Not cheap but not unreasonably priced.
The question is: could we get them cheaper on a GB? Most sources seem be gone. I remember seeing some UK shop though earlier this year which had good prices for large quantities but I fail to find them now…
I found also http://zoflex.com/products.html
They sell sheets.
Small sheet 152×152×1 mm is $35 + $11.5 shipping.
They have also larger sheets (304×304), 3 different thicknesses (0.5, 1, 1.5 mm), 2 hardness choices.
There are a few light makers that produce QTC flashlights:
Veleno
Peak
Fraz
I’ve seen a rumour that Acebeam 10160 uses QTC to
Myself I love QTC, it’s extremely simple and works great. I like this from-firefly-to-turbo adjustment better than any non-e-switch UI. And e-switches come with a few issues of their own, especially if one wants a really small light.
Thanks guys. Cool stuff indeed. It’s the first time I’ve seen/heard of it. I can certainly see the appeal of it, at least for lights using batteries that don’t have over-discharge issues.
I was interested so a little more googling shows that “Velostat pressure sensitive conductive sheet” is available from many places such as Tinkersphere $3.99 for 12” × 12” piece. Same stuff available directly from Adafruit, Digikey or Amazon for slightly more. Same properties as QTC???
As I remember from Match the only hitch in using this was getting it to stay at one setting. Need some kind of detent to hold the pressure steady.
Isn’t this possible to make yourself?
I mean like a piece of plastic sponge, soaked with graphite and latex mixture or something?
(i guess i should try that myself ?)
I tried some QTC and then gave it away because afaict it only works in single mode lights that are battery crushers (no spring above or below the battery).
I do not own any battery crusher lights…
All my lights have a spring, so the QTC would not work.
Good point.
I would like to try it in my Astrolux M01. (10180 keychain light)
No springs and the minus goes via the threads.
I’ve tried qtc before. I prefer the reliability and feel of infinitely variable control rings but those lights are bigger than qtc lights. I would like to try making a non-battery crush qtc host one day, just for the challenge of it
I did that with a cooyoo 10180 light.
Separate battery compartment, the head twisted to compress the QTC pill onto a fixed stationary contact not the cell itself.
And did it work?
(i think all those keychain USB charged 10180 lights are the same inside)
Yeah, I mean the light was stripped & heavily modified, just remembered it with pinks comment.
A slightly better way to implement QTC.
So you could have a sprung cell compartment and just the head or tail unit doing the variable thing without crushing the cell.
they have a 2 mode switch in the head, that is based on a domed metal disc that gets compressed to access the 2nd mode.
That defeated the QTC, which I wanted to use to get a moonlight mode.. Instead the QTC would trigger the high mode. iow, the QTC needed more pressure to work, than the 2 mode switch, which is based on a springy piece of metal that would move with less pressure than the QTC needed..
waste of time
That is not to say that a heavily modified light could not be made… but the QTC definitely did not work for my intended purpose with a 10180 light.. They come in many brands, they all work the same 2 mode spring switch..
I also tried it in a Fenix E01 and a Maratac, again hoping to create a sublument mode.. Total Fail
Yeah, i replaced the springy triangular(ish) disc in mine for a tiny strip of metal.
Works much better, because that springy disc couldn’t be soldered properly to the PCB, causing problems…
And so the tiny strip will have to be removed again if i want to try a pressure sensitive resistor in stead.
I think it’s wise to sandwich the pressure sensitive medium between thin brass sheet discs or between the PCB and a thin disc, so it won’t deform or damage.
I would also like to have a small amount. There is little time before Christmas but maybe it would be possible to make a group buy?…
Steve has some for sale in this site
Thanks for the heads-up. Just ordered some.
+1
2Q19
Nice
- LEDs & Other Stuff - - UI CheatSheets - - CRX Mods & Builds - - Stuff for Sale -
- The Old Lumens Flashlight Modders & Builders Challenge is Now Open - Link -
Can try asking Steve for GB pricing.
OK, I found that supplier:
https://mindsetsonline.co.uk/shop/pressure-sensitive-conductive-rubber-p...
5-pack of 10×10×1 mm pills is $4.58 but shipping is $7.68. Not much more than a 2-pack (of unspecified size) from veleno.
I found also
They sell sheets.
The Valeno designs pill will most likely be 4mm x 4mm.
That’s a really good deal for the mindsets 10mm pills if the material has the same or better properties to the usual QTC stuff.
I gotta ask… what exactly do you use this stuff for?
https://www.flickr.com/photos/akrylamid/sets/
If I remember correctly, you can make an infinitely variable output flashlight with it, but sadly, QTC isn't very durable.
BLF member Match used QTC years ago in one of his threads.
31 knives for sale=USA only ☮♫☯
[WTS] Brand New Timex Expedition Vibe Shock Camo Watch [USA Only]
http://budgetlightforum.com/node/48045
Please illuminate responsibly
Great, now you’ve got me wondering what I can do with Indium Tin Oxide Coated PET Plastic
It’s only 0.1 mm thick…
2Q19
It is difficult enough to get the factory stuff working properly.
So, i guess that’s a no then..
2Q19
Not at all, you might make something revolutionary, but, more likely, just get a sore head trying
I’ve played around with QTC a fair bit and never got it performing 100% to my liking but it can be useful for smaller builds. I might have another go.
Yeah I cant see how the velostat sheet would work for us being so thin, not compressible?
Didn’t look into it.
Graphite powder would seem like the suitable conducting material though.
I’ll pick up a flask at the hard wear store, see what i can do with it.
2Q19
Good point.
2Q19
And did it work?
2Q19
I wouldn’t have mentioned it otherwise
Found an old pic.
not for me
I tried it with a stock 10180 light
waste of time
2Q19
Also can put the QTC in the tail to avoid torsional stress, some of the better mods I did that way.
