Correct if if I’m wrong but I used calipers and measured it to be 18mm. At Kaidomain, there’s no option for 18mm when ordering a pcb. There is only 16mm or 20mm. Which one do I choose??
Also, can one put any XHP led’s on the A6 except for the 70.2’s?
16mm
Depends on the reflector hole, make sure to buy correct gaskets, otherwise you have to adapt them yourself
Hey thanks for that. Now I’ve gonna go get the led and gasket already
