CNCman's entry to the 7th annual BLF/O-L contest [mod light category]( FINISHED )
52 posts / 0 new
CNCman
CNCman's picture
Last seen: 7 hours 53 min ago
What an honor it is to compete with you guys here at BLF. I wanted to compete last yr but was unprepared.
I’m kinda going out on a limb here entering this contest this yr because I have nothing to work with yet.
Last week I ordered Santa a Haikelite MT09R 3x XHP70.2 from Banggood using Fin17 discount code for $109.32.
It will be shipped 12122019, so maybe early 2020 it will arrive.
After ordering, I remembered there were driver problems looming over this light. So after researching on BLF, it was clear cheap MOFFSET on TA design driver. So in hope of salvaging this light, I contacted Lexel and he still had one, so it is ordered.
So basically this mod will be a driver upgrade and spring bypass and any suggestions from you guys.
Note: Haikelite suppliers were shipping subpar MOFFSET and TA was in no way approving this.
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
Edited by: CNCman on 02/09/2020 - 14:23
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 hours 7 min ago
Great to have you enter CNCman. Good luck with your entry Beer
Skylight
Skylight's picture
Last seen: 48 min ago
Sounds nice! Good luck with your build.
I assume you have ordered in the color temperature you like. Otherwise you could swap the leds as well.
If you want you could have a look under the MCPCB if there is enough thermal paste. I have got a Q30 where not the whole copper surface was covered with thermal paste, just a small part in the middle. The copper based thermal paste Haikelite uses should be good.
MRsDNF
MRsDNF's picture
Last seen: 6 hours 11 min ago
Its good to see you enter the world of fun CNCman. Beer
Agro
Agro's picture
Last seen: 26 sec ago
Aside from the venerable FET, MT09R is an excellent light, there’s not much you can do to improve performance.
If you’re after small gains:
  • I don’t recall if MT09R has bypassed springs. If no, you could do that
  • use as fat lead wires as you can
If you have a steady hand you may try to slice and dice the emitters. This will be a big improvement in throw at the cost of some 10%-20% lumen loss. Personally I really like sliced and diced LED mods, I feel they are well worth the effort and I haven’t seen one in MT09R yet. Smile
You may do some visual mods if you like as well. Smile
G0OSE
G0OSE's picture
Last seen: 55 min 34 sec ago
Great to see you are entering the competition Beer and am looking forward to seeing your mods!
CRX
CRX's picture
Last seen: 2 hours 28 min ago
Welcome to the fray! Wink Thumbs Up
moderator007
moderator007's picture
Last seen: 3 hours 38 min ago
Great to see you entering the contest CNCman. Thumbs Up
lostheplot
lostheplot's picture
subscribed
sorry all images down
thanks photobucket
CNCman
CNCman's picture
I may need to change to a different mod because the Haikelite MT09R I ordered has not been restocked and will not be shipped until next year.
Banggood said it would be shipped two weeks ago and when they changed the order page to “ Do you want another item at similar value “, I requested a refund. After chatting with Banggood again , they said it was now in stock, so gullible me reordered it again. Now it says its “ Out of stock “ again. So I will let it go again for a few weeks and see if the MT09R will ever be restocked.
Meanwhile back at the ranch…. I was able to squeeze in some time to make some parts for a MT07 Buffalo. If I can get the heatsink made tomorrow, that should be the last part for now. All the parts were made after the beginning of the competition. If its OK, can I switch to this Mod ?
CRX
CRX's picture
Sure Thumbs Up
CNCman
CNCman's picture
OK Thumbs Up
GREAT Thumbs Up
I am getting some pics ready.
Agro
Agro's picture
Buffalo host has a lot of potential as well. I have MT07S but I consider MT07 host to be much better. Smile
CNCman
CNCman's picture
OK, It’s on now. Sorry for the confusion getting started. I purchased this Haikelite MT07 just after joining BLF. This is my first big led light and I was inspired by you guys to buy it. This was an early version with the old XHP70 led and OP reflector. I really liked it at first, but after learning more, it was time to try to make it better. I ordered a SMO reflector just one month after buying the light. Just a few weeks ago, work slowdown has finally allowed opportunity to access machine time after work hours. After drawing this up on FREE 2D CAD from Seimens PLM, it was verified it will fit and do-able.
1
Guess I wanted a thrower and didn’t care for the OP reflector.
2
The FREE 2D CAD from Seimens PLM is easy to learn and use, best 2D I found.
3
The new and larger reflector needed to be measured all over for dimensions for clearance fits. Threads were 1mm pitch.
This process of drawing the parts you have in hand first and then fitting them together in a CAD program
takes the guesswork out of play and allows you to move forward knowing your parts will fit.
4
CNCman
CNCman's picture
I decided to machine the adapter first because it was 7075 aluminum and the easiest and quickest to make. Here the inside and outside diameters are milled with a 1.0 diameter, 2 flute HSS end mill.
5
Threadmilling the flashlight threads 82.5mm x 1mm pitch using a 6 flute single row thread milling cutter.
6
Threadmilling the new bezel threads 88.5 × 1mm pitch.
7
Cutting the adapter off the coupon, same as using a part-off tool on a lathe, using a 5 insert, 2mm wide, 63.5mm diameter grooving tool.
8
Turning the 14deg angle to 3.292 major inside diameter.
9
These are the dimensions used to machine the adapter. I had to measure the new reflector in detail and the Buffalo and allow for clearance fits for angles, diameters and thread fits.
