BLF LT1M - LT1 Mini (link to project)
190 posts / 0 new
Agro
Agro's picture
Last seen: 36 sec ago
DBSAR wrote:
Agro wrote:
In front add a regular optics and LED, so it’s not just a lantern but a flashlight as well.
Tube gives little space for the driver…unless you make a flex PCB (not very expensive now) and fold it inside.
Yeah baby, someone has similar ideas to mine:
http://www.aliexpress.com/item/32760825307.html
I have one like that atm, its very finicky, flickers a lot, and has some design issues. (added to the radiation-blue tint and built in charger that charged a cell to 4.32 volts.[/quote]
Bad implementation does not invalidate a good idea. Silly
DBSAR
DBSAR's picture
Last seen: 1 day 17 hours ago
I know, its just the quality of most lights of that style on the market need some major modifications or don’t work well at all.
Big_Sam
Big_Sam's picture
Last seen: 2 days 12 hours ago
I would support 21700….. because it means I can use 18650 protected cells! For those of us who only use protected cells, many 18650 lights are not useable….. FW3…. EDC18…..etc but 21700 lights can all take a 69mm keeppower!
JermsMalibu
Last seen: 14 hours 57 min ago
Would it be feasible to make it accept 2 CR123s in an emergency? It’d be nice to have a fall-back to those if one is out camping and the rechargeable battery dies. I already take a couple CR123s in a waterproof case for some other lights I have (that are currently running rechargeables) for “just in case”.
Also, I’d vote for more than just 1 LED (2-4?) in order to drive them at lower currents for more lumens. A few extra dollars up front for something that can run longer and cooler at a given brightness (vs a single LED) would be good. Either way, I’m excited to see this project.
Edited to add: I was thinking 21700 or 26650 size instead of 18650 which is why I thought of more than 1 LED.
DBSAR
DBSAR's picture
21700 is the goal with the ability to use 18650’s with a sleeve. as a lantern, it will pull less amps than a high-powered flashlight with a turbo that only runs for a minute or less, as lanterns run continuously for hours on end, meaning it will likely have a low-volt protection like the full size LT1, and being a low-amp draw it can run nearly any type of 18650 from old weak laptop pulls up to a 5000 mAh 21700.
The thoughts of having the tube made just large enough diameter to handle a 3-AAA carrier has been thought about, in that case which would add that extra battery versatility of even fitting a basic 3-AAA series carrier in it for that additional option in emergencies to use alkaline or Eneloops. (but not to charge them)
Big_Sam
Big_Sam's picture
That’s a good idea DBSAR, a 3xAAA carrier would be a good backup.
DBSAR
DBSAR's picture
I discovered if the inside of the battery tube of the Fireflies PL47 21700 light was just barely half a mm larger, a 3-AAA plastic carrier from any cheap 3-AAA flashlight fits it and works with additional longer springs.
amishbill
amishbill's picture
Last seen: 1 day 14 hours ago
I like this idea, but I also dislike it. Flexibility is always a good thing, but what would be the result of someone having this carrier installed and accidentally / ignorantly plugging up the charge cable? Cooked NiMH or popped alkalines?
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
MtnDon
MtnDon's picture
Last seen: 3 hours 24 min ago
I’m sure it would be possible to design a mechanism that would prevent that, but it would complicate things.
…. a keyway, a switch that is activated when the 3xaa carrier is inserted……. everything and anything is possible. Is it worth the effort?
DBSAR
DBSAR's picture
amishbill wrote:
DBSAR wrote:
… The thoughts of having the tube made just large enough diameter to handle a 3-AAA carrier has been thought about, in that case which would add that extra battery versatility of even fitting a basic 3-AAA series carrier in it for that additional option in emergencies to use alkaline or Eneloops. (but not to charge them)
indeed that is a concern.
DBSAR
DBSAR's picture
good points. Something to disable charging with a 3-AAA carrier in it.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 32 min ago
Those carriers have a pogo-stick nipple to make contact, no?
Make a small center contact for power, and a concentric ring around it for charging. Should make contact with flat-tops, but not with the carrier.
DBSAR
DBSAR's picture
good idea Thumbs Up
BrianCharles
Last seen: 3 weeks 6 hours ago
Put me on the list for three. (When the list is started)
KevinZA1988
KevinZA1988's picture
Last seen: 1 day 1 hour ago
Would it be possible to add red LED’s operated as a separate mode in Anduril? Perfect for keeping bugs away when camping or fishing. Perhaps deep red XP-E? They are relatively cheap.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Big_Sam
Big_Sam's picture
That would work, you could do a similar circuit to the yellow work lamps that take 18650 and AA, they have a series of diodes to prevent charging of the AA.
Big Clive has done a tear down and circuit
That way the LT micro could be a power bank too.
https://youtu.be/NAoISQaA5jY
DBSAR
DBSAR's picture
it is possible, depending on if it will drive up the cost of the lantern or not.
Tixx
Last seen: 3 weeks 5 days ago
Very Cool! I love battery versatility! Like the ZL SC80 and the CountyComm Single C and D lights that have AA and AAA carriers.
bikenber73
bikenber73's picture
Last seen: 2 weeks 1 day ago
I’ll take 2 please!
gottawearshades
Interesting. Count me in for at least one.
fourbyfive
Last seen: 1 month 1 week ago
Also thinking plastic should be considered due weight considerations, and also cost. Assuming reasonable durability, but the lighter it is the less force acting on it to cause damage.[/quote
I think going composite (plastic or something else) is the way to go. The cost of mold-making might make the project unprofitable however. I would think 5000 units or more would have to be sold to break out on it. Personally, I would not carry a metal flashlight on a backpack venture. As Colin Fletcher once said, “Take care of the ounces and the pounds will take care of themselves.” I cut toothbrushes in half and stuff like that. Nothing metal in or on my pack is how I go, if possible. I’m keen on the aaa batteries as a power option, or aa would be fine too. I can’t imagine carrying power bricks in a backpack.
As I mentioned earlier, I’ll buy anything with the BLF monicker because I like the looks and function of everything I’ve seen. If the mini lantern is too heavy for me, then I’ll surely find a use for it elsewhere. So carry on dbsar, I’m sure it will be cool. Check me for one at least.
Stittville Ed
Stittville Ed's picture
Last seen: 1 week 6 hours ago
Carbon Fiber
Ironhorse
Last seen: 1 week 3 days ago
Interested.
bikenber73
I just received this and like it a lot .
Something similar without the flashlight might be a winner !
https://www.amazon.com/Streamlight-Siege-Rechargeable-Lantern-Coyote/dp/...
gangstead
Last seen: 2 weeks 5 days ago
If you start an interest list sign up in in for 2 (at least!)
AgentWhiteBread
If it’s anything remotely close to djozz’s lantern mod from the first page I’m in for two.
DBSAR
DBSAR's picture
I am looking to find a good host to build a prototype to start from for a mini-LT1 ( or Micro-LT1) design.
Stittville Ed
So will you be doing a Micro and a Mini Smile
Just had to say that before anyone else.
DBSAR
DBSAR's picture
definitely will be, either a mini or micro, or both. Big Smile
Slayer1
Slayer1's picture
Last seen: 3 hours 4 min ago
Count me in for 1 pc.
