Help with C8+ white flat mod
I have Convoy C8+ XPL-HI which I want to mod and try osram white flat led. I am confused about needed parts, so maybe someone who had done this can check my parts list:
Convoy 5A driver - 2.08€ 69% OFF|17mm Fahrer für SST40 ,4 modi 0.1% 3% 30% 100%, max strom ausgang 5000mA, Temperatur schutz management innen|Taschenlampen| - AliExpress
or led4power - https://led4power.com/product/ld-a4-2-12amp-17mm-constant-current-led-flashlight-driver/
Led4power driver is nice, but probably overkill for thrower setup which will be used on max amps only?
Osram white flat from Led4power - led4power
or from intl-outdoor - https://intl-outdoor.com/catalog/product/view/id/73/s/osram-cslnm1-tg/category/48/
Is there any difference in led4power and intl-outdoor supplied white flat leds and led boards?
I have C8+ stock reflector with 7mm hole, so I am confused about which gaskets do I need:
7mm XP gasket from convoy and mod it with knife? - 2.27€ |Dichtung für XP led und 7mm reflektor loch|led showerhead|led ceiling light fittingled garage - AliExpress
Or buy 9mm reflector from convoy and 3030 gasket instead?
Thanks for help.
LED4Power delivers top notch products, kaidomain’s mcpcb’s are usually thinner.
You need a 3030 gasket from kaidomain or Simon (convoy)
Hmm 7mm, is it Orange Peel or smooth? Maybe spend another few bucks and get a smooth with 9mm hole so you can use the correct gasket.
Remember it still needs focusing, so some sanding of the gasket may still be needed.
Gasket from Convoy, led from wherever you prefer.
I have made several with leds from Kd.
You can use the xpg gasket of C8+ but you have to make it thinner with a file and glue it in the center of the pcb, with osram you will have a small gap.
Good luck.
I have 7mm smooth reflector.
