[WTS] ON THE ROAD - U16 FOR SALE
BRAND NEW IN BOX (NEVER USED) this is the USB-c version that is only available from Aliexpress. Here are pics and description (from Chinese) below that.
Price = $32.80 + plus shipping to you (what I paid)
Why wait weeks to get it from China - get your brand new U16 today!
More Specifications:
【Body Design】Water resistant with a hard-anodized finish; anti-abrasive, shock-proof
【USB-C Charge】U16 can be recharged by USB-c cable directly,USB to wall or car adapter, and can be lighting while charging. Friendly red and blue battery indicator;
【CREE LED】CREE XM-L2 U3, Max output:1020lumen; aluminum vacuum electroplating reflecting system;Max luminous flux:4900cd;Max beam distance:140m;
【8 Mode】Regular 4 adaptable settings: Ultra Low/ Low / Medium / High; 4 Stealth Modes: Turbo/Strobe/Beacon/SOS. Double click direct to the Turbo, three click are Strobe 720lumen max for 35 minutes, 2 lumen for 160h;
【Super Compact】Length 71mm, Head Diameter26.5mm,Tail Diameter 24mm;Weight:60g (without battery);smallest lightest USB 16340 flashlight;
Modes & Lumen & Run time: Ultra Low: 2LM / 140H (Run time) Low: 150LM / 2H30M(Run time) Medium: 360LM / 1H (Run time) High: 720LM / 35M (Run time) Turbo: 1020LM / 30M (Run time) Mode Memory:remain at any mode, record by smart IC Card automatically will be the same mode when switch on next time. Mode Lock: Only One Mode Lock Method: When the light is on, LONG PRESS button for 2s until the light flashing. Then flashlight is turned off. When you open it again, it has entered the single mode. Unlock Method: Same as above, repeat the operation once again. WARNINGS: Do not look directly into the light in case of causing the damage to the eyes. Please close the concealed charge and reverse charge module if you don`t need when using and store.
