Group Buy Now Live - BLF GT90 SBT-90.2 powered 5,000 Lumen, 1.8Mcd / 2600m Super Thrower
331 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 8 hours 34 min ago
More like is the reflector factory open yet so that lumintop can get the parts to build lights lol.
Last I heard they were still on lockdown but that was a week ago.
justanotherguy
Last seen: 2 hours 55 min ago
Clint79 wrote:
Is Neal shipping out flashlights yet?
I inquired for a friend, to get a code and he said they were shipping next monday.
Which was actually last Monday. SO theoretically yes….
Clint79
Clint79's picture
Last seen: 1 week 1 day ago
Right on, maybe I’ll get my tracking numbers soon
Clint79
Clint79's picture
It’s been 10 days and my light hasn’t moved from Hong Kong. How long is the wait time for it to ship out of Hong Kong?
Texas_Ace
Texas_Ace's picture
It is very slow right now, there are very few flights due to the lock down right now so packages go out as space allows. From what I have seen this is adding a few weeks to the shipping process internationally, although larger packages will be delayed more then smaller ones.
I have a few things on order as well and they are also held up waiting for shipment out of the country.
brn2prgrm
Anyone have any recent data points they can provide, for delivery times from Neal to the US? Still patiently waiting on my GT90! Smile
shirnask
shirnask's picture
Last seen: 3 hours 3 min ago
Not for this light but
1) Ordered Mar 16, 2020 – Delivered Mar 26, 2020
2) Ordered April 09, 2020 – Arrive at international airport to abroad-HONGKONGCHINA – April 13, 2020
Texas_Ace
Texas_Ace's picture
There are very few international flights right now due to the virus. This is greatly slowing shipping to the point a lot of companies are just shipping by boat.
I have several orders from overseas that are held up waiting for transport right now, some going on close to a month so far.
Nothing we can do but wait.
Clint79
Clint79's picture
Finally got my GT90 flashlight, but it doesn’t work. Who do I contact to get it replaced? I emailed Neal but no response. Anywhere I can send the light to be fixed?
Texas_Ace
Texas_Ace's picture
It doesn’t work at all? That is very strange. That is very rare to not do anything as they are tested at the factory. Normally it is some small issue that slips by.
The batteries are fully charged to 4.2v? All inserted properly?
Does the switch LED light up?
Clint79
Clint79's picture
Batteries are fully charged and inserted correctly. Green light doesn’t turn on
Texas_Ace
Texas_Ace's picture
Ok, the switch LED is a very basic function, The most likely reason for it not turning on is that the driver is not getting power.
I would check the ends of the carrier to make sure it has the correct voltage. Then make sure the driver is screwed down properly. Also try pressing the carrier down onto the driver manually without the battery tube installed and see if it makes contact like that and turns the switch LED on.
Oh, also make sure the carrier is installed the correct direction, the “button top” end needs to face the driver.
If none of that works, the next step is to manually apply voltage to it with wires if possible, positive to the center contact and negative to the retaining ring for the driver.
JasonWW
JasonWW's picture
Last seen: 2 hours 3 min ago
Like this.
You press the carrier manually so it makes contact. Make sure the screws on the carrier are not loose.
Since it’s a 3v led, only one battery is needed.
Clint79
Clint79's picture
Yeah the flashlight is dud. I don’t know where to send it to get repaired or replaced. Still waiting for response from Neal
Clint79
Clint79's picture
I tried the carriers from the GT70 with the greens cells, the led switch turns on , but the flashlight won’t turn on
djozz
djozz's picture
Last seen: 32 min 56 sec ago
Uh oh
Texas_Ace
Texas_Ace's picture
That is really strange that not even the switch LED will turn on. Something would have to be seriously wrong for that to happen and shocked it would of made it threw QC.
I can fix it assuming I can get any needed parts from lumintop, which could be hard right now due to shipping delays from china. I have worked on a few other lights for them over the years.
I actually have a few GT90 conversion kits that I talked them into selling me on the way now. Possible the kit would have the parts needed to fix it.
Neal has been super busy, seems all the factories over there have been pressed into service making masks and other such items and are only able to work on flashlights at night after hours. You can also try contacting Leo@lumintop.com.
If you want to just send it to me to look at, send me a PM and we can go from there.
Texas_Ace
Texas_Ace's picture
When did you do that? Before or after you had issues? That would of instantly killed the LED as the GT70 carriers are 12v and the GT90 is 3V.
