Kdlitker p60 shorten battery with switch or tailcap?
22 posts / 0 new
John Deez
Last seen: 2 hours 8 min ago
I bought two Kdlitker e6 hosts with a variety of sst20 drop ins. They seem to be of good quality but have multiple frustrating points.
The battery compartment is way too long. I think a button top is supposed to only be a couple mm longer, and my homemade ones rattle around. The springs are already pretty long on both ends.
The kdlitker switch is a simple type that sits on a flat board. Its almost like they changed the switch without changing the body. I see that my surefire p6 switch and the mcclicky switches have a deeply recessed switch assembly for some reason. This appears to put the spring a lot more foward, and would allow the use of flat tops in the e6. I’m wondering if a certain mcclicky model or another switch would be worth purchasing to try out? It would fix this problem and also be and upgrade.
I don’t like the Kdlitker tailcap because its sharp and doesn’t balance well. Its my least favorite part of the host. However, its about a mm wider than the surefire tailcap, and I don’t think another type would fit it?
John Deez
John Deez
threads on tube: 23×1.0 (22.80mm)
threads on brass retainer for switch 21×1.0 (20.70mm)
Surefire tube: 22mm
KawiBoy1428
KawiBoy1428's picture
Last seen: 36 min 44 sec ago
Surefire tail 22×1.0mm
To be clear Surefire threads are standard not metric.. tail cap threads are 7/8-20
KB1428 “Live Life WOT
mattlward
mattlward's picture
Last seen: 1 hour 50 min ago
The tube length I’d annoying. I use a magnet to make the cells longer. We should let BanL know. This is a flaw. The switch board is fine.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
John Deez
Yes but I’m wondering if another tailcap would fit or another switch like the mcclicky would close the gap. I’d like to see the tailcaps stand better, not bite me, and have the two holes like an S2+ so it can still tailstand with a lanyard.
Is this how they’ve always been? I’m sure he knows because they came with weak little magnets.
mattlward
mattlward's picture
Well, the current draw on most p60 lights is not nuts, not worried about magnets. McClicky switches are not that great. An Omten 1288 on a good board with good springs will carry more current. I run the up to and over 15 amps, no p60 should ever pull that due to the poor heat transfer.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
John Deez
Its my ocd. I don’t like cheap fixes or the idea of different size threads on each end of the tube.
KawiBoy1428
The difference is in the driver size… a normal P60 (this is a PFlexPro) uses a 17mm driver the KD a 20mm so the driver has to sit farther up in the housing, due to the diameter, so it fits in different host’s, making the OAL shorter…
Even on this KD drop in, I’m using one of Blue Sword’s largest spring…
KawiBoy1428
Yep 15-20 amps on a regular/store bought grooved body general fit P60 triple/quad drop in’s, where you have to wrap with (non glued) copper foil might be alright for heat transfer and short bursts… it is better if you get the smooth bodied copper P60 quad/triple pills that are oversize from kiriba-ru and then hand fit to a press fit, tight enough were you need to make a delrin/plastic dowel to drive them in and out.. or a socket to drive/press them in…heat transfer is about the best you’ll ever get…. For a bit of Bling…with a Dragon driver you can run secondary aux LED’s (my 6P Surefire Copper Kiriba-ru/Triple mods)
John Deez
Thanks for the post. It doesn’t seem that I was notified of it via email.
This makes me wonder if the KDlitker hosts or drop ins are worth it. Once you optimize them, there isn’t much left of them. The hosts also look a little toy-ish in appearance. It’s too bad because they are otherwise of good quality.
My favorite KD drop in, a triple sst20 3000k makes a whining sound on high. The triple has a nice reulaux triangle beam. The quad has a terrible beam, complete with “buddah” lotus and cross shapes. This makes me wonder if the retainer ring on the kdlitkers makes a good quad unfeasible.
John Deez
Forgot to ask; what other budget hosts are there?
John Deez
The KD single emitter drop in uses a 17mm driver (the circuit board with the spring coming out of it?). But its still too short. I have an ultrafire drop in that didn’t make it into the picture, that’s ones a few mm longer than the KD single. I doesn’t make sense why they wouldn’t standardize their dimensions with other drop ins or even their own hosts.
KawiBoy1428
^^^^^ oh double bummer man… Facepalm my (triple) is in the junk box…
. Here is a pic of the driver out of the triple, I jumped the 2 resistor pads and got 4.6amps at the emitter.. using a clamp meter….. KD’s C.C. buck driver….
Photonica
Photonica's picture
Last seen: 20 hours 18 min ago
The WF-502B is indestructible, but quality varies. Sometimes you get a pretty good clicky, sometimes the switch is mushy. I haven’t tried the other WF-50X, but I’d expect they are comparable. With hosts from $5 and (crappy) lights from $7, it’s worth adding one to a future order just to have a cheap testbed around. There used to be C (3×16340) and D (4×16340, 2×18650) versions.
IMHO, the “ LumensFactory Seraph is one of the better-made mass-produced P60 hosts. $18.50 in 2- or 3-cell versions, $35 with a one mode P60. They also make M- and D36 heads, but I haven’t tried them.
More Photons!
Photonica
Photonica's picture
The problem is that P60 is no longer cutting edge for modders, probably for thermal transfer and space reasons as mentioned above. Most of Convoy’s lights are available as hosts in the $15-25 range; you can get the same form factor from Manta Ray or *Fire for a little cheaper. They take standard size drivers and MCPCBs and offer lots of choices. P60’s big advantage is the ease of changing – just pop in another module.
For non-modders, there’s a lot of really good $30 entry lights. It’s hard to justify $30-60 for a great P60 drop-in with the Wurkkos FC11, BLF A6, Convoy M*, Sofirn SC31B, etc out there.
Eh, enough bloviating, I guess.
More Photons!
John Deez
How is a convoy with a threaded pill better than a pressed fit or wrapped drop in?
JaredM
JaredM's picture
Last seen: 16 hours 44 min ago
My favorite budget P60 hosts are the Manta Ray M5 and M6. Between the two I prefer the M5. You can find them on ebay or ali for ~$10 with a crap drop-in included.
mattlward
mattlward's picture
Much larger surface are and good tight direct contact. Like heat fins, threads increase surface area and there for can transfer heat very well. The flat sides of the dropin have a fairly small surface area compared to the same amount of space with threads.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
John Deez
Only one edge of the threads would be pressed against the body once it was tight. The outer edge of the threads and the other side would have a gap between them and the body. It seems like it would be comparable or less good than a custom p60 pill like the ones sold here.
mattlward
mattlward's picture
All I can suggest is build a hot rod of each type and see it in action for yourself. I have built a couple dozen dropins and several dozen lights with threaded pills. It does make a difference.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
JaredM
JaredM's picture
In practice, threaded pill setups are easy/reliable to get an 80% solution to thermal transfer. The contact area is about the same as a straight, tight-slip-fit pill, but the contact pressure is way higher with threaded setups in almost every instance except precision machined and machine pressed drop-ins (which kills the main selling point of them in the first place). CTE is another thing to consider. If your host expands a higher percentage per degree than your drop-in, then it actually would loosen up in operation. Of course the opposite is true as well, and could be the best argument/approach at creating a good heat path in a drop-in setup.
