Anyone know if I could fit (4) Sub-C's (23mm x 43mm) into a 3C Maglite? 43mm x 4 cells = 172mm. 3 standard C's (50mm long) = 150mm. Can I gain 22mm more with a tailcap mod?
I know you can fit 3C's in a 2D cell Maglite with a tailcap mod. 2 D's should be 123mm long, and 3 C's should be 150mm long, so apparently you can gain 27mm with a D cell tailcap mod. I don't know how much gain you get in a C cell tailcap.
I can get 5000mAh Sub-C's. My thinking is to run (4) 5000mAh Sub C's instead of (3) 5000mAh C's for more capacity. The driver is rated up to 6 volts.
-Garry
