Test/review of Charger LiitoKala LiitoKala Lii-500S
19 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 min 56 sec ago
DSC_8214
DSC_8215 DSC_8216
This is a advanced 4 channel charger for LiIon and NiMH with multiple current settings and USB output.
DSC_8125 DSC_8126 DSC_8127 DSC_8128
DSC_8129
DSC_8130
It arrived in a yellow cardboard box with lots of specifications on it.
DSC_8210
The box contained the charger, power adapter, and a instruction sheet.
The supplied power adapter is a universal voltage (100-240VAC 50/60Hz) with 12V 3A output branded LiitoKala.
DSC_8217
The charger has a DC power input for the mains adapter and a 1A usb output.
DSC_8218
The user interface is 6 touch buttons and a display. The four top buttons is used to select a specific slot, when none of them has been pressed MODE and CURRENT works on all slots simultaneously.
The two bottom buttons is used to select mode (Charge, discharge, test) and current (500, 700, 1000mA, 2000mA). The current is charge current, discharge current will be either 250mA or 500mA.
Once charger is working it is not possible to change settings.
DSC_9614
During power on the charger will turn all segments in the display on and the leds in the top buttons, there is both a red and a green led.
As can be seen the display will only show data for one channel at a time.
DSC_9612
Without batteries in the charger it will show null, until the display turns off.
DSC_9615
Charging two batteries. This can be seen on the two red leds. The display shows information for slot #2.
DSC_8219 DSC_8221
The slots uses the classical slider construction and it works fine.
The slots can work from 32 mm to 74mm. This means that it will handle all protected 18650, 21700 and 26650 cells.
DSC_8220
The 2A slots are marked.
DSC_8222
supportedBatteryTypes
supportedBatterySizes DSC_8383 DSC_8384 DSC_8385
DSC_8383 DSC_8386 DSC_8387 DSC_8388
DSC_8389 DSC_8390 DSC_8391 DSC_8392
Measurements
  • Power consumption when idle is 1 watt, it drops to 0.8 watt when the display is off.
  • When powered the charger will charge a full LiIon battery with about 0.4mA
  • When not powered the charger will drain LiIon batteries with 3mA
  • When not powered the charger will drain NiMH batteries with 0.4mA
  • At 0 volt charger will not recognize any batteries, but show Err and charge with 3mA.
  • Above zero volt the charger will start charging with selected current.
  • Below 1.8 volt batteries are assumed to be NiMH.
  • Between 1.8 and 2V the charger will not recognize a battery type.
  • Above 2.0 volt batteries are assumed to be LiIon.
  • Charger will not restart if battery voltage drops.
  • Charger will restart charging after power loss, or battery insertion.
  • Voltmeter do not update when charging is finished.
  • Voltmeter has a minimum reading below 0.4V
  • Voltmeter is within 0.02 volt when voltage is above 0.8V, .
  • Display light will turn off after 30 seconds.
Charge LiIon
LiitoKala%20Lii-500S%201A%20%28SA18650-33%29%20%231
This is a nice CC/CV charge curve with termination at around 150mA
Display shows 3334mAh 3:53
LiitoKala%20Lii-500S%201A%20%28SA18650-33%29%20%232
Display shows 3476mAh 3:45
LiitoKala%20Lii-500S%201A%20%28SA18650-33%29%20%233
Display shows 3278mAh 3:44
LiitoKala%20Lii-500S%201A%20%28SA18650-33%29%20%234
All channels looks fine, but voltage is on the high side.
Display shows 3247mAh 3:39
LiitoKala%20Lii-500S%201A%20%28SA18650-26%29%20%231
Display shows 2859mAh 3:14
LiitoKala%20Lii-500S%201A%20%28PA18650-31%29%20%231
The voltage goes a bit above 4.25V on this cell.
Display shows 2808mAh 5:56
LiitoKala%20Lii-500S%201A%20%28BE18650-26%29%20%231
Here the CV voltage phase hovers around 4.25V
Display shows 2290mAh 4:09
LiitoKala%20Lii-500S%200.5A%20%28KP14500-08%29%20%231
Display shows 723mAh 1:43
LiitoKala%20Lii-500S%200.5A%20%28AW18350-IMR%29%20%231
Display shows 130mAh 0:38
LiitoKala%20Lii-500S%200.5A%20%28SA18650-33%29%20%231
Display shows 3308mAh 6:47
LiitoKala%20Lii-500S%202A%20%28SA18650-33%29%20%231
Again the voltage is above 4.25V during charge.
