De-domed a LED, went a bit wrong. Have i F***** it?
13 posts / 0 new
cornz
Last seen: 5 months 10 hours ago
Ok, my de-doming of an xph70 went a bit wrong. To the point i have managed to remove ALL the silicone ‘bubble’. The led still works but that yellow film has gone and it looks ‘blue’ although it is a 65000k version. Have i just trollied my LED or is it still usable?
https://1drv.ms/u/s!AoEv-9vBdzh_hfsSAmGhVaUqCv6TcQ?e=A0HHY1
The_Fat_Controller
The_Fat_Controller's picture
Last seen: 1 week 6 hours ago
only way to tell is power it up and see if there is any blue patches
It looks to me like you may have just missed the critical part over the phosphor layer by a Gnats man parts
Jerommel
Jerommel's picture
Yes, you now have a large royal blue LED.
That yellow stuff is the phosphorous layer that normally turns the blue light into the other colors of the spectrum so that you get white light.
Jerommel
Jerommel's picture
Hmmm… Looks to me like it’s not on the 4 emitters anymore..
The_Fat_Controller
Nice royal blue then Sad
cornz
So that explains that then. One royally ****** led but without making mistakes, you learn sweet FA.
Fortunately, they aren’t too expensive. Oddly though, i was using a brand new scalpel blade and the dome just came away from the led surface taking the phosphor layer with it.
Just saying to a mate, when i worked in Maplins back in the late 80’s / early 90’s we started to sell blue, 5mm, water clear leds. £17.50 each and the first white ones were almost double that.
The_Fat_Controller
To be honest, I really don’t think its worth trying to de dome emitters anymore, if you want throw there are lots of good factory dome less emitters around that will outperform an xhp 70 , those leds are best suited to flooder’s
Even a nice hard driven domed Xhp50 will probably out throw a 70
Jerommel
Jerommel's picture
Yeah, i’ve ruined a few LEDs myself too, trying to slice the dome off…
…also in other ways, by the way…
Yes, LED technology has come a long way.\
Even very high Color Rendering Index and decent efficiency.
trailhunter
Last seen: 1 week 6 days ago
I use very thin washers and stack them until you get the desired height then take a brand new razor and slice slowly one way. I’m sure others have better ways of doing it but this is what I do.
nuemtol
Last seen: 3 weeks 3 days ago
What are the nice XHP70 emitter options available? I’m looking for one too.
BlueSwordM
BlueSwordM's picture
Last seen: 6 hours 16 min ago
cornz
A simple but ingenious idea!!!
rngwn
rngwn's picture
Last seen: 3 days 15 hours ago
One (improbable, but creative) way to salvage that might be to get a layer of phosphor somewhere else.
Or if you’re daring enough, you might try buying a phosphor, mixing it with silicone and reapply it on your emitter. Silly
Searching for High CRI leds since 2010...
Has finally gotten to the bottom after 10 years of delving deep into that rabbit hole of them high CRI lights...
High CRI, high quality lights doesn't need to be expensive, or is it?
