Convoy S12 vs M21B Differences?
17 posts / 0 new
wacki
Last seen: 1 day 8 hours ago
I’m looking at the Convoy S12 vs M21B
What’s the difference? Is it just one has 3 LED’s and the other only has 1?
What’s the pro & con of that?
Any other differences? Both have use a 21700 battery.
“Relevant BLF thread”: http://budgetlightforum.com/node/64374
Convoy M21B
Convoy S12
Cereal_killer
Cereal_killer's picture
Last seen: 2 weeks 6 days ago
From what I can tell, in addition to both being 1×21700 lights they both have the same driver and similar bodies but don’t underestimate the difference the optical setups will cause, in use these will be very different lights with very different beam patterns. There’s also color rendering differences and efficiency differences from them having different led’s…
The triple sst-20 S12 will have a less throw cause of the 3 tiny reflectors, it’ll also have “pedals” in the beam pattern from where the 3 reflector cups overlap creating a non-round spill beam. It will, again because of the sst-20’s have much higher CRI (up to >95CRI depending on which bin, I didn’t see that listed but you can usually specify when ordering from simon) and also because it has 3 of the most efficient led’s will stay in regulation longer and be more efficient overall and create less heat for a given lumen output.
The M21b with its sst-40 in a single larger reflector will have lower CRI but a more throwey, intense beam. It’ll also make a lot of heat especially at max (6A).
Both should have similar outputs (atleast visually it won’t be much of a difference lumen wise from 3xSST-20’s vs 1xSST-40)
wacki
Thank you.
What do you mean by “stay in regulation longer”?
So the only advantage of the single LED is
  1. more throw?
  2. And possibly a more even light distribution?
Less heat at max for the single LED doesn’t seem like an advantage if the triple LED can produce the same amount of light more efficiently.
Who is Simon? This light is available on aliexpress, banggood and many other sites. Should I buy directly from him?
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 6 hours 17 min ago
The M21B is significantly throwier. zeroair got something like 400m+ on his. It will also have less even light distribution since it is a single emitter light with a larger reflector:emitter ratio.
Simon is the owner and operator of Convoy. I would buy from the official Convoy store on AliExpress, although some of his lights are exclusive to BangGood (I think the M21B is).
Photonica
Photonica's picture
Last seen: 14 hours 5 min ago
There’s an M21B on the convoy store.
$22.29 SST-40 in 6500K or 5000K. I’ve been trying to decide between the M21A/C8+ vs M21B vs L21A. So many lights, so little allowance.
Quote:
PARAMETER Material: Aluminum Alloy LED: luminus SST40 with DTP copper plate Driver: 4 modes 0.1%-3%-30%-100%, max current output 6000mA, Temperature protection management inside Low voltage warning: Yes Reverse polarity protection: Yes Lens type: ar-coated glass Reflector: smooth Mode memory: Yes Tailstand: Yes Battery included: No Required battery type: 21700 or 18650 lithium (battery tube inner diameter 21.5mm) Required battery quantity: 1pcs Diameter(Head/Body): 35.7 / 27.1 mm Length: 141.5mm Weight: 120g
More Photons!
id30209
id30209's picture
Last seen: 4 hours 10 min ago
Photonica wrote:
I've been trying to decide between the M21A/C8+ vs M21B vs L21A.
Me too!! Do they both use the same 20mm driver?
WTB Titanium 4sevens Quarks & Jetbeam TCR1
echikongen
Last seen: 1 month 1 day ago
I had the same question. After digging I can say that M21A is slightly larger and more heavy compared to M21B. M21A has more throw.
M21A is the 21700 version of a C8+, while the M21B is the 21700 version of a M1.
Dalamar
Last seen: 6 days 10 hours ago
More leds with the same power is more efficiency. Probably like 25% more for 3, but it depends. I prefer multiled TIR lights for general use due to smooth wide beam, but they have no throw so they are useless for shooting or searchlights.
I doubt the light you are asking about will be smooth since it’s not TIR.
I only like high CRI, I have or have had in order of pref:
Fireflies E07 219B SW45
Emisar D4 SST20 4000k frosted lens (the lack of some preset levels kinda makes me want to rate it lower though...)
Jaxman E2L 219c 5700k (indoor use only due to color temp)
Jaxman E2L 219c 4000k
Klarus Mi7
Varmint removal (throw):
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k (3200ma)
Lumintop ODL20C
wacki
Does simon do any custom jobs? Like changing a flashlight out to orange peel instead of smooth? If so best way to contact him? “customer support” or something else?
Thanks!
Jack Kellar
Jack Kellar's picture
Last seen: 11 hours 44 min ago
Thanks!
He sure does. You can ask for specific emitters, reflectors, driver configurations, and even tail boot color Big Smile
Mocarny
Mocarny's picture
Last seen: 12 hours 11 min ago
I like my M21B very much, and S12 as well, or even more. It just depends on what you need. Nice neutral tint and much throw? M21B SST40 5000K. More flooded beam and high CRI? S12 with Nichia or SST20 4000K. But if you really want a flood beam from M21B, you can ask Simon to change reflector to OP, or if he doesn’t have it, you can also add Dc-Fix to make the beam more even.
You can ask him by clicking “Contact” on the product page, under the flashlight photo.
wacki
What is Dc-Fix? Edit, never-mind I found it:
http://budgetlightforum.com/node/62343
You guys are awesome
wacki
Bummer customer support said only smooth reflector.
BurningPlayd0h
There are only smooth available for the M1 and M21B, I think the M2 uses the same model of reflector as well.
Jack Kellar
Really? Wow. My M1 (purchased in 2017) has the OP reflector and I hadn’t even requested it, so I figured it was the default.
BurningPlayd0h
Interesting, I searched for an OP to put in my M21B and couldn’t find a single light in the family using it. I would guess they went out of production before the X-PL HI version (which doesn’t really need it) was released.
Hugh Johnson
Hugh Johnson's picture
Last seen: 5 hours 26 min ago
S12: Any opinions on choosing between 4,000k 219C and SST-20?
I think the Nichia will be floodier and run hotter. What about tint and total output? I’m also looking for some beamshot comparisons between the two.