Display shows 3172mAh 2:44
LiitoKala%20Lii-500S%202A%20%28AP18650-26%29%20%231
Display shows 2840mAh 1:58
LiitoKala%20Lii-500S%202A%20%28SA20700-30%29%20%231
Display shows 3109mAh 1:43
LiitoKala%20Lii-500S%201A%20%284xSA18650-33%29
Display shows on slot #1: 3395mAh 3:38
Display shows on slot #2: 3470mAh 3:38
Display shows on slot #3: 3442mAh 3:40
Display shows on slot #4: 3395mAh 3:38
Temp6955
M1: 36.3°C, M2: 38.3°C, M3: 37.8°C, M4: 35.6°C, HS1: 58.8°C
Temp6956
M1: 47.5°C, HS1: 54.0°C
PoweronLiIon
The charger is slow to start, because it waits for user input.
Charge NiMH
LiitoKala%20Lii-500S%201A%20%28eneloop%29%20%231
The charger uses a -dv/dt termination, here it needs about 20 minutes to detect it, this means the battery gets fairly hot at the end. Then it continues with a trickle charge of about 17mA
Display shows 2415mAh 2:42
LiitoKala%20Lii-500S%201A%20%28eneloop%29%20%232
Display shows 2399mAh 2:41
LiitoKala%20Lii-500S%201A%20%28eneloop%29%20%233
Display shows 2392mAh 2:40
LiitoKala%20Lii-500S%201A%20%28eneloop%29%20%234
The other four slots are similar
Display shows 2332mAh 2:36
LiitoKala%20Lii-500S%201A%20%28eneloopPro%29%20%231
Here is a fast termination, maybe even too fast.
Display shows 2554mAh 2:51
LiitoKala%20Lii-500S%201A%20%28fujitsu%29%20%231
With the Fujitsu cell the termination is fine.
Display shows 3196mAh 3:34
LiitoKala%20Lii-500S%201A%20%28leise25%29%20%231
Again a slow termination.
Display shows 3091mA 3:27
LiitoKala%20Lii-500S%200.5A%20%28eneloop%29%20%231
This termination is slight premature.
Display shows 1953mAh 4:24
LiitoKala%20Lii-500S%200.5A%20%28eneloopAAA%29%20%231
Display shows 911mAh in 2:03
LiitoKala%20Lii-500S%201A%20full%20%28eneloop%29%20%231
Detection of a full cell is fairly fast for a -dv/dt charger.
Display shows 203mAh 0:13
LiitoKala%20Lii-500S%201A%20%284xeneoop%29
Display shows on slot #1: 2211mAh 2:28
Display shows on slot #2: 2217mAh 2:28
Display shows on slot #3: 2148mAh 2:24
Display shows on slot #4: 2188mAh 2:26
Temp6971
M1: 33.3°C, M2: 32.4°C, M3: 33.2°C, M4: 34.6°C, HS1: 39.6°C
Temp6972
HS1: 43.2°C
PoweronNiMH
The same slow startup as with LiIon. As usually the charger turns current off to measure voltage.
TrickleNiMH
The trickle charge is full charge current for 1 second once a minute, this is about 17mA
Discharge LiIon
The possible discharge currents are 250mA and 500mA
LiitoKala%20Lii-500S%200.25A%20discharge%20%28SA18650-33%29%20%231
The low discharge setting uses constant current and discharges to about 2.8V
Display shows 3152mAh 13:00 2.80V
LiitoKala%20Lii-500S%200.5A%20discharge%20%28SA18650-33%29%20%231
The high setting also uses constant current and discharges to about 2.8V
Display shows 3268mAh 6:32 2.80V
LiitoKala%20Lii-500S%200.5A%20discharge%20%28SA18650-33%29%20%232
Display shows 3244mAh 6:29 2.80V
LiitoKala%20Lii-500S%200.5A%20discharge%20%28SA18650-33%29%20%233
Display shows 3152mAh 6:32 2.80V
LiitoKala%20Lii-500S%200.5A%20discharge%20%28SA18650-33%29%20%234
Display shows 3271mAh 6:32 2.80V
LiitoKala%20Lii-500S%200.5A%20discharge%20%284xSA18650-33%29
The charger can do four 0.5A discharges at once and temperature is fairly moderate.