10
Here is the finished product after hours of planning, designing, programming and about 1.5 hrs machining.
11
12
grin
Last seen: 2 hours 20 min ago
Haha Im a hack compared to work I see here, it gives me something to aspire to.
MRsDNF
MRsDNF's picture
That is simply orsm. Have to love NC machines not that I’d have a clue how to use one. Thumbs Up
CNCman
CNCman's picture
OK , next up is the new bezel. I made this from a piece of scrap 316 stainless steel. It is a very tough material to machine.
Here the 29deg front angle, face, and outside diameter were turned on a Monarch lathe. It is being parted off in this picture.
The tailstock is inside to catch it when it falls off.
13
Here the inside diameters are bored to finish after flipping it around to the opposite end.
There is paper between the chuck jaws and the outside diameter to protect the finish.
Notice the parallel and 2 magnets on the chuck face. That was done to extend the bezel away
from the chuck jaws so it could be faced to finish. The magnets are very strong and the RPM was kept very slow.
14
Here are the dimensions used to machine the Bezel. The threads were match fit to the adapter.
Unfortunately I broke an end mill while milling the inside diameter prior to thread milling and
was a bit rattled by that and forgot to take more pictures of the bezel threading. It is easier to thread mill
the metric threads than to do that on a lathe. Doing metric threads on a lathe can be very troublesome.
15
Broke an end mill right before finishing the Bezel. Forgot to change “Y axis” number in the program,.
And yes it left a mark on the inside diameter. But the 316ss is so tough, it still did not scrap it. Facepalm
16
And here is the finished Bezel.
17
18
There is the mark from the end mill. Oh well, nothing is perfect.
19
pinkpanda3310
Ouch. Looks like it could’ve been worse, though. Great progress since you got rolling Thumbs Up Looking forward to more Smile
CNCman
CNCman's picture
OK, here is the last part machined, a Heat-sink.
After mounting the 86mm reflector forward of the original position, a gap or space was created even with the longer reflector. So this created an opportunity to add more heat distribution. I had to draw this up on the fly on paper.
20
21
22
23
The copper is pressed in with .0005 interference press fit. Copper is very sticky and a light press holds good.
24
25
26
27
Finishing outside diameter and parting it out simultaneously. Left .007 thick and broke it out by hand.
28
Finished Heatsink at .290 thick.
29
30
mr_magoo
Last seen: 4 hours 36 min ago
Hey I learned something from you CNC man! I’ve never thought of holding a parallel to the chuck with magnets. Seems easier than bumping it straight with with a mallet and checking wobble with a dial indicator. And tool pressure doesn’t push it back when you have a light grip on thin parts.
I never got a chance to learn CNC machining where I worked, wish I did. I was always too busy doing repairs on manual machines for them to find the time.
CNCman
CNCman's picture
“ mr_magoo “
I recycled the two magnets from a trashed cheap headset someone threw away. They grip hard. Just keep the RPM low or it may come out. We also use a triangle shaped piece from flat stock we cut on a band saw that cannot fly out of a 3 jaw chuck and a X shaped for 4 jaw chuck.
Manual Machinists are harder to find today and pay more most of the time. CNC machinists today are becoming more like operators, button pushers and part changers. I started manual machining for many years before slowly doing both.
You never know whats around the corner, maybe you will. But if not, be the best at what you do now, smile and be happy Big Smile
CNCman
CNCman's picture
Ok , here is a fit check of the adapter, reflector, bezel and ar coated lense.
31
The new reflector is considerably larger, 86mm x 84mm vs 72mm x 68mm.
32
33
34
There were no machining done to the MT07.
35
36
37
38
39
40
41
The heatsink is not in yet, so the led is .290 below the reflector. Going to work that tomorrow Big Smile
Also it may need some focus adjustment, but I hope not much.
42
There is a lot yet to finish and I will need some help doing a LED swap to a XHP72.2 .
And any suggestions you guys have. Beer
MRsDNF
MRsDNF's picture
That is machining pawn at its best. Nice work Mr CNC. Thumbs Up
Agro
Agro's picture
Looks great so far. Smile
pinkpanda3310
+1 I love seeing machining set ups Smile
Very cool mod.
CNCman
CNCman's picture
Time to assemble and test. We will be making some additional mods if possible.
43
44
45
46
47
Is there a resistor mod that can be done with some improvement in output ?
48
Wow, it checked .287 thick core. That is approx .640 total under the LED.
49
50
51
I could not get any 12mm long 2mm screws in time, so ACE Hardware bailed me out with some 3mm x 12mm long screws.
So we drilled and tapped it to the 3mm x .5mm thread from the driver end.
52
53
54
55
56
57
I was hoping the focus was OK, it looked right, but…….
58
Here you can see a doughnut hole in the middle. Any suggestions how to stop this ?
This was a 4500k XHP70 LED i think, looks soft white on the wall.
59
pinkpanda3310
AFAIK that reflector is better suited to small die LEDs. I don’t think you can completely eliminate the donut with an mtg2.
Hoop
Hoop's picture
Last seen: 6 hours 14 min ago
Nice mod CNCman. Thumbs Up Changing the LED to an XHP70.2 and slicing and dicing it might be a good way to go to resolve the donut hole issue and improve output a bit.
CNCman
CNCman's picture
I thought that to pinkpanda3310, so after checking the reflector on Aliexpress, will this be ok for the XHP70 ?
CNCman
CNCman's picture
Thanks everyone Thumbs Up
Hoop, Yes that is a good idea so I will order one today. It should be here in time.