In this case there is nothing I could do right now as the LED will have to be replaced and hopefully it did not also kill the MCU.
Yokiamy
Yokiamy's picture
Last seen: 6 hours 4 min ago
If you used the GT70 carriers on the GT90 you killed the light yourself (Chibim did kill it as well using the wrong carriers)
The voltage of the GT90 is 4,2V (cells parallel) whereas the 70 needs 3S1P (correct me if I’m wrong)
Texas_Ace
Texas_Ace's picture
Yokiamy wrote:
If you used the GT70 carriers on the GT90 you killed the light yourself (Chibim did kill it as well using the wrong carriers) The voltage of the GT90 is 4,2V (cells parallel) whereas the 70 needs 3S1P (correct me if I’m wrong)
The GT / GT70 is 4S (so 16.8V fully charged).
mikelights
mikelights's picture
Last seen: 5 days 1 hour ago
Interested
Current collection
Olight -S1R -I3E EOS -S mini brass -S2A -X7R -S mini copper Sofirn -SP33 Nitecore -TM06S Thrunite  -TN42 -TN40 ThorFire -S70S -TG06S -TK05 Manker -Mk34 Noctigon Emisar -Meteor M43 -Emisar D4 -Emisar D1 -Emisar D1S -Emisar D18 -Emisar D4S Rofis -TR31 Lumintop -BLF GT -GT Mini -IYP365 -Tool AA 2.0 -FW3C Acebeam -X80GTvn -W30 Imalent -R90C -MS18 FireFlies -E07 Brass Reylight -Pineapple
Product Reviews
Chargers:
Opus BT-C3100MiBoxer C4-12MiBoxer C8Folomov A1
Flashlights:
BLF GTTN42TG06SEmisar D4GT MiniS70STM36EDC-C4BLF Q8W30
Custom Builds
XPL-HI C8, Aspheric XHP-70OSLON D1S
Texas_Ace
Texas_Ace's picture
Well, after a lot of shipping hassle and ending up having to ship it express just to get the package past customs;
I am now in possession of a few GT90 conversion kits for either the GT or GT70.
They include:
MCPCB with pre-installed SBT-90.2 LED
GT90 Texas Avenger driver
2x GT90 3V carriers (CAN NOT USE past carriers, they are 12v)
Centering ring (comes with the stock ring right now, I am looking into 3D printing better fitting rings once the shop with the printer opens back up)
Switch pre-soldered onto the driver
I only have a few of them and doubt I will be able to get more, particularly with the hassle it was to just get these out of china much less talking them into selling me them in the first place lol.
They will be on a first come, first served basis.
Send me a PM if interested.
FlashPilot
FlashPilot's picture
Last seen: 3 min 6 sec ago
TA, I cant believe you pulled it off! Thumbs Up
PM sent.
KawiBoy1428
KawiBoy1428's picture
Wink Thumbs Up I would be interested in a better centering device when you get around to it too Thanks T/A
KB1428 “Live Life WOT
Texas_Ace
Texas_Ace's picture
PM sent.
It was not easy, I started trying to get them 3 months ago now and they just showed up yesterday to give you an idea lol.
Texas_Ace
Texas_Ace's picture
The 3D printer is not set to re-open for at least another month last I heard. So it could be awhile. Send me a message then if I forget.
Texas_Ace
Texas_Ace's picture
The last GT90 conversion kit sold a few days ago BUT seems that lumintop is in need of some cash and are willing to sell me a few more out the back door.
I am putting together an interest list for those that want a GT90 conversion kit for the GT or GT70 (same kit works in both).
If you are interested send me a PM quickly as the number of interested parties will determine how many I get.
KawiBoy1428
Hey Ace.. got my SBT90.2 kit today…nice packing job… everything looks good.
I see what you mean by needing a better/real centering device Facepalm … I have a couple Idea’s…
Texas_Ace
Texas_Ace's picture
KawiBoy1428 wrote:
Hey Ace.. got my SBT90.2 kit today…nice packing job… everything looks good. I see what you mean by needing a better/real centering device Facepalm … I have a couple Idea’s…
If you are careful when you tighten the head down, it puts enough pressure that it should stay centered unless you really bang it.
Long term though I do want to make some custom centering rings that fit better though but the 3D printer is still closed at least until next month last I checked.
Texas_Ace
Texas_Ace's picture
In other news, I will be placing the order for the GT90 conversion kits on Monday. While I plan to order a few extra kits I can’t afford to be left holding a bunch of them.
So If you are interested, let me know.