Display shows on slot #1: 3277mAh 6:33
Display shows on slot #2: 3372mAh 6:44
Display shows on slot #3: 3346mAh 6:41
Display shows on slot #4: 3329mAh 6:39
Temp6983
M1: 44.1°C, M2: 44.8°C, M3: 46.2°C, M4: 46.4°C, HS1: 65.5°C
There is some heat while discharging LiIon.
Discharge NiMH
LiitoKala%20Lii-500S%200.5A%20discharge%20%28eneloop%29%20%231
NiMH is discharged with constant current to about 1.1V.
Display shows 1834mAh 3:40 0.9V
LiitoKala%20Lii-500S%200.5A%20discharge%20%28eneloop%29%20%232
Display shows 1741mAh 3.29 0.9V
LiitoKala%20Lii-500S%200.5A%20discharge%20%28eneloop%29%20%233
Display shows 1839mAh 3:40 0.9V
LiitoKala%20Lii-500S%200.5A%20discharge%20%28eneloop%29%20%234
Display shows 1897mAh 3:47 0.9V
LiitoKala%20Lii-500S%200.5A%20discharge%20%284xeneloop%29
No problem with discharging four cells at a time.
Display shows on slot #1: 1908mAh 3:49
Display shows on slot #2: 1941mAh 3:52
Display shows on slot #3: 1914mAh 3:49
Display shows on slot #4: 1945mAh 3:53
Temp6975
M1: 35.5°C, M2: 35.3°C, M3: 35.9°C, M4: 36.5°C, HS1: 40.8°C
With NiMH the heat is fairly limited.
Temp6976
HS1: 45.1°C
Test LiIon & NiMH
This is a combination of charger, discharge and then charging again, show the result from the discharge.
LiitoKala%20Lii-500S%200.5A%20test%20%28SA18650-33%29%20%231
The display shows data for the discharge, the total time used here is about 14.5.
Display shows 3257mAh 6:30
LiitoKala%20Lii-500S%201A%20test%20%28eneloop%29%20%231
The NiMH is faster the to test, but still takes a lot of time (9 hours).
Display shows 1977mAh 3:57
USB output
  • When not powered the charger will drain LiIon batteries with 2mA (No USB symbol on display)
  • When display is on the charger will drain LiIon batteries with 26mA (Total for all loaded batteries)
  • When display is off, but USB output is on the charger will drain LiIon batteries with 13mA (Total for all loaded batteries)
  • MODE button will turn display on
  • USB output is coded as Apple 1A
  • When power is connected, USB output is forced off.
  • When the load drops below 70mA the output will turn off in 20 seconds.
LiitoKala%20Lii-500S%20230V%20load%20sweep
The USB output can deliver 1.1A, this is fine for a 1A USB charger, but not that much current for a modern smartphone or tablet.
LiitoKala%20Lii-500S%20120V%20load%20sweep
LiitoKala%20Lii-500S%20charging%20230V%20load%20sweep
The USB output also works with full power while charging 4 LiIon batteries.
LiitoKala%20Lii-500S%20230V%20load%20test
There is no problem running the USB output at 1A for one hour.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp7029
HS1: 51.6°C
Temp7030
HS1: 48.3°C
Temp7031
HS1: 42.1°C
10ohm
There is 42mV rms and 1403mVpp noise. This is very good values.
5ohm
There is 40mV rms and 1324mVpp noise. The high peak level is probably common mode noise from the power supply.
Testing the power supply with 2830 volt worked fine, but it failed 4242 volt between mains and low volt side, this makes it unsafe in 230V countries.
Conclusion
The charger works, LiIon charge voltage is slightly on the high side, it is not perfect at terminating NiMH and USB output works fine at 1A. The temperature when discharging batteries is acceptable. The displayed capacity values are a bit on the high side.
The failed high voltage test is bad, buying another power supply could fix it.
Notes
Read more about how I test USB power supplies/charger
BaronVonEissler
BaronVonEissler's picture
Last seen: 2 weeks 1 day ago
Thanks for the review. They are very helpful.
