An upgrade to an old favorite, Crelant 7G5 SBT-90.2
16 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 2 weeks 4 days ago
Ok, so for the Crelant 7G5 SBT-90.2 build I got the new driver built and the fix for Bistro on it, rebuilt the light and am very pleased with the results…
A big part of the choice for using this light was the tail end, as it holds a heavy duty Tofty switch. These were built in England some years back and were $25 apiece! Worth it though when you need a quality switch that carries serious power, as this light now does… A Samsung 25S cell gives 23.2A at the tail for 4240 lumens out the front. Lux is 352.5Kcd for 1187.43M throw. I Like It! Big Smile
I built a light engine/heat sink to replace the emitter shelf area and I made it about an inch longer than there was room for, bored the end of the battery tube to accept this extra length and tie the heat sinking into the battery tube. Wink
I needed a spacer as the tube is still longer than an 18650, so I used a .458 Ham’r brass soldered onto a switch board, the board keeps the spacer centered and the heavy BlueSword spring contacts the brass screw in the Tofty switch. Big Smile
In the Crelant 7G5 the reflector has a 53mm opening and is approximately 55mm deep, this yields an excellent hot spot that is fat and well defined, the beam profile is a tube/column of light much like a very fat laser. Will get beam shots later tonight…
What with multiple interruptions it was somewhat of a hassle to build, but well worth it in the end! A great update to a nice old light, very happy with it’s performance… I just need to find some more Samsung 25S cells now. lol
1-15-20, beamshots (super high humidity then dense fog)
Edit: It’s 610 yds to the little white barn in the one shot, 195 yds to the tree in the other. Wink
Edited by: DB Custom on 01/15/2020 - 10:10
MRsDNF
MRsDNF's picture
Last seen: 11 hours 28 min ago
Nice work Dale. Good luck on your search. Thumbs Up
Where are your sourcing your leds?
DB Custom
DB Custom's picture
I got the 90.2’s from Wendy at Lantend.
Just ordered 6 Samsung 25S 18650’s from IMRbatteries for $3.99 each. Most power from an 18650 I’ve found.
DB Custom
DB Custom's picture
Neal has had some of the 90.2’s at a good price but I don’t know if he has any left. Worth a look at NealsDeals
The_Fat_Controller
The_Fat_Controller's picture
you need to find an aspheric for that old classic, i don’t know if it is the same as the 7g5cs , but if it is the 7g5ch collimator head may fit the thread on the neck section certainly looks hopeful Wink
DB Custom
DB Custom's picture
Yes but… I much prefer a reflectored light to an aspheric.
MRsDNF
MRsDNF's picture
Beer
EasyB
Last seen: 7 hours 59 min ago
Nice, it looks like you added some needed mass and heat sinking with your custom pill. I think this is a great size light for this LED, prob a similar beam to my L2 with this LED. Good size to light up a large area a couple hundred meters out. I got 280kcd in the L2 at about 22A.
DB Custom
DB Custom's picture
Several not-ideal beamshots added to the OP.
It’s intense, for sure! lol
DB Custom
DB Custom's picture
Thinking of making a custom head via the bezel threads to enable a large reflector to fit on a Q8, thus utilizing 4 parallel cells in the soup can style light while also optimizing it with a larger reflector for this emitter. Big Smile
The_Fat_Controller
I couldnt decide….. so i ended up with both Facepalm
NICE BEAM SHOTS!! that looks impressive , how wells it coping with the heat?
johny723
Last seen: 1 day 20 hours ago
I don’t have the privilege to hold it in person, but based on the power consumption of the emitter, it should be like taking a hot potato out from the embers Big Smile
DB Custom
DB Custom's picture
I rebuilt my seventh scratch built light today, marrying my previous adapter and pill to a Q8. The big Luminus die does not disappoint in a 124mm reflector! Big Smile
DB Custom
DB Custom's picture
I set the thermal configuration in Bistro on the Crelant last night and it made 55 seconds before I cut it off, figured to stop it a little shy of too hot in order to allow some lee-way. Wink
The new one today uses Anduril and has far more heat sink mass… have yet to set thermal configuration or get beam shots as dark has yet to arrive. A too short 5M test shows 1.71Mcd though so it should be interesting getting a beam shot… hope weather is accommodating.
gerasalex
gerasalex's picture
Last seen: 9 hours 6 min ago
hmm .. it would be interesting to insert SBT-90.2 into the mf02 housing from the astrolux..
"... God is light, and in him is no darkness at all..." 1 John 1:5 (KJV)
Rusty Joe
Rusty Joe's picture
Last seen: 2 weeks 5 days ago
But it’s not regulated, is it?
