BLF LT1M - LT1 Mini (link to project)
190 posts / 0 new
led_400
Last seen: 1 day 14 hours ago
I’m interested. Also agree that 21700 is the way to go
mr_magoo
Last seen: 4 hours 4 min ago
raccoon city wrote:
I’m very interested…
BLF LT1-Micro sounds great!
By the way, I would much prefer a 21700 host to a 26650 host.
Agreed with you on the 21700 size. No need for the extra diameter or weight in this case.
Maybe I should make a left turn and throw something together to test some concepts, and enter it in the Old-lumens hand made light contest at the same time.
firedome
Last seen: 7 months 1 week ago
Subscribed
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
RollerBoySE
RollerBoySE's picture
Last seen: 1 month 1 week ago
Design ideas could be taken from the Nitecore LA10 CRI and upscale it to take 21700, onboard charging and Andruil.
https://flashlight.nitecore.com/product/la10cri
Kindle
Kindle's picture
djozz wrote:
In my 18650 lantern mod I used a Philips bulb optic to spread the light coming from the underside. A similar optic could be used for this micro-lantern.
http://budgetlightforum.com/comment/1576561#comment-1576561
!{width:80%}https://i.imgur.com/9lyG4cEr.jpg!
That is gorgeous.
Dioda
Last seen: 18 min 3 sec ago
Im interested in more compact 21700 version too. LT1 is too heavy/bulky for me to carry in backpack.
CJ Avlis
Last seen: 20 hours 3 min ago
I’m interested in 2…especially 21700 format.
Unloco
Last seen: 10 hours 32 min ago
WOW!
Interested!
Forever
Forever's picture
Last seen: 57 min 36 sec ago
I’m interested. Something small with a 21700, 4000k and high CRI would be great.
Funzel67
Last seen: 1 day 59 min ago
Also interessed but more in 26650 format. Should give a more robust stand due to better diameter / height ratio.
MtnDon
MtnDon's picture
Last seen: 54 min 17 sec ago
Stability when standing the lantern on the end is important. However, I don’t believe that is alone is a good enough reason to choose a 26650 cell over a 21700. Correct me if I am wrong but it seems to me that 21700 size cells offer greater capacities than any 26650 cells.
Maybe it is more important to use a 21700 cell for greater capacities and then just make the standing end of the lantern enlarged?
Thoughts on that???
DBSAR
DBSAR's picture
Last seen: 1 day 19 hours ago
Thoughts on that???
I agree on that the 21700 is a better (more modern cell size with 5000mAh capacity) choice, and the plan to have the LT1M with a magnetic base, will be easy to have a flat base stand that sticks to it included. (already working on it. Big Smile
Dioda
With 21700 we could achieve bit narrower profile. The final shape is very important at least for me, I would greatly like something similar to the recent Nitecore Campbank lantern, which is more or less flat and can be easily worn even in pocket.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 40 min ago
The Nitefox UW360 has that, a flat disc that lets the critter stick to it to stand upright on nonmagnetic surfaces.
Tixx
Last seen: 4 weeks 1 day ago
Very interested! Thanks
DBSAR
DBSAR's picture
That is the plan Thumbs Up
Trail Trek
Trail Trek's picture
Last seen: 1 month 6 days ago
Very interested, I also think 21700 would be preferable. In regards weight what is the current target if there is one? The reason i ask is that when wild camping weight is a key issue, i dont get to just take things out a car and walk 5 feet in a campsite.
Thank you DBSAR for all of your lantern work recently im looking forward to this one.
Scallywag
Scallywag's picture
Last seen: 15 hours 42 min ago
Thoughts on that???
Actually, Shockli’s 5500mAh 26650 cell delivers fantastic currents and also tends to test at or above capacity rating. Someone else sells it too, I forget who. To me it’s the best compromise cell, like a 30E. A 40T will get you higher drains but to me I’ll take the 1.7 extra amp hours.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
sbslider
sbslider's picture
Last seen: 2 days 19 hours ago
This light will not require a high drain cell.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Scallywag
Scallywag's picture
Exactly. Are there 21700s over 5000mAh like there are for 26650?
dekozn
Last seen: 4 days 6 hours ago
26650 is to heavy for backpacking. Even 18650 is considered to heavy for some of us. But pared with a 18650 headlight I might consider taking a lantern that runs on 18650 as I only need to take one type cell with me. There’s no need for long runtimes or high output an 18650 is more than adequate if you really want to design it with backpackers in mind. Also size matters while backpacking, make it as small as possible. No need for usb charging (how the hell you gonna charge it in the forest?) but could be useful.
Idiot proofing something only creates improved idiots.
FlashPilot
FlashPilot's picture
Last seen: 1 hour 3 min ago
I smell another 10,000 post thread in progress (with less than 20 posts worth reading) Silly
Count me in!
Might as well also start thinking about the LT1-Maxi with 100 emitters and 20 × 18650 capacity. Thumbs Up
And please maintain your health, that last one took its toll!
rom
Last seen: 3 months 1 day ago
I’m in!
Would be great if base would be FW3A with 18650 battery
emarkd
emarkd's picture
Last seen: 1 week 6 hours ago
Ok, ok. Put me on the list. _sigh _
Big Smile
specialk
Last seen: 11 hours 9 min ago
Count me in please.
fourbyfive
Man Without Shadow wrote:
I’m 4054 on the group buy list…when will I get my code?
Hehe, good one. I appreciate the loquacious sobriety.
KevinZA1988
KevinZA1988's picture
Last seen: 1 day 16 hours ago
Definitely interested…
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
DavidEF
DavidEF's picture
Last seen: 6 hours 30 min ago
Interested in this. If a suitable host can be found, I will gladly contribute a few dollars to get one sent to DBSAR for prototyping.
- The YKK Philosophy
Agro
Agro's picture
Last seen: 2 hours 44 min ago
Interested. There are too few details to tell for sure and I’d definitely like to know more.
h5550
Last seen: 3 hours 54 min ago
In for 1 Cool
