gChart's Hand Made entry - 7th Annual BLF/OL Contest
32 posts / 0 new
gchart
gchart's picture
Last seen: 2 hours 5 min ago
This is just a placeholder for now. I’ll likely just be brainstorming until after Christmas. Stay tuned!
2019-12-30 Update: I decided to make a model to confirm fitment and sizing. Details in post 21
2020-01-14 Update: PCBs ordered, parts received
  • PCBs have been created and ordered (using Oshpark’s After Dark service)
  • Qi receiver, TP4056, primary LEDs, and reverse-mount LEDs have been received
  • Brass strips have been picked up from my local Ace Hardware (who knew they have a nice assortment of brass and aluminum stock from K&S?)
  • Updated model created that’s even more compact
2019-12-11 Update: (some) parts ordered
I think I’m getting the electronics side of things refined, though I’m still mulling over the exterior.
  • I found and ordered a quite small Qi charging receiver coil that should fit nicely. It’s only a 3W charge, but that’s plenty for the 600mAh lipo battery
  • I ordered a few TP4056 charging boards that I’ll scavenge the parts off of and solder directly to my main board (for space savings and so I can integrate the charging status LEDs)
  • While browsing for the TP4056 boards, I ran across this interesting battery status module and was able to identify the IC it uses (HM1160). I was planning on using the ATtiny to drive some battery status LEDs, but this will be a nice discrete option that will find it’s way into other things (illuminated tailcaps using it coming soon!).
  • Lastly, I also ordered some 150mA 4000K 2835 LEDs. I used the 60mA version in last year’s flip lantern and they seemed to be pretty good. I’ll use an array of them in the front for a bunch of floody light.
I’m still debating about the backplate to which the Qi coil will mount. Carbon fiber would look cool. But I’m also thinking about a smoked (transparent black) acrylic/plexiglass so that you can see the coil.
2019-12-04 Update: General Ideas
I’ll go ahead and throw out some general musings that I’m rolling around in my head:
  • General form factor will likely be akin to the Nitecore TIP / TUP… rectangular / blocky and small
  • The light will be built around a 600mAh lipo that I have sitting around from ESP8266 / ESP32 projects
  • Since I’m using a built-in lipo battery, I’ll want onboard charging. I want to go USB-C since it’s newer and I want to support that factor (and that’s what my phone uses to charge), but I would really prefer the socket to be surface-mount without any thru-holes (due to aesthetics) and every USB-C socket I’ve seen uses thru-holes for support. So I’m on the fence between this and micro USB which appears that can be surface mounted without thru-holes. That, and the TP4056 boards are easier to come by in micro USB (there are some in type-C, but less common). I may have to get a board or two of each and just play around with them. I think I’m going to get a prefab TP4056 board, strip off the components, and put them directly onto my main board.
  • Another thought I had was that instead of messing around with the USB socket, perhaps embedding a QI wireless receiver coil (something like this)and wiring that directly to the TP4056… thereby eliminating the USB socket entirely. A little extra complexity, but it’d be pretty cool.
  • The shell of the light will likely be made from copper sheet / strips for a classy look… or maybe copper surround with carbon fiber sheet panel(s)? One of the side panels will likely be the main PCB itself – I’m thinking of using Oshpark’s new After Dark series, black and shiny copper.
  • I want the visible side of the PCB to be decorative with few, if any, traces visible. It will likely have programming pads (for UPDI), reverse-mount LEDs for indication and aux, and perhaps a touch-sensor pad. I’m really debating about mounting a thru-PCB tactile switch vs using a touch sensor for the switch. I feel like a touch sensor would be really cool, but then I’d need to lock it out all the time… I imagine the touch sensor would be accidentally activated in my pocket.
Edited by: gchart on 01/14/2020 - 11:35
gchart
gchart's picture
Reserved
CRX
CRX's picture
Last seen: 37 min 27 sec ago
Great to see you entering gchart Thumbs Up
pinkpanda3310
pinkpanda3310's picture
Last seen: 11 hours 7 min ago
If chart is brainstorming that sounds like it’ll be real technical to me. Good luck Smile
DavidEF
DavidEF's picture
Last seen: 2 days 17 hours ago
Looking forward to seeing what you come up with. I made my placeholder thread quite a while back, and still haven’t even started really brainstorming yet. Facepalm
- The YKK Philosophy
MRsDNF
MRsDNF's picture
Last seen: 3 days 1 hour ago
Popcorn at the ready. I know I’m going to Love this one.
