Best AA Flashlight Between $30-$50
40 posts / 0 new
WalkIntoTheLight
Last seen: 4 hours 38 min ago
hank wrote:
Cells in parallel: Nitecore MT22A
I don’t understand the benefit of using cells in parallel in a AA light. I get it with lithium-ion (it’s generally safer), but why with an already-safe chemistry like NiMH? They still need to use a boost-driver (which adds some inefficiency the more you need to boost). Is it just amps? Unless they’re using more than 5 amps, a single Eneloop should do the job. If they want to use 2 (or more) cells, why not put them in series so you get a voltage closer to the forward-voltage of the LED, and use half the amps for less loss due to resistance in all the contacts?
buck91
buck91's picture
Last seen: 3 hours 16 min ago
drewski wrote:
Has anyone tried sticking an SST-20 in a Tool AA? I don’t know if they come on 14mm mpcbs. I would love a 4000k tool aa though.
Not specifically but I’ve put SST-20 in place of some cold white Nichia as well as XPG2 leds with good results. Don’t see why the Tool would be any different. Worst case, just reflow the SST-20 onto the existing star.
Scallywag
Scallywag's picture
Last seen: 21 hours 24 min ago
Standard footprint, just reflow it.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Watermanchris
Last seen: 2 hours 19 min ago
It’s just adding capacity and more amps. Lights with parallel batteries can often run on a single cell in a pinch like the LT1.
hank
hank's picture
Last seen: 12 hours 55 min ago
Actually “side by side” is what I like; the old incandescent “doorstop wedge” flashlights I remember had the cells wired in series but placed side by side. I don’t know how they’re wired in contemporary flashlights.
WalkIntoTheLight
That seems inefficient, compared to cells in series. Why double the amps, when you can instead double the voltage? Less amps means less loss to resistance, and higher voltage means a more efficient driver.
hank
hank's picture
I just bought a NITECORE MT22A to give to an elderly neighbor — it’s handgrip size, comes with a highly findable yellow case, and runs on two AA cells.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 24 min ago
One problem with any cells in series, whether alkaleaks or NiMH, is that one cell can rapidly go to zero and then be reverse-charged. Probably ruin NiMH, but would definitely cause an alkaleak to crap the bed. There’s always one runt of the litter that’ll go first.
xevious
xevious's picture
Last seen: 12 hours 21 min ago
!{width:35%}https://encrypted-tbn2.gstatic.com/shopping?q=tbn:ANd9GcQlAgjizc14_xabul...!
Yes, when I said “parallel” I meant physically, not necessarily circuit wise. Vast majority of 2xAA lights run in series, with sequential orientation.
