Haikelite HK04 groupbuy is ALIVE
111 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 5 hours 53 min ago
Hello my dear friends!
Today i received the first pictures of the soon to be released
HAIKELITE HK04
SPECS (not final)
ANDURIL UI
* 3x 18650
* LED choices:
– 4 CREE XHP50.2 ~15000LM ~750m
– 4 Luminus SST40 ~9000LM ~850m
– 4 CREE XP-L-HI ~5000LM ~950m
USB-C charging port
* IPX7 waterproof
BLF members can also enter their username (please post that you voted!)
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
Edited by: M4D M4X on 12/09/2019 - 08:46
M4D M4X
M4D M4X's picture
i found a Aliexpress shop listing the Haikelite HK04
beside some new pictures i add below there are more interesting specs:
(PLEASE NOTE: those information is not confirmed by banggood)
Specifications
Material: 6063 aluminum alloy barrel material; stainless steel pressure ring; no
Stainless steel switch pressure ring, ultra-low internal resistance copper alloy silver-plated spring
Surface Treatment: Military Grade III Hard Oxidation
Lens: Tempered glass lens with anti-reflection violet coating
Color: Black / Desert Fence Yellow (optional)
Battery: Three 18650 power batteries (pointed, half pointed)
Charging: Type-C charging port, 5V / 3A fast fast charging,
When charging-the switch lights up red; when charging is complete-the switch lights up Light blue
Charging time: 3000mAh 3 sections 18650 duration 5 hours or so
Lamp beads: Four LEDs with three options: CREE XHP50.2
Or Luminus-SST40 or CREE XP-L HI Highest Level Glare Selection
Color temperature: 6500K (cold white) and 5000K (neutral)
Waterproof rating: IPX7
Product size: 140mm (total length) x56mm (headPart) x50mm (tail) x46mm (body)
Product weight: Bare tube 370g Package weight 586g
Packing list:
HK04 flashlight * 1
Waterproof O-ring * 2
Product Manual *
Portable hand strap * 1
Type-C USB adapter cable * 1
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
Hello my friends!
I was able to get it as public groupbuy! (no need to PM / mail / message)
please us my links to go to banggoods page for detailed information
if you want to share with your friends please give them the linkto this thread!
http://budgetlightforum.com/node/70406 (do not post the details anywhere)
And here is the deal which could be negotiated based on the feeler:
deals.m4dm4x.com
Th558
Th558's picture
Last seen: 4 hours 22 min ago
Wow. They actually designed something decent looking for once! XHP50s are pretty efficient so the sustained output should be pretty good. Nice to see there’s other emitter options as well. Wonder what the price will be.
Tubercle
Last seen: 7 hours 18 min ago
Grossly inflated specs once again. Doubt the throw numbers can get close to what they state. Same w/ the lumens, that 4× 50.2 light is gonna put out absurd heat.
Then again, would be interested if they offer <=5000k tints which they’re not gonna.
SKY69
Last seen: 1 week 4 days ago
I voted for the XPL Hi however I would be interested in any configuration.
SKV89
Last seen: 47 min 9 sec ago
Basically Q8 with USB-C recharge. Not bad.
mattlward
mattlward's picture
Last seen: 6 days 10 hours ago
Would love to see the XHP50.2 happen with a tint warmer that 5000k.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Roger Sully
Roger Sully's picture
Last seen: 6 months 4 weeks ago
Voted for the XHP50. Looking forward to seeing the price on this.
sandro
Last seen: 22 hours 22 min ago
Voted for the XHP50
Di_Joker
Di_Joker's picture
Last seen: 52 min 49 sec ago
Sorry for my poor english.
rizky_p
rizky_p's picture
Last seen: 1 day 17 hours ago
afaik this is an upgraded Q8, now let see about the price.
Streamtronics
Streamtronics's picture
Last seen: 1 week 2 days ago
Voted.
Anthon
Last seen: 6 hours 46 min ago
why 3×18650? too little power for such lumens. And you need to buy a new set of 3×18650 cells because you can’t use your other 4×18650 cells from your other flashlights
mortuus
mortuus's picture
Last seen: 7 hours 57 min ago
hm not better using 21700 ? since its bigger then q8 makes no sense using just 3 18650…
...where Frugal meets with Flashlight!
Funzel67
Last seen: 7 hours 28 min ago
Looks more like a competitor to Sofirns SP36 to me. Hope price is also in same range. And vote for 4000/5000k.
CM2010
Last seen: 10 hours 15 min ago
Xph50.2 and would prefer 21700’s.
Sillen
Sillen's picture
Maybe 4 CREE XHP50.2 ~15000LM pending price
Di_Joker
Di_Joker's picture
Yes, it would ideally be 4*XHP50.2 (4000K Hi-CRI?) and 3*21700
Satan@103TFS
Last seen: 3 days 1 hour ago
Voted for SST40 and prefer 3×21700
1stein
1stein's picture
Last seen: 2 weeks 17 hours ago
Voted for SST-40
hasddie293
hasddie293's picture
Last seen: 1 day 14 min ago
I will vote for SST40. Look, it has a balance between thrower and flood also less heat.
Yet if I do recall, both xpl hi and xhp50.2 draw huge amount of current compare to sst40. I dont know you guys know relationship between current and heat.
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Tony Cape
Tony Cape's picture
Last seen: 22 hours 28 min ago
Voted SST40
Photonica
Photonica's picture
Warm is better. Noticed the trit slots. I’m sure Lexel will have an aux board eventually. It’s gonna be blingy!
More Photons!
CrashOne
Last seen: 10 hours 33 min ago
If the price is right, interested in the XHP50.2 version.
Chinaheart
Chinaheart's picture
Last seen: 1 hour 13 min ago
I voted for SSt40
Captain_Joe
Voted for 1 XPL-HI and 2 SST-40
CrashOne
Did anyone already order one from Aliexpress? Looking forward to the reviews.
Tubercle
SST40 maybe green at lower levels.
Sunnysunsun
Sunnysunsun's picture
Last seen: 15 min 53 sec ago
I haven’t seen 3v xhp 50.2s come in anything other than 5700k and 6500k. Unless they’re using a boost circuit, that’s all you’re going to get unless they’re actually going for 3 cells in series which seems unlikely with USB charging. It’ll likely be 3P without a boost circuit and we’ll get 6500k
FlashPilot
FlashPilot's picture
Last seen: 8 hours 38 min ago
Looks like they missed the mark on this one. As others have mentioned, building this light with with either 4 × 18650 or 3 × 21700 makes a lot more sense.
