter's picture
Last seen: 1 hour 37 min ago
What I have a hard time with is the ongoing harping over it when Sofirn has said that they are going to add it to the LT after it has been completely tested. The ones already completed are not going the have the change retrofitted but at some point it will be in newly manufactured ones.
If someone must have the USB-C fix then don’t buy the lantern, wait until it’s in production, or find another lantern that has it and all the other features in the LT.
In my opinion Sofirn has been very responsive to making changes, and it’s not as if a changed can be implement in just a day because people feel it has to be.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
Yokiamy
Yokiamy's picture
Last seen: 8 hours 7 min ago
Charging 2A is more than enough, thats 500 mA per cell. i use laptop pulls with my LT, so i’m more than happy.
Actually, that is the main reason i just use an 1,5A charger with my phone as well, i never use the USB-C PD charger with it (it delivers 3A !) It will charge my phone very rapid, as well as the rapid deterioration of the battery.
djozz
djozz's picture
Last seen: 6 hours 46 min ago
The problem, for some, is when a genuine USB-C source is used that uses the correct USB-C protocol, the lantern will not charge because the charger does not get the correct feedback from the lantern. The simplest solution for that is adding two resistors on the lantern driver, apparently a USB-C charger then measures a correct resistance and starts charging.
For others it is no problem because if you have any USB-A source and use a USB-A to USB-C cable (one is included with the lantern), the charging works, because USB-A does not need feedback from the device to start charging. Most of us have multiple USB-A chargers around.
An argument for correct USB-C compatibility is that although now it only a problem for a few, maybe somewhere in the future dumb chargers may become obsolete and then we can not charge our lantern anymore from any source and need to keep a dedicated (USB-A) charger around especially for the lantern.
For perspective, quite a few flashlights from various brands are around now that have a USB-C type port and none use the correct USB-C protocol, they all assume that you use a dumb charger.
amishbill
amishbill's picture
Last seen: 2 weeks 6 days ago
USB-C power bricks don’t provide any power unless they see a special resistance pattern from the powered device.
A power consuming device tells the power source to provide basic USB power when USB-C lines CC1 and/or CC2 are connected to ground through a 5.1k Ohm resistor. (if you connect both lines, each one needs it’s own resistor)
There are two workrounds, not including using a USB-A power source.
1- Use a C to A adapter, and plug the lantern’s A to C cable into that.
2- Open the lantern and remove the driver board. Attach a 5.1k Ohm resistor between ground and one or both CC1/CC2 lines on the back of the lantern’s USB port. If you connect both, you must use one resistor for each line, You cannot piggyback both CC1 and CC2 onto one resistor and expect it to work.
Note: I’ve seen some references to the Raspberry Pi 4 folks only connecting one of the CC lines and that being enough to get power from a USB-C power source. The ‘proper’ answer seems to be using two resistors and connecting both lines. I can’t tell you if one line will work with your cable and power brick, which single line will or will not work, or if it will only work with one side of the USB-C cable up, or if it will turn your lantern into an invisible pink unicorn.
This is purely a DIY, proceed at your own risk situation.
I have plenty of resistors on hand. I’ll probably post pics of what did (or did not) work for me once I get a lantern to work on. Odds are someone else will beat me to it though.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 16 hours 29 min ago
So to be clear, the USB-C issue isn’t a potentially hazardous/destructive one like in some other recent USB-C lights? Just that it won’t charge with a C-to-C cable?
amishbill
amishbill's picture
Exactly.
mgracia85
mgracia85's picture
Last seen: 2 hours 57 min ago
Is this just for the first batch of lights?
I love my wife’s toy poodle
Stereodude
Last seen: 1 month 4 weeks ago
At least the first two. We don’t know when LT1’s with this fixed will be released.
will34
will34's picture
Last seen: 3 days 21 hours ago
The main issue here is people thought the USB-C port was chosen for wide compatibility hence they expected it to be correctly integrated.
Wrong….
The USB-C port was chosen over the Micro USB for DURABILITY and reversible plugging, and the only thing that’s changed is that now instead of using a micro usb cable to charge, you’d have to use a USB A to C cable to charge.
Trail Trek
Trail Trek's picture
Last seen: 1 week 4 days ago
I use a type-c to type-c in my car to charge the phone but i have tons of type-A (the fat end) to type c in the house so this would not have been an issue.
