Hi everybody.
I’m planning on build a bicycle light with a XHP35 HI on a Opulent Americas starboard and a 40mm Aspheric Acrylic Lens with 16mm focal length. The led will be mounted a little bit further for a wider beam while exactly on the focus I’ will put a straight iris to cut a small part of the upper beam that bother the opposite traffic or people walking. I decide to build this lamp myself because there is no commercial solution that has a simil beam pattern.
But now I found this LED from Osram Oslon Blackflat
It has 5 emitters in a row for a total of 5,5mm x 1mm, 1400 to 2200lm, 15w absorption. It would be perfect behind an aspheric lens in beam pattern.
But the led comes without any starboard and I don’t know where to find a proper one nor how to flow one.
The question is: can I stick directly as-is on a adhesive heat sink or the electric insulating adhesive film has too much thermal resistance for the small pads of the led?
Any idea on how to solve the problem?
Thanks
