Hi. I have a KDLITKER P6-TRI TRIPLE CREE XP-L HI 2000 LUMENS 3V - 9V 6-MODE P60 DROP-IN MODULE (DIA. 26.5MM) arriving. Will my Solarforce L2P with stock forward clicky tailcap be able to run this drop in with no issues? The Drop in’s indicated output current is 5000-6000ma max.
Thanks for the replies. What is the maximum current the stock l2p forward clicky tailcap can handle? If I use a high current draw dropin than the tailcaps rated capacity will it fry the tailcap internals or just the dropins output will only be limited and tailcap will be ok?
Thanks. So is it safe for me to assume that the stock l2p tailcap can handle high amp draw/high output dropins, no need to upgrade to a mcclicky or similar mod?