I suppose i can see some the issue in a one wire only setting. i have a type c powerbank and in order to charge my type-c items fast i use a type c to type c cable so it uses power delivery (pd) to negotiate a high charge rate. Sometimes i go camping and only take that cable so i can charge, phones, laptop, gopro etc so maybe in that very specific scenario i would not be able to charge. But if they are fixing it anyway im super happy.
spinynorman
Last seen: 5 hours 44 min ago
A non-protocol compliant USB-C port turned me into a newt!
f0xx
f0xx's picture
Last seen: 1 day 1 hour ago
Finally! A place I can come and vent about how this lantern doesn’t provide all the features that are included in the USB C spec. I’m mostly upset that MHL, Display port, and HDMI aren’t implemented correctly.. I wanted to hook this sucker up to a projector! Forget about storing photos on it as well, it doesn’t appear that they managed to get that working.
It seems that if I use the included cable it will only work with most of the USB ports in my home, car, and office.
BurningPlayd0h
I have a bunch of USB-C devices and don’t even have a C-to-C cord yet lol. All of them have included C-to-A cables, so I wonder how many consumer devices are actually following the standard?
C is becoming very common in the US and the more sturdy connectors that aren’t uni-directional are a HUGE benefit and easily reason enough to not have micro-USB the way I see it.
Couchmaster
Last seen: 1 day 11 hours ago
LOL, thanks for the uplift:-)
Sparks65
Sparks65's picture
Last seen: 10 hours 51 min ago
Thanks, f0xx that was great!!!
jon7
Thanks for all of the info! Unfortunate that they implemented USB-C charging incorrectly, but honestly most devices implement it incorrectly so I think most people are used to that!
anonymous_user
Last seen: 15 min 28 sec ago
I think some manufacturers default to USB A to C for compatibility reasons. Many people have plenty of chargers and computers with USB A ports. The device itself could still support USB PD properly. And yes I know the obvious answer would be to just include both types of cables.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 4 days 14 hours ago
I think for all LT1 lanterns of batch #1 and #2 this following picture should work:
xevious
xevious's picture
Last seen: 1 day 13 hours ago
Terrific diagram that makes it very clear. Thank you! Thumbs Up
pooptoast
pooptoast's picture
Last seen: 1 week 1 day ago
Thank you Lux-Perpetua, great diagram. I’m sure there are still some people who will whine about their USB-C purity but I simply cannot comprehend how this is a dealbreaking issue when the workaround is so damn simple.
Stittville Ed
The HDMI will be in V90000000000, can’t wait to use it Smile
Yokiamy
Yokiamy's picture
Trail Trek wrote:
I use a type-c to type-c in my car to charge the phone but i have tons of type-A (the fat end) to type c in the house so this would not have been an issue. I suppose i can see some the issue in a one wire only setting. i have a type c powerbank and in order to charge my type-c items fast i use a type c to type c cable so it uses power delivery (pd) to negotiate a high charge rate. Sometimes i go camping and only take that cable so i can charge, phones, laptop, gopro etc so maybe in that very specific scenario i would not be able to charge. But if they are fixing it anyway im super happy.
What car are you driving? Never seen a car with USB-C built in (yet)
DBSAR
DBSAR's picture
Last seen: 12 hours 8 min ago
Wrong….
Exactly. The LT1 was not designed, or intended to have the “fast-charging” high amp protocol, we only went with the USB-C type port for the durability and the fact that it can plug in in any direction. (easier in the dark) The LT1 is set to be charged at either the 1.5 amp default or set to a 0.75 amp charge rate to allow the ability to charge from weaker, low-amp power sources such as small Solar chargers, small power banks, lower power car & RV USB power ports, and so on. Unlike a phone, there is absolutely no reason that the LT1 needs a 3+ amp charge rate. even at the 0.75 amp setting there is plenty of time in a day to charge it when its not in use, also for the added benefit of longer cell life when being used in off grid situations where the lantern will be used every night & charged every day possibly, (365 days a year)
Stereodude
DBSAR wrote:
Exactly. The LT1 was not designed, or intended to have the “fast-charging” high amp protocol, we only went with the USB-C type port for the durability and the fact that it can plug in in any direction. (easier in the dark) The LT1 is set to be charged at either the 1.5 amp default or set to a 0.75 amp charge rate to allow the ability to charge from weaker, low-amp power sources such as small Solar chargers, small power banks, lower power car & RV USB power ports, and so on. Unlike a phone, there is absolutely no reason that the LT1 needs a 3+ amp charge rate…
None of which have anything to do with the mistake in the USB-C implementation. No one is complaining that it doesn’t charge at 3A. They’re complaining that it doesn’t charge.
dealgrabber2002
Last seen: 2 hours 51 sec ago
Any have an estimate runtime on the default step brightness for 3rd, 4th, and 5th (brightest) mode on 4 tested 3000MaH batteries? I just want to get a rough idea.
shirnask
shirnask's picture
Last seen: 3 hours 41 min ago
There was no mistake
Stereodude
So it doesn’t charge with many USB-C chargers that are compliant to the USB-C spec by design?
You guys should just stop digging… Facepalm