With the Failed High Voltage test and the Inability to Discharge at 1amp[1000mAh], I am happy to stick with my Opus BT-C3100 2.2. Big Smile
You can't hide me from me.
eebowler
eebowler's picture
Last seen: 1 month 1 week ago
Thank you for the review!
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
RapidLux
RapidLux's picture
Last seen: 9 hours 44 min ago
Will it be safe to use the old Lii-500 power supply, if not charging cells with the 2A option?
HKJ
HKJ's picture
RapidLux wrote:
Will it be safe to use the old Lii-500 power supply, if not charging NiMH cells with the 4*2A option?
It is LiIon charging you have to be careful with. My guess is that a total of 4A LiIon charge current will be safe with a 2A plug pack.
RapidLux
RapidLux's picture
Nice, then I will replace the new power supply with the old Lii-500 one, and use the new charger as usual.
NorthernHarrier
NorthernHarrier's picture
Last seen: 1 day 15 hours ago
Thank you for the review. I have a Lii-500S, and it seems to be terminating charging of my Li-ion cells at 4.2 volts and otherwise working fine. I’ve also charged quite a few Eneloop and Fujistsu NiMH cells, which have not felt warm to the touch at termination of charging.
RapidLux
RapidLux's picture
I’ve used this charger maybe 15 times in 230 volt with the original power adaptor. Can this have damaged the charger, in a way there could now be a weakness inside that may once escalate into something serious danger? And even if I now start to use the old Lii-500 power supply?
SIGShooter
SIGShooter's picture
Last seen: 2 hours 38 min ago
Don’t see why since the power supply is a universal one (100-240VAC 50/60Hz) and the charger itself only sees 12 volts.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
HKJ
HKJ's picture
Most likely not. The risk with a failed high voltage test is not the charger, but anyone touching the metal on the charger, but the high voltage test/requirement includes a lot of safety compare to normal domestic power. If you lives near some large factories or have a lot of lighting strikes in the area the risk is greater.
hammerJoe
In 2020 I would say that this is not a good charger either for Lion or Nimh.
With so many good choices out there we have to start to be more critical of newer devices and this one based on HJK review should fall under the no buy category.
HJK work is important because most of us do not have equipment to see what the charger is actually doing.
In the end these chargers end up charging the batteries and they tell us what they charged but without the equipment we dont know if it handled the cells properly and/or actually charged the cells correctly.
Micro
Last seen: 1 month 1 day ago
Thanks for the review HKJ.
Very good work. Smile
I have this charger. Hhmm. But the good thing, i have another charger to use Xtar Sv2 Rocket Smile
Is there anyone who can recommend a power supply for the Liitokala 500S charger with eu plug.
Thanks in advance.
Have a nice day or night. Micro.
flydiver
Last seen: 12 hours 40 min ago
It’s probably a ‘standard size’ plug, at least the one on the older Lii-500 is. I’ve found 3-5A/12v PS in local computer/electronics recycle stores for like $2-3. Work great. Many of my chargers are now powered by these ‘upgrades’.
Just take the charger with you to check for sure and glasses if you need them to read the fine print for output.
I agree with @hammerJoe. There would seem to be better chargers available. It’s not awful, but after reading HKJ review I wouldn’t buy it.
Micro
Thanks for the answer flydiver. Wink
I have your solution in my mind.
The solution for me was easier than I thought. Uses the Xtar power supply. The plug fits nicely and even if it only gives 2A it will work fine. I don’t charge the batteries so hard.
woodyt
Excellent review as always, thanks for your hard work
Nisei
Last seen: 1 month 3 days ago
@HKJ
Thanks for the review!
The display backlight turns off after 30 seconds but when you press one of the channel buttons for a few seconds it will stay on.
Perhaps you could add that to the list.
CNCman
CNCman's picture
Last seen: 8 hours 55 min ago
Thank You HKJ for that review. That was very deep/detailed, clear presentation.
I was going to buy this charger later this year.
But now I will get another Opus BT-C3100 2.2 instead. Thumbs Up
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
zarko550
Last seen: 2 days 20 hours ago
You mention that there are better alternatives – would you mind giving an example of other chargers that have the same functionality – can charge 21700 Li-ion, as well as NiMH and act as a power bank.
puglife2
puglife2's picture
Last seen: 1 day 16 hours ago
Vapcell S4 Plus
