ReyLight copper pineapple mini, AAA/10440 flashlight, Nichia 219B 4500K R9080 high CRI LED
174 posts / 0 new
milk
milk's picture
Last seen: 1 day 5 hours ago
Mine appears to have been sitting in Shenzhen with the airline carrier since the 15th (ordered on the 9th). Does the CNY affects air travel too? Maybe I just missed the window..
raccoon city
raccoon city's picture
Last seen: 51 min 9 sec ago
I heard that the "slow boat from China" is a myth and that the vast majority of stuff coming from China comes via air.
I believe that's true, and that CNY affects air travel.
mortuus
mortuus's picture
Last seen: 15 hours 5 min ago
the whole country is shut down more or less during their holidays, its crazy but thats how it works there dont expect any movement until early next month.
...where Frugal meets with Flashlight!
Johnnyh
Johnnyh's picture
Last seen: 2 weeks 3 days ago
Mine got here relatively quickly (upstate NY) , about two weeks. Great looking light but it’s malfunctioning. Won’t come on unless I unscrew the head a few turns, then works for a bit then goes out again. Emailed Rey but like many in his country it’s vacation time. Anyone else experience this or any ideas on a fix?
id30209
id30209's picture
Last seen: 2 hours 24 min ago
Wait for a week for celebration end. Rey will be available only then.
WTB  Jetbeam TCR1  &  Titanium 47 2xAA Quark
Unheard
Last seen: 10 hours 22 min ago
Can you take a picture of the driver PCB? Maybe the ICs are not seated properly on the PCB, or the whole PCB came loose.
LemonLime
Last seen: 2 days 7 hours ago
Something similar with the unit I received. No LED but the copper heats up with enough clicks.
Unheard
After about two minutes on 10% mode the light turned off, leaving me in the dark. I tried an AAA but it won’t came on. Re-inserted the LiIon and it was alive again. Cannot reproduce it. It didn’t get hot, there were no mechanical impacts. I can slighty unscrew the head and retighten it, shaking the light, whatever, it works continuously.
I will take it apart if there’s time. For now, it is suspended from its EDC duties.
Unheard
Shortcut between driver output and copper caused e.g. by solder could explain it.
Johnnyh
Johnnyh's picture
I don’t have any li-ion in this size, only AAA Eneloop and AAA alkaline. They both exhibit the same behavior...by the way...shouldn’t there be an O-Ring between the lens and the reflector?
Coaster
Last seen: 5 days 18 hours ago
The oring between the lens and reflector is gitd so it may be hard to see in daylight.
Unheard
Johnnyh wrote:
I don’t have any li-ion in this size, only AAA Eneloop and AAA alkaline. They both exhibit the same behavior…by the way…shouldn’t there be an O-Ring between the lens and the reflector?
There’s a GITD-ring.
Johnnyh
Johnnyh's picture
I took it apart...there is no o-ring anywhere in the head.
Unheard
What causes the glowing?
Johnnyh
Johnnyh's picture
There is no glowing...a GITD Ring was supplied in the box it came in but no ring is installed in the head. Could this be causing the odd behavior?
Coaster
Could be. Mine had a gitd oring in the head already and one in the box. I would also check the the retaining ring is tightened sounds like yours was built at the end of the day.
Johnnyh
Johnnyh's picture
I think you’re right...one of the body o-rings was missing also...anyways...I installed the GITD o-ring behind the lens, installed the reflector and reinstalled the led module...began working...sort of...it visibly flickers in high mode...rapidly changing output...I’ll mess around some more and see what happens. Thanks all for the help!
Coaster
Johnnyh wrote:
I think you’re right…one of the body o-rings was missing also…anyways…I installed the GITD o-ring behind the lens, installed the reflector and reinstalled the led module…began working…sort of…it visibly flickers in high mode…rapidly changing output…I’ll mess around some more and see what happens. Thanks all for the help!
Once Rey is back from vacation I’m sure he’ll make it right if it is still acting up.