G0OSE
G0OSE's picture
Last seen: 53 min 7 sec ago
Nice one Gchart, glad to see you decided to enter! Thumbs Up I hope there will be some of your aux led action!
gchart
gchart's picture
Photonica
Photonica's picture
Last seen: 19 hours 3 min ago
It would be interesting to integrate the QI coil into the appearance of the light if you’re going with a black and copper motif. If you’re planning on more than minimal current you probably won’t be able to etch it on the PCB, but putting it on the other side of the light in clear epoxy might be cool.
https://hackaday.com/2019/04/11/implementing-qi-inductive-charging-yours...
More Photons!
gchart
gchart's picture
I suppose I could make one side panel acrylic/plexi with the coil stuck to it from the inside so that it’s (1) protected and (2) visible. Interesting idea…
lostheplot
lostheplot's picture
I like the hand built lights amazed at what can be done.
sorry all images down
thanks photobucket
gchart
gchart's picture
2019-12-11 Update: some parts ordered (details in the first post)
Next up: creating a sketch of the body and circuit, order the pieces for the body
gchart
gchart's picture
Initial assembly sketch:
CRX
CRX's picture
Ideas coming together Thumbs Up
MRsDNF
MRsDNF's picture
Thumbs Up
gchart
gchart's picture
My thought with the two copper sidewalls is to have them layered with the inner being a couple millimeters shorter than the outer. That will create a shelf for the top and bottom panels to sit on. But getting the bends to match might be challenging. And I’m not sure how I’m going to stick everything together – solder the sidewalls together? Or use an adhesive? Kinda stuck on that part. Any advice is welcome!
MtnDon
MtnDon's picture
Last seen: 29 min 21 sec ago
I thought the double sidewall construction was going to end up with it being somekind of a battery using some sort of magical separator. Wink Facepalm
Seriously though, bending them together in a sandwich might be the way to get the bends to coincide. ???
What gauge metal?
BLF Member Map Add your name and location.
CRX
CRX's picture
Cut copper sheet to size and bend into the body shape, maybe use a forming block.
Clamp the inner copper to the outer when formed with a little solder paste and torch it.
gchart
gchart's picture
Thanks for the input. Thats kinda what I’ve been thinking, CRX. As far as materials, I’m thinking of ordering some copper strips online. Probably something like 2mm x 15mm for the inner strip and 1mm x 18mm for the outer strip.
gchart
gchart's picture
I wanted to get a feel for size and fitment before I started ordering strips of metal and PCBs. So I decided to make a scale mock-up.
I used Fusion360 and my 3D printer to make the model. But no 3D parts will be used in the actual build of the flashlight.
Legend:
  • Black: outer brass trim (I could find brass more readily than copper in the right size)
  • Blue: inner brass strip for making a ridge to mount pieces to
  • White, solid: base plate, likely smoked translucent acrylic
  • White, holes: main PCB with most circuitry
  • Gold: PCB with 8× 2835 LEDs (rated at 150mA, 4000K)
Shown with the battery, switch, and the Qi charging coil
Agro
Agro's picture
Last seen: 30 min 4 sec ago
Anything that would show the scale?
MRsDNF
MRsDNF's picture
The mockup looks really good. Is the switch about 5mm square?
gchart
gchart's picture
Here it is next to a 18650 and Tool AA for scale. The switch is 12mm square with a ~7mm diameter button.
Agro
Agro's picture
Small. Smile
MRsDNF
MRsDNF's picture
Thumbs Up
pinkpanda3310
Lookin good gchart
gchart
gchart's picture
Among other things (see the OP), PCBs have been created and ordered using Oshpark’s After Dark service (black substrate with clear mask).
Main board
LED board
MRsDNF
MRsDNF's picture
After dark for black magic?
They look good. Beer
gchart
gchart's picture
Black Magic, you know it!
I recently tried the After Dark for some tailcaps and they came out great. To take full advantage of the service, you need to tailor your design for it so that the traces look good (and potentially using copper for labels instead of silkscreen):
MRsDNF
MRsDNF's picture
Cool
pinkpanda3310
I’m somewhat jealous of your electronics skills Wink
