[H17A] Don’t blow my 20
21 posts / 0 new
Hank33
Hank33's picture
Last seen: 16 hours 7 min ago
I ordered a H17A 17 mm driver. Driver mentions to use it with XHP50.2 or SST40. If I use this driver for an SST-20J4 HB4 (3000k), will the SST-20 survive?
'The true mystery of the world is the visible, not the invincible.'
contactcr
Last seen: 4 hours 51 min ago
If you spring bypass both ends and use a really high drain battery maybe, otherwise probably not. This is one of those things that’s highly dependent on overall resistance of the rest of your build.
Hank33
Hank33's picture
Yeah I think I’ll do all those hacks but I think it sounds like I better not try it? Got a S2+ coming from Kaidomain.
contactcr
If you use a GA battery or similar (the true 3500mAh rated ones) you will be fine. A fully charged VTC6 would not be recommended on such a build.
Hank33
Hank33's picture
Ok nice and I have 2 30Q’s and one 35E coming. Crown
SK1LL
SK1LL's picture
Last seen: 43 min 37 sec ago
don’t think that 35E would pop the SST-20 but looks like a close call.
- Paul
Hank33
Hank33's picture
Living on the edge…
snakebite
snakebite's picture
Last seen: 1 day 18 hours ago
good copper dtp mcpcb?
good host with thick shelf?
you might pull it off.
Hank33
Hank33's picture
So what I’m sensing now is that if I follow the above parameters for the build, then the led might burn out? Basically just build it and hope for the best scenario I guess??
Jerommel
Jerommel's picture
Last seen: 2 days 18 hours ago
You’d better get a proper constant current (current regulated / current limiting) driver for a single relatively small low Vf LED like the SST-20.
The LD-25 from Simon / Convoy (unfortunately discontinued at Fasttech) does 3 Amperes, which is a nice amount of maximum current for the SST-20.
Those FET DD drivers are more suited for high Vf LEDs like XP-L (HI) or for multiple LEDs (so that the internal resistance of the battery and the electrical path from battery to LED provides the resistance as to not smoke your quad low Vf LEDs.)
id30209
id30209's picture
Last seen: 9 hours 37 min ago
If you like H17F then just remove FEt by desoldering it. That’s what i did running triple 219B.
That way you convert H17F to Prometheus Icarus driver.
You’ll have 3A max output
Happy New Year
WTB Titanium 4sevens Quarks & Jetbeam TCR1
Hank33
Hank33's picture
My mole hill’s becoming a mountain now Big Smile
Jerommel
Jerommel's picture
Happy New Year
This doesn’t make sense to me.
But a happy new year to you too. Smile
id30209
id30209's picture
Jerommel wrote:
This doesn't make sense to me. But a happy new year to you too. :)
Sorry, working. Was just stop by. I only had H17F on hands and didn’t wanted to overdrive tiny 219B so i have just removed fet.
SST20 can be used safely with fet if heatsink is ok but if OP is concerned about safety then just desolder little devil.
Jerommel
Jerommel's picture
id30209 wrote:
Jerommel wrote:
This doesn’t make sense to me. But a happy new year to you too. Smile
You removed and bypassed it, i assume.
Without it you only have one AMC7135 (= 350mA)
I would never drive 219B or 219C with more than 2.5 Amperes.
They don’t like it and it’s not worth the few extra Lumen.
But you must have used a low drain battery or have a less than optimal electrical path.
contactcr
H17A – some questionable Kaidomain FET
H17F – good FET+N DrJones driver
Bottom line. Run the SST20 with your cheap driver and 35E and don’t worry about it.
id30209
id30209's picture
Jerommel wrote:
You removed and bypassed it, i assume. Without it you only have one AMC7135 (= 350mA) I would never drive 219B or 219C with more than 2.5 Amperes. They don't like it and it's not worth the few extra Lumen. But you must have used a low drain battery or have a less than optimal electrical path.
Got home at last and checked again my build.
Nope i haven’t bypassed it at all. Just desoldered FET and voila.
Jerommel
Jerommel's picture
But it’s a FET + 1 (1x AMC 7135) isn’t it?
id30209
id30209's picture
Jerommel wrote:
But it's a FET + 1 (1x AMC 7135) isn't it?
To be honest, no idea. I’m not so in elec data and info. I’m more of a handy man. If it works it works if not, test another one. Tana advised me he was doing it in Surefire mods with Nichia emitters so i gave it a shot.
and it worked.
I’ll post pics tomorrow.
id30209
id30209's picture
H17
H17 without F
Hank33
Hank33's picture
Oh man I think something funky is going on!. But seriously, I just saw the latest update to my post above a couple of hours ago. Then when I arrived home, my Kaidomain orders including the H17A was sitting in the mailbox!