Johnnyh
Johnnyh's picture
Yes... no worries here!
chops728
Last seen: 5 hours 4 min ago
Mine worked with an Eneloop fine —- when I went back to try it again that night it wouldn’t come on —tried another AAA alkaline battery nothing — I then tried a Li on cell worked perfectly —- afterwards it worked with the Eneloop —- I didn’t check the voltage — I’m assuming the AAA cells voltage are right on the edge of not working the boost driver properly
ReyLight
ReyLight's picture
Last seen: 19 hours 8 min ago
Sorry for the late reply. Living in a remote area during the holiday. I can only access the internet now and then. It might be better to pm me incase I miss something.
I will go to the factory and re-check the lux reading when I go back to work.
The holiday was Feb-5, now it is few days longer, because there is a very terrible disease in China, most people wear a mask and stay at home.
Thanks Kevin Manley for the more detailed manual.
Reylight Mini Pineapple Programming Guide
1. Turn on the light.
2. Press (tap) the button 8+ times. The light will now blink once, then strobe, blink twice, then strobe, blink three times, then strobe…After 5 blinks and a strobe, the sequence repeats.
a. 1 blink: mode group selection. Press the button to enter this menu.
i. 1 blink: (ML)-2%-20%-100%
ii. 2nd blink: (ML)-10%-40%-100%
iii. 3rd blink: (ML)-2%-10%-50%
iv. 4th blink: (ML)-50%-100%-strobe-SOS
It then repeats. Press the button during any blink to select that mode group.
b. 2 blinks: mode memory on-off toggle (default off). Press the button during the two blinks or during the strobe after to turn mode memory on. Repeat to turn mode memory off.
c. 3 blinks: moonlight mode off-on toggle (default on). Press the button during the three blinks or during the strobe after to turn moonlight off. Repeat to turn moonlight on.
d. 4 blinks: mode order toggle (default LMH). Press the button during the four blinks or during the strobe after to change the mode order from Low Medium High to High Medium Low. Repeat to reverse the order.
e. 5 blinks: factory reset. Press the button during the five blinks or during the strobe after to reset the light to factory settings.
Johnnyh
Johnnyh's picture
Just to update...don’t know why or how but after a few on-off cycles and mode switching, the light is working as normal...go figure...
BTW, Rey contacted me via email last night since I had reached out to him when I first received the light...very nice of him during such a difficult time in his country. Very much appreciated!
trakcon
trakcon's picture
Last seen: 4 hours 10 min ago
Stay safe, Rey.
Unheard
… and enjoy your hollidays.
id30209
id30209's picture
And there’s a report that new Reylight won’t turn on on NiMh, only alkalines...
Looks like Rey is going to be busy making changes to the driver.
trailhunter
Last seen: 4 days 15 hours ago
Order placed
Unheard
id30209 wrote:
And there’s a report that new Reylight won’t turn on on NiMh, only alkalines…
Mine does. But it switches off at higher modes and won’t come back until I reinsert the 10440. Very strange behaviour.
Hope Rey can solve the problems [and offer driver PCBs at a discount for us Big Smile ].
dk21291
dk21291's picture
Last seen: 1 week 1 day ago
Not the case for me, I have been running mine exclusively on Eneloops, not a single problem.
treellama
Last seen: 6 hours 19 min ago
Mine won’t run on alkalines or NiMH, only 10440. Probably just some issues with the first batch of drivers.
Firebird
Firebird's picture
Last seen: 2 weeks 4 days ago
Hey all, first post here but thought I’d share my experience with this light.
Before you read the rest, know that I love this little light and want to get the pinapple AA version now.
(POST EDITED) It appears that Rey’s site already says that a normal button top battery is not suggested, something we should have read a little better.
Worked great out of the box, my one gripe was the tail switch was a bit sticky and needed to be pressed straight down to function properly. Fixed by unscrewing and re-seating.
Then I dropped the light (threw it accidentally by chasing it) against a tile ceramic floor. Very hard.
This caused the same problem described above, it will give problems with a normal AA and tightened down all the way, but with the shorter rechargeable there’s no issue.
The extra length of the button top on the Energizer ultimate lith. is the difference, and depending how much you tighten can cause either flickering or complete failure to turn on. Loosening one turn fixes it.
Trying to work the action back and forth seemed to make it better, making me think the board itself is possibly unseated a bit? I am no flashlight engineer so this is as much as I can say.
Otherwise, the light works great and I absolutely love it. Honestly I’m amazed it took the abuse I’ve dished out and the light only started giving issues after I smashed it. Fast shipping too, lovely tint.
AzzonFire.
