MF01 Mini / MT07- Mod/Upgrade - Copper Heatsink Cover Plate - 1st batch shipped - 2nd in production
288 posts / 0 new
man of light
man of light's picture
Last seen: 3 hours 8 min ago
For everyone interested, today I updated the post #1 and post #2 with some news on the Status and the 2nd batch.
Please take a look for the latest infos.
Gerrit
Last seen: 39 min 37 sec ago
It works great, done in 15 minutes. Thumbs Up
deus1ex
Last seen: 12 min 19 sec ago
Interest in one
Lexel
Lexel's picture
Last seen: 1 day 15 min ago
Thermal test now done
Test conditions:
driver temp sensor on PCB calibrated
set to 50°C
Full AMC heating at 2.4A
Time lapse x5 almost 5 minutes
I found that stock the Anduril firmware seem to quite regulating after first throttle, it may get into unsafe temperatures
In an assembled light a lot of the heat will be conducted away from battery tube, so the bare AMCs will stay a bit cooler
and the AMC heat spreader will stay quite a lot cooler than in this test
1. tested stock upper left
it seems after first throttle the temperature regulation quits and it heats up to 70°C on PCB
2. Aluminum prototype
lower left
3. production sample copper
middle upper and lower
gchart
gchart's picture
Last seen: 1 hour 6 min ago
Great comparison, Lexel. The clamp meter is a bit hard to read in the copper spreader test, but it looks like it stays around 2.4A perhaps? Aluminum doesn’t appear to be too far behind, but definitely better than running it bare.
man of light
Thanks for the test Lexel, great Job Thumbs Up
As expected, the temperatures on the copper version stays a bit lower than on the aluminum version.
Also the heat distribution between the heatsink and the head seems to be best balanced on the copper version.
Lexel
Lexel's picture
Yes with both heat spreaders in those 5 minutes the light ran constant, the clamp meter sometimes is acting bad not reading correct or fluctuating a bit, I may have to open it and clean
I am not sure how the temperature is affected in the total light assembly
with it the temperature is definitely a lot lower as the driver gets most cooling connection to the battery tube
But the strange behavior when thermal throttling should be history
Still it seems there is a bug in the firmware when it ran without heat spreader Anduril kept going almost at 100% while the light constantly heated up far behind the set point
moonstone4
Last seen: 15 hours 46 min ago
I am interested in 2 of them.
olles
Last seen: 12 min 50 sec ago
Thanks for making a second batch!
Olles
ZozzV6
ZozzV6's picture
Last seen: 2 days 40 min ago
man of light you can add my post link to the OP where I have images of thermal paste and silicone heat pad images added Wink
Alvaro52021
Last seen: 1 day 20 hours ago
Interested!!! How can i get one of those!?? Thank you
Alvaro52021
Interested in 1
man of light
Good idea Zozz, I’ve just added an alternative method of thermal contacting using thermal pads in the description of post #1 with a link to your post.
I also mentioned and linked the thermal test from Lexel in the OP.
Welcom to BLF, I’ve just answered your PM with some information and added you to the list of the 2nd batch.
nobody
Last seen: 1 hour 59 min ago
ZozzV6 wrote:
So you need to make sure you use enough thermal transfer materials and I suggest using 0,5-1mm silicone thermal pads cutted shape on the 7135 top.
Just for clarification (maybe I missed something), you have pictures with the thermal pad on top of the 7135 chips and a picture with the thermal pad on the bottom of the copper plate.  Do you recommend putting it in both places or is one better than the other?
ZozzV6
ZozzV6's picture
Not necessary. Those two pictures are two different try. Even if you add layers you make the thermal path worse. The second and current one is where I putted the thermal pad on the copper thing and cutted it exactly the shape it has. And I used thermap paste on the side of it. Then grabbed it with tweezers to put it in place.
nobody
Got it. Thanks.
mihlit
Last seen: 5 hours 32 min ago
Interested in 1 piece
MoreLumens
MoreLumens's picture
Last seen: 11 sec ago
Hmm so which one is better; thermal paste or with pads?
noboneshotdog
Last seen: 2 hours 49 min ago
Yes, please let us know. I was planning on paste…..
Thier ain’t no bones in a hot dog. F. York
gman7228
Last seen: 1 day 14 hours ago
Please put me down for two from the second batch. Thanks!
gman7228
There are 10 kinds of people in the world. Those that understand binary notation and those that do not.
ZozzV6
ZozzV6's picture
For me the combination of the two worked best this way:
MoreLumens
Im leaning on that option too, but I would need to get some thermal pads for that and the end result is that I would almost double the price of this light with all these mods. Totally worth it though, but still need to find good thermal pads. Anyone has some advices where to get some?
man of light
The heatsink plate is generally designed for usage with thermal compound paste, I would still recommend to use it this way.
Both thermal contacting methods will work well, if the installation is properly done and there will be no differences in the runtime performance or thermal effectiveness.
Good quality thermal pads are mostly more expensive than a high quality thermal compound paste.
MoreLumens
Ok then I stick with paste. Thanks for everything!
Malenurse84
Last seen: 3 hours 32 min ago
I will take 2 of them
freshnight
Last seen: 1 hour 46 min ago
I’ll take one !
Chinaheart
Chinaheart's picture
Last seen: 2 min 24 sec ago
 Interested...
Dr.Phillip
Dr.Phillip's picture
Last seen: 3 hours 45 min ago
I received mine, 3 pieces. Thank you man of light. Will install them after I flash it later. Hopefully I’ll post some pics as well. They look great! Thumbs Up
gecco
Last seen: 1 hour 34 min ago
If I have the lamp and the copper plate, I consider whether I should use a graphite cooling pad instead of the MX4 paste because of the mess when I open the lamp again, what do you think.
Graphite cooling pad should conduct better than a thermopad?.
What is the distance between the copper plate and the housing?
Imalent DX80, Astrolux MF04, Astrolux MF02, Mateminco MT07 Mini, Lumintop SD75/dedomed, Manker U11,
Ituo Wiz 20, Nitecore HC30, Skilhunt H03R, Nitefighter BT21mod, KD MJ-880 Clone, 8x Yinding, Nitefighter BT40 Mod, Solarstorm X2, Magicshine MJ 906, Magicshine MJ 902
Dr.Phillip
gecco wrote:
If I have the lamp and the copper plate, I consider whether I should use a graphite cooling pad instead of the MX4 paste because of the mess when I open the lamp again, what do you think. Graphite cooling pad should conduct better than a thermopad?. What is the distance between the copper plate and the housing?
Graphite pads are electrically conductive, might not be a problem in large CPUs where you just cut them short near the edge of the professor, but it might be a problem with this small AMCs. Plus it might be hard getting them to touch the copper and all chips without touching the PCB and any component they might short.
