MTN-17DDM squeals like a pig when amp juice is flowing
21 posts / 0 new
trailhunter
Last seen: 1 week 6 days ago
When hitting 10+ amps, the driver starts screaming with a high pitched squeal. Is this driver inductor whine and is it of concern? I’m hitting 19A on my setup.
KnHawke
KnHawke's picture
Last seen: 1 week 1 day ago
I wonder if it is a bad FET, since there is no inductor on these drivers.
Just put together a set of the 20mm version of this exact same thing and so far, no problems with these little mini-monsters (XPL2-HD and XHP50.2-3V)
What host and LED you using BTW?
moderator007
moderator007's picture
Last seen: 17 hours 26 min ago
It would about have to be the PWM in the fet. Possible the PWM frequency isn’t low enough or bad fet like KnHawke said.
Which firmware did you choose?
trailhunter
Thanks, it’s in a s2+ and it’s an xhp50.2
trailhunter
It would about have to be the PWM in the fet. Possible the PWM frequency isn’t high enough or bad fet like KnHawke said.
I’m using bistro.
moderator007
I’m no expert here but it might be worth a try. Changing between fast and phase correct pwm might solve the problem. I don’t know which one you have now.
//#define FAST 0×23 // fast PWM channel 1 only
//#define PHASE 0×21 // phase-correct PWM channel 1 only
#define FAST 0xA3 // fast PWM both channels
#define PHASE 0xA1 // phase-correct PWM both channels
Toykeeper would be the expert with this. Richard at Mtn might know how to solve the problem.
You might find a solution here. https://forum.allaboutcircuits.com/threads/mosfet-gate-ringing.151840/
Adding a resistor in series to the gate or lowering the frequency may help. But I have used this type fet+1 driver (blf x6) with a triple pulling similar currents without whine or ringing as they call it. I used NarsilM made for e-switch.
CRX
CRX's picture
Last seen: 1 hour 19 min ago
trailhunter
CRX wrote:
Silicone cubes.
Cute cubes, what do I do with em? Smile
trailhunter
moderator007 wrote:
I’m no expert here but it might be worth a try. Changing between fast and phase correct pwm might solve the problem. I don’t know which one you have now. //#define FAST 0×23 // fast PWM channel 1 only //#define PHASE 0×21 // phase-correct PWM channel 1 only #define FAST 0xA3 // fast PWM both channels #define PHASE 0xA1 // phase-correct PWM both channels Toykeeper would be the expert with this. Richard at Mtn might know how to solve the problem. . You might find a solution here. https://forum.allaboutcircuits.com/threads/mosfet-gate-ringing.151840/ Adding a resistor in series to the gate or lowering the frequency may help. But I have used this type fet+1 driver (blf x6) with a triple pulling similar currents without whine or ringing as they call it. I used NarsilM made for e-switch.
Thanks for this, I’ll try it out.
Lexel
Lexel's picture
Last seen: 1 month 1 day ago
Usually mechanical move able parts make the buzz like cables or springs, it’s hard to eliminate if you can’t pot the whole light
Even inside a battery such sounds can be created
CRX
CRX's picture
trailhunter wrote:
CRX wrote:
Silicone cubes.
Squish them into driver spaces.
Flying Luminosity
Flying Luminosity's picture
Last seen: 7 months 1 week ago
CRX wrote:
Silicone cubes.
Not sure if I’d trust an object that’s advertised as a ‘cube’ if it’s only 1cm x 1cm x 0.5cm. That’s either half a cube, or four conjoined cubes.
CRX
CRX's picture
True, don’t use these, they are not labeled absolutely correctly.
Some of the edges are not laser line straight either. False advertising!! Silly
I wish I had realized before using these for years Big Smile
Flying Luminosity
Well to be fair, the term is nowadays used pretty freely! Big Smile
CRX
CRX's picture
Smile
snakebite
snakebite's picture
Last seen: 2 days 10 hours ago
could be piezoelectric noise from an mlcc.
trailhunter
Do the mtn-17ddm and 20ddm drivers support high current (10-20 amps)?
KnHawke
KnHawke's picture
I want to say Yes to that, since looking at how the parts are laid out by the direct bypass of the positive line and the very short negative traces near the edge of the board, but I have no equipment to measure the XHP50.2 I have here and going by Vesture’s readings of the same LED, I could be pulling 13 amps.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 3 min ago
These (2) 50.2 3v builds draw over 20 amps some builds 30+ amps…on a 30T using Mtn Drv’s…4800-9000lm
KB1428 “Live Life WOT
trailhunter
!{width:100%}https://i.postimg.cc/ZY74GB35/IMG-0255.jpg!
29A is incredible, what battery do you use to get that?
KawiBoy1428
21700 Ohm Run or a 30T….
